Win 7 computer 32-bit - Black screen with cursor before user selection
Marcinkazzzek 4776 6
  • Deleted atikmpag.sys likely caused boot failure
    #1 16715874
    Marcinkazzzek
    Hi I'm Marcin And I would like to ask for help since yesterday When I turn on the computer a black screen appears with the cursor before logging in to the user
    EMERGENCY modes have a black screen with the cursor
    normal wine mode however 7 Displays a blue screen
    atikmpag. sys something out there
    this problem appeared when I went to the task manager and deleted some atimkdag.sys file
    all you could do was enter the cmd register editor. Is it possible to fix this black screen?
    I forgot to add that in normal mode after starting the blue screen pops up and after a while the computer restarts
    while in emergency modes a black screen appears with the cursor in the middle with which I can move but there is nowhere to choose the user I clicked enter and nothing works just stands still but the mouse can be moved. please help not wanting to format the computer.
    IF THIS IS NOT THIS DEPARTMENT.
  • #2 16715889
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    If you have a system restore point, use it, you can start the restore from the W7 installation CD, unless you can under Windows.
  • #3 16715897
    Marcinkazzzek
    I just need another idea to remove this black screen. Using an editor or cmd, I know it can be done, but how? Some serious sonic expert I need.
    I can only add that the option is in HKEY LOCAL MACHINE, but I do not want to spoil anything, just fix it.
  • #4 16715919
    nici
    Help: 266
    Rate: 979
    Do as he writes @Kolobos .
    Marcinkazzzek wrote:
    some serious personalized expert I need
    That's what a friend is like.
  • #5 16715951
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Alt + ctrl + del work? Manager on? If so, enable restore.
  • Missing atikmpag.sys points to graphics driver failure
    #6 16715981
    Marcinkazzzek
    Damn I'd rather use the registry editor ... THIS IS EVERYTHING I FIND I know it is for the advanced but I have a broken pocket (pushed in by my sister) And the question is how to do it
    I went to F8 to fix the system. I clicked startup repair tools
    loading was short and I wrote:
    the system repair tool during startup cannot detect the problem.
    System restore also won't help because I am writing no restore points have been created on the computer's system disk. to create a restore point. open system protection. kliklem. This computer is running on a restricted diagnostic stand. If you use the system restore function in this restricted state, you cannot undo the restore operation
    Retrieving the image If the pocket is broken, return it to the expert format
    Memory Diagnostics MEMORY CHECKING is in progress for problems
    I will give the results after graduation
    The only option that works with me is CMD, you can open all folders with cmd. However, I think the registry editor will be more effective as to the black screen
    I know the black screen has been fixed in skull removal. creating a new skull entry, then the data modification exploder.exe and smigalo
    With this black screen before logging in can not be repaired or even enter at least 1 account
    I have given all the information if anyone has ideas to write or the fogmat option remains
    Just that alt + ctrl + del does not work and the messamer only appears on the black screen
    I found 1 error that the atikmpag.sys file is missing
    THEN it turned on and the blue screen went out after a while
  • #7 16715990
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    I write "I came in", is it so difficult? Not to mention the fact that the word removed is not about ...
    Can you answer the questions? Task manager working? Turns on after pressing alt + ctrl + del?
    The registry is set to shell on explorer.exe, not "skull", but how do you know that this is a problem since it has broken graphics card drivers, not shell?
The discussion revolves around a Windows 7 32-bit computer experiencing a black screen with a movable cursor before user login. The issue arose after the user deleted the atikmpag.sys file via Task Manager. Attempts to access normal mode result in a blue screen error, while safe mode presents a black screen with no user selection. Suggestions include using System Restore from a Windows installation CD, checking Task Manager functionality, and ensuring the registry is set correctly to launch explorer.exe. The user expresses a preference for using the registry editor to resolve the issue, but is concerned about potential mistakes. The discussion highlights the challenges of troubleshooting without restore points and the possibility of broken graphics card drivers.
