Using Galletto v54 for OPEL ECU Flashing: BDM vs External Connector
Pascalt 15120 17
Can Galletto v54 flash an Opel ECU through the external connector, or is BDM/opening the housing required?
Galletto v54 can work through the external connector/OBD on supported Opel ECUs, so BDM/opening the housing is not always necessary [#16718961][#16720939] The exact method depends on the car and ECU version; for example, Astra G 1.7 Isuzu was said to work after the flash connector, and HSFI 2.1 with x16xel was also said to be doable [#16718961][#16719606] One reply describes bench use as being like OBD: apply power and K-line and operate it that way [#16720939] The thread also warns that original Galletto has poor technical support, so compatibility is the main limitation [#16719528]
  • #1 16717063
    Pascalt
    Help: 9
    Rate: 143
    I'm planning to buy Galletto v54 (of course the original).
    Will the title be on the table?
    Is BDM = the only way to open the housing, will it work through the external connector?
    Thank you in advance for your answer,
    Best regards!
    bodzio012
    Help: 161
    Rate: 780
    Depends on which year of the car? If the astra G with 1.7 isuzu then after the flash connector will go.
    tomasz0703
    Help: 69
    Rate: 489
    What car what delco x16xel z16xel z16xe mt35e etc. what do you want to do specifically?
  • #4 16719504
    Pascalt
    Help: 9
    Rate: 143
    Thank you. HSFI 2.1 with x16xel I would like to agree with HSFI 2.1 from an engine of unknown origin.
    adrian1201
    Help: 128
    Rate: 416
    Galetto in ori is a failure of a large subscription and basically zero support.
    adam7009
    Help: 656
    Rate: 1635
    will do the trick.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
    daras41
    Help: 57
    Rate: 315
    Kess will also embrace the table and the joint.
  • #8 16720809
    Pascalt
    Help: 9
    Rate: 143
    Thanks for the quick help. However, I am a bit more inclined towards Galletto - it more coincides with my needs, and since I am spending a lot of money, it is better to do it once.
    Galletto, I understand the topic, but after OBD ...? And you will have to simulate a bit on the table? Am I right?
    In another forum I found a piece of documentation from Galletto and there was no mention about the Opel HSFI ... there was no written pinology - hence the conclusion, I do not know whether it is right that only after OBD ... and here would be the only minus Galletto.
    adam7009
    Help: 656
    Rate: 1635
    On the table like after obd, power and K and you act.
  • #10 17085823
    Pascalt
    Help: 9
    Rate: 143
    Welcome back...
    I operate Galletto ... potentially very nice device, but no technical support.
    I flashed Galletto, then cloned with Carprog and the car did not start (HSFI driver - 2.1) - it fired on the original. The second driver (target) is operational.
    The most effective would be to program the controller after SPS, unfortunately I do not have access to this equipment yet and I wonder if using K-tag or Galletto has the right to work flipped between controllers ... Does anyone have such successful attempts behind Simtec controllers or Delco.
    Unfortunately, I failed ...
    I'm not asking here about immo - that's another story as you know.
    Anyone got any idea?
    Can someone help me with a hint?
  • #11 17103538
    piotrekwoj1
    Help: 947
    Rate: 3433
    Carprog original or clone?
  • #12 17103854
    melas
    Help: 138
    Rate: 689
    I just moved the carprog data and password without flashing. Car original of course.
  • #13 17103973
    Pascalt
    Help: 9
    Rate: 143
    And what does it matter if I ask? Carprog is not used for flashing. Ie. if the engines are different, they will not agree on the software version. I am afraid of Chinese ...
    daro30elektro
    Help: 8
    Rate: 30
    Welcome back...
    You can easily copy the clone yourself with a Kess in the car or on the table, and all you need is CP to read the Pin and reset or upload the eeprom. Then with OpCom in the immo module you add the engine driver and the case :) As for Tech2 and SPS, after the VIN you will only update the driver software but the security will be old.
  • #15 17155149
    Pascalt
    Help: 9
    Rate: 143
    Thanks for the answer. I tried to transfer Galleto, there was a checksum error. Of course, later I was going to transfer CP the rest I needed. That was in Simtec 71. I will try Kessem again.
    daro30elektro, are you aware of the car's configuration data in the part of the flash that Galletto embraces?
    daro30elektro
    Help: 8
    Rate: 30
    Kess when loading Delco HSFI immediately counts checksums Galeciak comes out that no. What to Simtec 71 is neither Galleto, nor Kess, MPPS, Flash TEC, etc. do not read the full content of the flash from Simtec71 (only 24kB) only IO Terminal (512kB ).
    Added after 7 [minutes]:
    If your question was related to Simtec71, so in Flash there is a memory area reserved for the so-called emulated eeprom where the configuration data (PIN, VIN, mileage, equipment variants, etc.) are saved. In summary, if you lose the whole flash (size 512kB ) then you have a cloned driver 1 to 1. Unfortunately you won't do it Galleto, Kess, MPPS, Flash TEC, ITP.
  • #17 17156283
    Pascalt
    Help: 9
    Rate: 143
    In that case, I understand that Kess + CP also will not do the whole Simtec 71 1: 1?
  • #18 17673095
    ireneusz1981
    Level 19  
    Help: 26
    Rate: 82
    I think only SPS after vin number.
