Blue screen, windows 7 - Blue appears when turning on the computer screen
Euroxxx 4755 9
Why does my Windows 7 PC show a blue screen and restart every time I turn it on?
Try uninstalling Avast in Safe Mode and then restart the computer; in this thread, that resolved the blue-screen reboot loop [#16680866] If it still happens, press F8 at startup and disable automatic restart after a crash so you can see and photograph the BSOD error [#16680287] The thread also recommends performing a Clear CMOS and checking RAM with Memtest [#16680782] For Memtest on USB, use the Auto-installer for USB Key version from memtest.org [#16680856]
  • #1 16680234
    Euroxxx
    Rate: 15
    Hi, I need help when I try to start my computer, a blue screen appears and then the computer restarts
  • #2 16680246
    Killlu
    Help: 64
    Rate: 66
    Will you provide full computer specifications, with particular emphasis on the make and model of the power supply, is it a secret?
  • #3 16680270
    Euroxxx
    Rate: 15
    And how should I check it?
  • #4 16680287
    Kasek21
    Help: 4981
    Rate: 3547
    When starting the system, press the F8 key - after the selection options appear, select:
    Disable automatic restart after computer crash.
    Take a picture of this Bluescreen.
    You don't know what components you have in your computer?
  • #5 16680298
    Killlu
    Help: 64
    Rate: 66
    Open the housing and take good-quality photos.
  • #6 16680738
    Euroxxx
    Rate: 15
    Blue screen, windows 7 - Blue appears when turning on the computer screen Blue screen, windows 7 - Blue appears when turning on the computer screen
    I will send pictures of the computer later
  • #7 16680782
    Kasek21
    Help: 4981
    Rate: 3547
    If uninstalling Avast does not help then do the following.
    Perform Clear CMOS.
    Download from here: http://www.memtest.org/#downiso
    Unzip, burn the image to disk, and boot your computer from it. You can also download the version on a pendrive. (two program transitions).
  • #8 16680850
    Euroxxx
    Rate: 15
    And from this site, mamtest.org, what exactly should I download?
    because there is a lot of it
  • #9 16680856
    Kasek21
    Help: 4981
    Rate: 3547
    If the USB stick is the latest version and Download - Auto-installer for USB Key (Win 9x / 2k / xp / 7) * NEW! *.
    Uninstalling Avast didn't help?
  • #10 16680866
    Euroxxx
    Rate: 15
    I uninstalled avast in safe mode and restarted the computer and it works thanks for the help
A user reported encountering a blue screen error upon starting their Windows 7 computer, which subsequently restarts. Forum members requested detailed computer specifications, particularly the power supply model, and suggested pressing F8 during startup to disable automatic restarts after crashes. They advised taking photos of the blue screen for further analysis. One user recommended uninstalling Avast antivirus and performing a Clear CMOS reset. After following these steps, including using a memory testing tool from memtest.org, the original poster confirmed that uninstalling Avast in safe mode resolved the issue.
