Transferring Video Signal from Panasonic TV to ACER H6510BD Projector via DENON AVR-X520BT Receiver
jacacom11 13377 6
  • SCART-to-HDMI converter may enable projector output
    #1 16926061
    jacacom11
    For me, the situation looks like this. I have an old Panasonic plasma TV with two HDMI outputs and two SCART. One SCART output has the ability to send image to such devices as "video recorder". I have a DENON AVR-X520BT receiver and an ACER H6510BD projector. I tried to connect the TV to the amp via the SCART output to the VIDEO input, then through the HDMI output from the amp to the projector but unfortunately no effect. When I connected the TV directly to the projector to the VIDEO input, the image was transmitted. Which may be the reason why the receiver is not transmitting the image to the projector. After HDMI to the projector?
    If I buy a device of this type, for example
    https://pl.aliexpress.com/item/1080-P-Ekskluz...ZORA-HD-DVD-dla-Sky-Box/32831696330.html?spm= a2g17.search0104.3.22.c13L1j & ws_ab_test = searchweb0_0 2Csearchweb201602_1_5130011_10152_10151_10065_10344_10068_10342_10343_51102_10340_10341_5000011_10084_10083_10304_10307_10301_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_10142_5060011%%% 2Csearchweb201603_6 2CppcSwitch_5 & algo_expid = 8d0f568a-39f2-4d14-9f2c-755534892bf9-3 & algo_pvid = 8d0f568a-39f2-4d14-9f2c-755534892bf9 & rmStoreLevelAB = 5
    or this type
    https://pl.aliexpress.com/item/Mini-SCART-to-...Adapter-1080P-HD-TV-USB/32818796549.html?spm= a2g17.search0104.3.74.c13L1j & ws_ab_test = searchweb0_0, searchweb201602_1_5130011_10152_10151_10065_10344_10068_10342_10343_51102_10340_10341_5000011_10084_10083_10304_10307_10301_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_10142_5060011, searchweb201603_6, ppcSwitch_5 & algo_expid = 8d0f568a-39f2-4d14-9f2c-755534892bf9-10 & algo_pvid = 8d0f568a-39f2-4d14-9f2c- 755534892bf9 & rmStoreLevelAB = 5
    it will be a chance that the image will be sent from the SCART output to the SCART to HDMI converter
  • #2 16927434
    arturdip
    Help: 170
    Rate: 324
    Unfortunately, most often in receivers it is just an entrance
  • #3 16927482
    jacacom11
    Yes, but according to Denon instructions, this input is used to connect an external device, e.g. Turner TV. The receiver sends a signal via HDMI to e.g. a TV or projector.
    I want to send a signal from the TV to the amp and then HDMI to the projector.
    If I connect the TV directly to the scart projector -> VIDEO, the signal is sent. And through the Scart amp (TV) -> VODEO IN (receiver) -> HDMI Out (receiver) it does not reach the projector. What's the problem.
  • #4 16927500
    KOCUREK1970
    Help: 3863
    Rate: 5493
    First make sure you have any OUTPUT audio / video signal on this TV for EURO.
    How is the problem - there is no communication between the analog ports in the cinema and the HDMI digital port. There is no communication because it cannot be.
  • #5 16927525
    jacacom11
    The signal as it is because as I wrote scart before, the Video gives the image.
    Good if the analog input in the receiver does not communicate with the digital HDMI, whether through this device http://sklepwideo.pl/converter_scart-hdmi_snavs2h03 after connecting SCART TV with any HDMI input in the amp, the signal will be sent to the HDMI output in the amp to the projector.
  • #6 16927682
    KOCUREK1970
    Help: 3863
    Rate: 5493
    But in direct connection and through an analog connection.
    jacacom11 wrote:
    through this device
    Buy and see - nobody guarantees you that it will work remotely.
  • #7 16927696
    jacacom11
    I am asking because maybe someone had experience with this device.
    Maybe someone had a similar problem and somehow managed something different than the one I propose.
The discussion revolves around the challenge of transferring a video signal from a Panasonic plasma TV to an ACER H6510BD projector via a DENON AVR-X520BT receiver. The user has attempted to connect the TV to the receiver using a SCART output to the receiver's VIDEO input, then HDMI output to the projector, but this setup fails to transmit the image. Direct connection from the TV to the projector works, indicating a potential issue with the receiver's ability to handle the analog-to-digital signal conversion. Suggestions include ensuring the TV outputs a compatible signal and considering the purchase of a SCART to HDMI converter to facilitate the connection through the receiver. However, there are concerns about the reliability of such converters.
