Asus F555L Upgrade: Replacing Intel Core i3-4005U with i5 or i7 Processor - Compatibility & Factors
janusz2301 9453 9
Can I replace the Intel Core i3-4005U in an Asus X555LJ notebook with a compatible i5 or i7 processor, and if so, which one will fit?
No, in this model the Core i3-4005U is soldered to the motherboard, so you cannot swap it for an i5 or i7 CPU [#16390477][#16390539] The U-series processors are described as soldered, so there is no drop-in socketed upgrade path [#16390539] Even though Asus sold X555 variants with i5 and i7 processors, that does not mean your board can be upgraded by replacing only the CPU; it would require a different board/module [#16390572][#16393172]
  • #1 16390413
    janusz2301
    Hello. I have a 1.5 year old laptop. I want to replace the processor with i5 or i7 anyway. In fact, this i3ka "slows down" a bit. I don't know what to replace. What i5 or 7 will go in it. I do not know what slot, etc. What processor will be supported (max. Parameters, but also such that it does not turn out that the processor will go, only the motherboard will have too bottleneck, for example, on the bus. detailed, so that I have sufficient knowledge on the subject, I also do not know how economical it will be (i5 v i7). I would ask for help.
    These are the parameters present:
    Processor type Intel Core i3-4005U, 1700 MHz (17 x 100)
    Name of Asus X555LJ Series Notebook motherboard
    Motherboard chipset Intel Lynx Point-LP, Intel Haswell
    BIOS type AMI (04/08/2015)
    Integrated Intel (R) HD Graphics Family (1 GB)
    Dedicated nVIDIA GeForce 920M graphics
    M4-CT256M4SSD2 SSD physical disk (256 GB, SATA-III)
    As I wrote, the laptop "clogs" especially with several threads at once. Hence the decision to possibly replace the processor. Thank you very much for all your help. best regards
  • #2 16390477
    andrzejz78
    Level 19  
    Help: 25
    Rate: 110
    There, you probably have a processor soldered to the board, so you won't do anything
  • #3 16390539
    grubas
    Level 40  
    Help: 647
    Rate: 553
    The processor is not replaceable. All with the letter are soldered.
  • #4 16390572
    janusz2301
    It's not going to be soldered? Besides, the same models were made of the i5 and i7ka. And they had the same motherboard name. So I don't quite understand ????
  • #5 16390600
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    You can try.
    Changes in general cargo are possible.
    Did you compare the rev albums?
  • #6 16390627
    janusz2301
    I haven't compared anything yet. In fact, I'm surprised by the info about the soldered processor. Now I am beginning to understand why there was a lack of processor compatibility in the description. What will they not do today to throw away old equipment with garbage. Shock. Anyway, you can get the same i5 or i7 somewhere? It will probably be a BGA solder. And as for the Prock - this is the same model with the i7: Intel Core i7-5500U. Going to buy it somewhere?
  • #7 16392121
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    In China
    Intel SR23W I7-5500U I7 5500U BGA1168
    price 197. $
  • #8 16393172
    xironeksik
    Help: 60
    Rate: 71
    Unfortunately, such a future awaits us that processors, memories, etc. will be soldered in the board and only the entire module will be replaced (if it is available at all). As a result, the expansion of laptops will fail because the customer, for example, after 2-3 years from the purchase, will not be able to replace the processor itself and add a framework, but will be forced to go for a new computer ...
    You can currently search for the entire album and sell your current one. It is also often the case that if you had an i7 and simply soldered it, it would start, but it will not be profitable in terms of price, so few people practice it ... I have recently replaced in Acer such a processor from i3 to i5 and the laptop fired without any modification since an arrow (only there was a situation that the slingshot was dead and we had a working one in the flooded fin, so you did not risk a lot, only your time to deflect the prock and re-solder in the new disc).
    PS The worst thing is that there is a fashion for SSD disks and the manufacturer is also soldering into the board more and more often and with a failure of the board for an ordinary Kowalski, it will be practically impossible to recover data ... Such times are waiting for us, unfortunately now in the amount of up to PLN 2,000 they no longer do laptops only toys ....
  • #10 16426831
    janusz2301
    Exactly. I close the topic.
The discussion centers around the potential upgrade of an Asus F555L laptop, specifically replacing the Intel Core i3-4005U processor with an i5 or i7 variant. Users express concerns about the compatibility of processors, with several responses indicating that the i3 processor is likely soldered to the motherboard, making upgrades impossible. The Asus X555LJ motherboard, equipped with an Intel Lynx Point-LP chipset, limits the upgrade options. Some users mention the possibility of finding an i7-5500U processor, but the general consensus is that the soldered nature of modern laptop components restricts upgrades, leading to a trend where entire modules must be replaced instead of individual components. The conversation highlights the challenges of laptop repairability and the decline of motherboard repair services.
