Windows 7 System Files Damage - Computer Reboots at Startup, Safe Mode Inaccessible
Adan199518 7371 19
How can I fix a Windows 7 PC that reboots at the “Windows is starting up” screen and won’t enter Safe Mode or Startup Repair?
You likely cannot repair this installation; the recommended fix is to reinstall Windows 7 because the system was installed on another computer and will not boot properly on this one [#16296004][#16293901] If the disk came from a laptop, moving it to a different PC can prevent the system from starting, even if Safe Mode and repair also fail [#16294736] Switching IDE/AHCI is not the real solution here, especially if the motherboard does not support AHCI [#16294736] If you need important files, connect the disk to another computer with a USB adapter or boot another system from USB and copy the data off the drive [#16294148][#16294810]
  • #1 16293846
    Adan199518
    Rate: 11
    Hi. I have a problem namely when starting Windows 7 when the message "Windows is starting up" appears, the computer resets, it is impossible to turn on safe mode or restore to the last known configuration the same happens. I tried to fix using the Windows 7 tile but the repair did nothing. You can exclude that the hardware is damaged because another disk is working, I suspect that something is damaged in the system files. I tried from the command line sfc command. I would ask for help
  • #2 16293901
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Reinstall the system, you won't fix it anymore.
  • #3 16293925
    Arekadiuszby
    Rate: 32
    I had it when I made the backup ... Only the reinstall of the system worked.
  • #4 16294049
    Adan199518
    Rate: 11
    However, I have important data, it is not a good option for me, this disk was from a laptop, maybe I should switch in bios from IDE to AHCI
  • #5 16294148
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    You can switch and check.
    You can connect the disk to another computer and save important data or even boot any system from usb and use it to rip data from the disk to another medium.
  • #6 16294604
    Adan199518
    Rate: 11
    And how to switch it in the bios because I can't do it too much, I prefer to get a little tired myself for sure, it will give me more knowledge about it. After enabling the option of not starting the system, the following bluescreen is displayed after an error:
  • #8 16294716
    Adan199518
    Rate: 11
    I have Windows 7 Home Premium 32 bit, Gigabyte GA-M61SME-S2 motherboard, AMD 2GHz processor, 2 GB RAM memory. Unfortunately, I found out that my motherboard does not support ACHI mode.
  • #9 16294736
    DriverMSG
    Help: 3984
    Rate: 4883
    And what does this have to do with the problem? And since it doesn't support, why does the board manufacturer give AHCI drivers?
    Adan199518 wrote:
    this disk was from a laptop maybe should switch in bios from IDE to AHCI
    If the system was also from this laptop, there is no chance to run it on this PC.
  • #10 16294777
    Adan199518
    Rate: 11
    Why because there are no drivers loaded on this PC what does it consist of? And the drivers are on ACHI, I did not notice where in the FAQ it said that there is no CD, there is no ACHI support: /
  • #11 16294785
    DriverMSG
    Help: 3984
    Rate: 4883
    Adan199518 wrote:
    what is it about
    Because they are uploaded from a different computer with a different chipset etc.
  • #12 16294796
    Adan199518
    Rate: 11
    Is there a way to upload the drivers themselves then should Windows work? Indeed the drivers are for ACHI only that there is none for my Windows 7 32 bit
  • #13 16294810
    DriverMSG
    Help: 3984
    Rate: 4883
    The only way I know is to remove all possible drivers and turn off the system before removing the disk (in this case from the laptop).
    After transferring the disk to another computer, this one should detect the deficiencies and install the appropriate drivers.
  • #14 16294819
    Adan199518
    Rate: 11
    I can't insert this disk into my laptop anymore it has crashed the disk has been working and I wanted to work on it normally it can be done from windows I have a USB adapter I can operate data on the disk
  • #15 16294839
    DriverMSG
    Help: 3984
    Rate: 4883
    Adan199518 wrote:
    it can be done from windows I have a USB adapter I can manipulate data on a disk
    I will not help in this matter.
    Installation of Windows 7 takes up to an hour - you will lose more time on the laborious search for responsible files.
  • #16 16294862
    Adan199518
    Rate: 11
    Can you focus on this error? I think that in safe mode it should start without drivers and it does the same, i.e. it resets. At most, it's about ACHI mode
  • #17 16295886
    Arekadiuszby
    Rate: 32
    How many times should you repeat this drive to something else?
  • #18 16296004
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    @Arekadiuszby for what? The problem is that the author has installed the system on another computer and is now trying to run it on this. That's why it doesn't work.
    You must reinstall the system.
  • #19 16367634
    Adan199518
    Rate: 11
    There is no way to upload drivers from a new computer somehow so that this system can work on a new computer?
  • #20 16367663
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    > Reinstall the system.
The discussion revolves around a Windows 7 system that fails to boot, repeatedly resetting at the startup screen. The user is unable to access Safe Mode or perform a system restore, leading to suspicions of damaged system files. Several participants suggest reinstalling the operating system as the most viable solution, although the user expresses concern about losing important data. Alternatives proposed include switching the BIOS setting from IDE to AHCI and using a USB adapter to recover data from the disk. The user reveals that their motherboard does not support AHCI mode, complicating the situation further. The conversation highlights the challenges of running a system installed on one computer on a different hardware setup, emphasizing the need for a fresh installation of Windows 7.
