Opel Corsa D 2014r 1.4 XER 100 HP - ECM Scheme, P0651-00, P0807-00, P0557-00, C0236-71, U2107-71
brylant238 13593 5
  • #1 16721358
    brylant238
    Rate: 44
    Hello, I need the 1.4 XER 100 HP engine installation diagram
    In the car there is a problem with the power supply, from which the ECM pin is 5V on the clutch sensor, etc.
    ECM
    P0651-00 5V Reference 2 Circuit
    P0807-00 Cluutch Pedal Position CPP Sensor Circuit LOV Voltage
    P0557-00 Breake Booster presure Sensor Circuit lov Voltage
    ABS
    C0236-71 Invlid Data from ECM (Engine Control Module)
    IPC
    U2107-71 Invalid Data from BCM (Body Control Module
  • #2 16721449
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    Hello - A14xer diagram. Regards Opel Corsa D 2014r 1.4 XER 100 HP - ECM Scheme, P0651-00, P0807-00, P0557-00, C0236-71, U2107-71 Opel Corsa D 2014r 1.4 XER 100 HP - ECM Scheme, P0651-00, P0807-00, P0557-00, C0236-71, U2107-71
  • #3 16721631
    brylant238
    Rate: 44
    Gentlemen, you need a description of B30, b28, etc ..
  • #4 16721795
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    Schematic description ... Regards
    • opisA14xer.txt (898 Bytes) You must be logged in to download this attachment.
  • #5 16721893
    brylant238
    Rate: 44
    This is a diagram for a computer with two plugs, I have 3 plugins
    Delco 12643636
  • #6 16723044
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    There were no more :) Best regards .
    • A14xerGMPT-E78.zip (183.56 KB) You must be logged in to download this attachment.
