ECM Program: Seeking Software for Modifying Engine ECU Maps & Driver Map Adjustments
yamahar1 59805 7
  • #1 10224241
    yamahar1
    Hello, I am looking for a program called ecm that can modify engine driver maps, is there anyone who can help
  • #2 10226016
    decybel91
    Help: 1024
    Rate: 4231
    ECM stands for engine control module, so I don't know what program you are looking for.
  • #3 10230536
    yamahar1
    Supposedly MAXBOX, but I don't know exactly
  • #4 10230788
    decybel91
    Help: 1024
    Rate: 4231
    Supposedly unicorns live beyond the Urals and what is the result of this?
    Say specifically what you want to do and what you need.
  • #5 10236772
    yamahar1
    As you would notice it in the first post, I wrote what I want to do, I need a program that goes to convert mape ecu and winols is quite difficult I heard that there are others easier to understand
  • #6 10236838
    wiciu
    Rate: 16
    Winsol is not difficult, editing maps is not easy. A colleague above rightly asked what you want to do, if you want to bury yourself, winhex is freeware and you will mess with it. Anyway, I don't know of any ECU batch editing freeware.
    Regards
    P.
  • #7 10487755
    gregorianin
    Help: 44
    Rate: 294
    In fact, the only significant (commercial) software to edit is http://www.evc.de/en/default.asp or https://www.vcpowerteam.com/, while working on both, I am definitely going to buy the first one.
  • #8 16523783
    mattai
    Colleagues write about modifications to the ecu. Is there any (inexpensive) application / interface with which it will be possible, for example, to edit the air conditioning function (addition). I have an op-com, but unfortunately I do not have access to such things there. Opel is reluctant to do this work, and they probably do not know how to do it. I don't have CAN yet.
The discussion revolves around finding software to modify engine ECU maps, specifically for driver map adjustments. The original poster seeks an easier alternative to WinOLS for ECU mapping. Responses suggest various software options, including MAXBOX and commercial solutions from EVC and VCPowerteam. There is also mention of WinHex as a freeware option, though it may be complex for beginners. Additionally, a user inquires about inexpensive applications for modifying specific functions, such as air conditioning, using an OP-COM interface, highlighting the challenges faced with OEM support for such modifications.