    I had Meriva in a slot machine. The engine driver fell and it was good that it was repaired because in the meantime we put and coded drivers with the same names but from the manual and Meriva did not drive. That's how it is with these hybrid drivers. I don't know the way. Even PSG16 write that it is possible to clone but neither mpps nor anything that does not move. Only sps under vin and it's ok.
The discussion revolves around the use of the Galletto v54 for ECU flashing in OPEL vehicles, specifically addressing the methods of BDM (Background Debug Mode) versus using an external connector. Users inquire about the compatibility of Galletto with various OPEL models, including HSFI 2.1 and Simtec controllers. Concerns are raised regarding the lack of technical support for Galletto, with some users reporting issues such as checksum errors and unsuccessful cloning attempts with Carprog. The consensus suggests that while Galletto can be effective, it may require additional steps like using K-tag or SPS for optimal results, especially when dealing with configuration data and cloning between controllers.
TL;DR: For Opel ECUs, Simtec71 needs a full 512 kB read, and “Kess immediately counts checksums.” Use bench power + K-line or OBD; BDM isn’t always required. [Elektroda, daro30elektro, post #17155569]
Why it matters: This FAQ helps DIY tuners choose the right tool and connection method to avoid no-starts and checksum errors when flashing Opel ECUs.
Is BDM the only way to program Opel ECUs with Galletto v54?
No. For many Opel ECUs you can flash through the external connector or on the bench. Provide power and K‑line like OBD. BDM is not mandatory unless the ECU or situation requires it. “On the table like after OBD, power and K and you act.” [Elektroda, adam7009, post #16720939]
Can I flash an Astra G 1.7 Isuzu ECU through the external port?
Yes. Users confirm the Astra G 1.7 Isuzu accepts flashing via the external connector. This avoids opening the ECU. Always ensure stable voltage and correct pinout before writing. [Elektroda, bodzio012, post #16718961]
Will Galletto handle HSFI 2.1 cloning without issues?
Not reliably. One user reported a no‑start after flashing and cloning HSFI 2.1, while the original ECU ran fine. Consider checksum handling and security pairing before swapping. [Elektroda, Pascalt, post #17085823]
Does Kess solve checksum errors on Delco HSFI?
Yes. Kess recalculates checksums automatically when loading Delco HSFI, which prevents common write‑time failures. Some Galletto setups do not handle these checksums. [Elektroda, daro30elektro, post #17155569]
What tool reads Simtec71 full content for a 1:1 clone?
IO Terminal. Popular tools like Galletto, Kess, MPPS, and Flashtec read only about 24 kB, but Simtec71 requires a full 512 kB flash for a true clone. [Elektroda, daro30elektro, post #17155569]
Is SPS by VIN enough to swap ECUs securely?
SPS updates software based on VIN but preserves existing security. You must still handle PIN/immobilizer pairing separately to start the car. [Elektroda, daro30elektro, post #17153494]
How do I bench‑flash an Opel ECU safely?
  1. Provide a stable bench supply and wire power, ground, and K‑line like OBD.
  2. Connect your tool (e.g., Kess/Galletto) and identify ECU.
  3. Read backup, then write calibrated file and verify. [Elektroda, adam7009, post #16720939]
What caused my checksum error with Galletto on Simtec71?
Simtec71 requires correct checksum handling and full 512 kB coverage. Galletto may not recalc checksums or read the entire image, causing write errors. “Kess immediately counts checksums.” [Elektroda, daro30elektro, post #17155569]
Can I clone HSFI/Delco on the car without opening the ECU?
Yes. You can copy on the car or bench with Kess, then use CarProg (PIN) and OP‑COM to adapt immobilizer. This avoids ECU opening in many cases. [Elektroda, daro30elektro, post #17153494]
What is BDM in ECU work?
BDM (Background Debug Mode) is a direct microcontroller interface used to read/write ECU memory on the bench. It’s helpful when OBD or K‑line access is limited, but many Opel tasks work via external connector. [Elektroda, adam7009, post #16720939]
What is the K‑line?
The K‑line is a single‑wire diagnostic communication line used by older ECUs. On the bench, you mimic OBD by powering the ECU and connecting the K‑line to your flasher. [Elektroda, adam7009, post #16720939]
Why did my cloned ECU start on the bench but not in the car?
Security mismatches can block starts. After cloning, read the PIN with CarProg and pair the ECU in the immobilizer module using OP‑COM. SPS alone won’t fix security. [Elektroda, daro30elektro, post #17153494]
What is Simtec71, and why is it tricky?
Simtec71 is a Siemens ECU used in Opel gasoline engines. It stores config in emulated EEPROM inside the 512 kB flash. Partial 24 kB reads miss this, blocking 1:1 cloning. [Elektroda, daro30elektro, post #17155569]
Edge case: Why did a Meriva not drive after swapping ‘same‑name’ ECUs?
Hybrid ECUs can look identical but differ by transmission. Swapping a manual version into an automatic Meriva prevented driving. Always match by VIN and transmission. [Elektroda, ireneusz1981, post #17673095]
Will CarProg alone clone the ECU firmware?
No. CarProg is used here for PIN reading and EEPROM tasks. Use a flasher (Kess, etc.) for maps/flash, then adapt security with OP‑COM. [Elektroda, daro30elektro, post #17153494]
I have HSFI 2.1 x16xel. Can I pair it with an unknown donor ECU?
Yes, with the right process. Flash compatible software, ensure checksums, read PIN from donor, reset/adapt immobilizer, and then learn it with OP‑COM. [Elektroda, daro30elektro, post #17153494]
