Connecting Denon AVR 2113 Receiver to Optoma 27HD Projector for Sound Output
superdeko 12498 18
How do I connect a Denon AVR-2113 receiver to an Optoma HD27 projector so the sound comes from the receiver and not from the projector?
Use HDMI for the picture path to the projector, but do not expect the projector’s HDMI to send audio back to the Denon, because the projector’s HDMI is an input only. If you want audio from the projector itself, the only output mentioned is the 3.5 mm JACK / AUDIO OUT connector, not HDMI [#16721020][#16718980] For a wired home-theater setup, the thread says there is no need to "pull" sound out of the projector; the goal is simply picture on the projector and sound in the home theater [#16725453][#16725731]
  • #1 16716972
    superdeko
    I bought a Denon AVR 2113 receiver and an Optoma 27HD projector.
    How to connect the projector so that the sound comes from the receiver and not from the projector?
    Thank you very much for help.
  • #2 16717139
    chyczak
    Help: 6
    Rate: 23
    The fastest using an HDMI cable. Regards
  • #3 16717235
    superdeko
    OK - which inputs should you use?
    Connecting Denon AVR 2113 Receiver to Optoma 27HD Projector for Sound Output Connecting Denon AVR 2113 Receiver to Optoma 27HD Projector for Sound Output
  • #4 16717405
  • #5 16718952
    superdeko
    I know it can be weird but not everyone understands it. When I connect my computer to a TV there are no markings, only 1 HDMI and everything works. Here I have an HDMI cable connected to input 2 on the projector. In the receiver, I threw it under every channel - but there is never sound, that's why I write.
  • #6 16718980
  • #7 16719012
    superdeko
    so HDMI won't sound?
  • #8 16719114
  • #9 16721020
    superdeko
    I finally got the answer:
    Unfortunately, the HDMI connector on the projector is an HDMI input, so you can't send anything through this connector. You can output audio using the JACK (audio out) connector.
    Pity and thanks for help
    Regards
  • #10 16721318
    Polon_us
    Help: 1184
    Rate: 1282
    Hmm, something's wrong with me ...
    When the computer is connected to the amplifier and the HDMI output on the amplifier to the projector's input:
    - no sound at all?
    - is the sound in the computer speakers?
    - video passes without a problem?
    Having connections as above , please check the audio card settings on your computer, i.e. check that
    which audio device is currently the default device.
    There's a sign there.
    It is advisable that the computer plays a movie at this time.
    Is this computer a "tin" or laptop?
  • #11 16725218
    chyczak
    Help: 6
    Rate: 23
    What is the sound source ?? Does the projector support ARC ??
  • #12 16725434
    superdeko
    hello - I send sound from computers / phones via Chromecast to the projector.
    Sound is currently being output from the projector (built-in speakers)
    I mounted the projector with an HDMI cable - but no sound is made in any setting.
    This answer I got from boys from omawiamy.pl - where they described this projector (youtube)
  • #13 16725453
    Polon_us
    Help: 1184
    Rate: 1282
    Well, there is no need to "pull" the sound out of the projector.
    In particular, if we are talking about a wired connection.
    But if a colleague does not deign to answer the questions asked to solve this problem, well ...
    Only you can wash your hands ...
    Yea ... interesting ... heh ...
  • #14 16725649
    superdeko
    I do not quite get it - so you can send a sound?
    nowhere near connectors does the ARC description appear (also in the projector's manual)
  • #15 16725731
    Polon_us
    Help: 1184
    Rate: 1282
    heh ...
    The goal is to get a picture on the projector and sound in the home theater, right?
    If that's the goal, then there is no need to deliberate over "pulling" the sound out of the projector.
    There are other routes to achieve this effect.
  • #16 16725755
    superdeko
    ok - can you expand what you mean with other options?
    We are talking about a specific projector (Optoma 27 HD) and receiver (Denon AVR 2113)
    Thanks
  • #17 16725785
    Polon_us
    Help: 1184
    Rate: 1282
    I know, I read this topic carefully.
    I could, but to check them you need cooperation.
    I posted an entry (# 10) and I do not see an answer to it so far.
    And some information is necessary to solve this problem.
    But the options I mentioned only apply to wired connections.
  • #18 16733079
    superdeko
    OK - here all data.
    The image is transmitted through Chromecast - only the projector - receiver is connected to the cable.
    - no sound at all? -> Sound is only output from the projector
    - is the sound in the computer speakers? -> NO
    - video passes without a problem? YES
    Sound Card OK - Comp is Laptop.
  • #19 16733617
    Polon_us
    Help: 1184
    Rate: 1282
    Well, I asked a specific question:
    Polon_us wrote:
    Having connections as above, please check the audio card settings in your computer, i.e. check
    I received the answer:
    superdeko wrote:
    Sound card OK
    In such cases, I want to help.
