Windows 10 Black Screen After Login with Cursor, No Task Manager Access
mateusz2957 6711 8
  • #1 17269746
    mateusz2957
    Hello from yesterday I have a problem with the computer because when I try to turn on the computer I can log in normally but after logging in a black screen pops up with the cursor only which looks like with xp is the same hourglass when I turn on ctrl alt del but when I turn it on I can't start the task manager because I don't pop up I can only move the cursor, please help
    Windows 10
    When I started the computer yesterday it was good and today after logging in I was prepared for the system and then after reset nothing and I wait for about an hour
    I am asking for quick help
    PS: I can't even turn on safe mode
    Moderated By DriverMSG:
    3.1.15. Do not ask immediately in the forum, if you have not checked anything yourself or attempted self-diagnosis. Remember that advice is given remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and brief description of the fault.
  • #2 17269782
    Pedros050
    Help: 2471
    Rate: 3923
    Hello. Laptop computer? Provide configurations?
  • #3 17269783
    squeze
    Rate: 15
    and safe mode? did you run a black screen or does it load normally?
  • #4 17269804
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    Is it with the cursor only or with an hourglass? Maybe a picture?
    So you lacked patience, or the system got stuck after installing the new Win10 build.
    Do you have another user there?
  • #5 17269813
    mateusz2957
    When I started the safe mode, the same screen resolution has changed and that's it
    The hourglass is shown for a moment when I click ctrl alt dlt. I don't have another user
  • #6 17270890
    jdubowski
    Help: 2511
    Rate: 2804
    Boot from a CD like PCUnlocker and activate the Administrator user. Log in and see what will happen.
  • #7 17273270
    aachi
    Help: 73
    Rate: 46
    I encountered something similar, but I was able to fire the task manager without the left Ctrl + left Shift + Esc shortcut. Later I ran explorer.exe and it fixed itself.
    Alternatively, check the Win + R shortcut and then try explorer.exe to run.
    If it doesn't work, boot the computer from some liveCD and check the SMART disk.
  • #8 17281008
    mateusz2957
    No shortcuts work, just the hourglass and nothing happens
  • #9 17281014
    Pedros050
    Help: 2471
    Rate: 3923
    Provide computer specifications?
The user is experiencing a black screen with a cursor after logging into Windows 10, unable to access the task manager or safe mode. Initial troubleshooting suggestions include checking system configurations, attempting to boot into safe mode, and using a live CD to access the Administrator account. Other users shared similar experiences, recommending running explorer.exe via shortcuts or using a live CD to check the hard drive's SMART status. The user confirmed that no shortcuts are functioning, and the issue persists with only an hourglass appearing momentarily.