    I do not intend to "get" the exact answer from the author - I wrote about it above.
    I wish you success in solving the problem.
The discussion revolves around connecting a Denon AVR 2113 receiver to an Optoma 27HD projector to ensure sound output from the receiver rather than the projector. Users suggest using an HDMI cable for video and audio transmission, but it is clarified that the HDMI port on the projector is an input only, which does not support audio output. Instead, audio can be routed through the projector's audio out (JACK) connector. Participants emphasize the importance of checking the audio settings on the computer and ensuring the correct audio output device is selected. The conversation highlights the need for proper configuration and understanding of the device connections to achieve the desired audio output.
TL;DR: For this setup, 0 audio returns over HDMI from the Optoma 27HD; “HDMI connector on the projector is an HDMI input.” [Elektroda, superdeko, post #16725434]
Why it matters: If you feed the projector directly, your Denon AVR-2113 won’t get audio; route sources through the AVR first.
Who this is for: Anyone asking how to connect a Denon AVR-2113 to an Optoma 27HD (with Chromecast, PC, or phone) so sound plays on the receiver, not the projector.
How do I wire Denon AVR-2113 to Optoma 27HD so the AVR plays sound?
Connect your sources to the AVR’s HDMI inputs. Run one HDMI cable from the AVR’s HDMI MONITOR OUT to the Optoma’s HDMI IN. Set your source to output audio over HDMI. This path gives picture on the projector and audio on the AVR. [Elektroda, Polon_us, post #16721318]
Does the Optoma 27HD send audio back to the AVR over HDMI (ARC)?
No. The Optoma 27HD’s HDMI is input-only, and users reported no ARC on its connectors or in the manual. Use the projector’s 3.5 mm audio-out only if you must extract analog stereo. [Elektroda, superdeko, post #16725649]
Which HDMI ports should I actually use?
Use the Denon’s HDMI MONITOR OUT to the projector’s HDMI IN. Use any Denon HDMI IN for your sources. Follow the clear OUT/IN labeling to avoid dead audio paths. [Elektroda, 1098678, post #16717405]
Why do I get video but no AVR sound when casting with Chromecast to the projector?
Because the projector is the only HDMI sink in that chain. Audio stays with the projector’s speakers. Route Chromecast into a Denon HDMI input so the AVR decodes audio, then pass video to the projector. “No need to pull the sound out of the projector.” [Elektroda, Polon_us, post #16725453]
Can HDMI from the projector carry sound to the AVR?
No. The projector’s HDMI is not an output. As one reply summarized: “HDMI connector on the projector is an HDMI input.” Use AVR-first routing for sound. [Elektroda, superdeko, post #16725434]
How should I set my laptop’s audio so it plays through the AVR over HDMI?
Open your OS sound settings while a movie plays. Set the default playback device to your HDMI/AVR. This avoids audio staying on laptop speakers and ensures the AVR receives the stream. [Elektroda, Polon_us, post #16721318]
What does the projector’s ‘audio out (jack)’ actually give me?
It outputs analog audio derived from the HDMI input, suitable for powered speakers or an AVR’s analog input. Expect stereo, not surround formats. It’s a fallback if you can’t route through the AVR. [Elektroda, superdeko, post #16721020]
I still have no sound—what quick checks should I run?
Confirm the source’s default audio device is HDMI/AVR. Select the correct HDMI input on the Denon. Try another HDMI cable/port. Keep the source → AVR → projector chain; bypassing it strands audio at the projector. [Elektroda, Polon_us, post #16721318]
Does the Optoma 27HD support ARC at all?
Users found no ARC labeling on the chassis or in the manual, so plan as if ARC is unsupported. Run sources into the Denon to handle audio properly. [Elektroda, superdeko, post #16725649]
How do I connect Chromecast so the AVR decodes audio?
  1. Plug Chromecast into a Denon AVR-2113 HDMI input.
  2. Connect Denon HDMI MONITOR OUT to Optoma 27HD HDMI IN.
  3. Select that HDMI input on the Denon; cast content. This yields AVR audio and projector video. [Elektroda, superdeko, post #16725434]
Why does everyone say not to “pull” audio from the projector?
Because the clean signal path is source → AVR for decoding, then video → projector. As one expert put it, “no need to ‘pull’ the sound out of the projector,” especially with wired connections. [Elektroda, Polon_us, post #16725453]
Will the projector’s audio-out give me surround sound on the Denon?
No. A 3.5 mm analog output carries two-channel audio. Connect sources to the AVR over HDMI to decode multichannel formats correctly and avoid quality loss. [Elektroda, superdeko, post #16721020]
