Opel Corsa D 1,2 16v 2006: Engine Jerking & Shutting Off, Fault Codes p0171, p0068, p2188
konrad1983daniel 10410 4
  • #1 16297560
    konrad1983daniel
    Rate: 24
    Errors from the photo usually appear after 3 -4 starts and the engine has warmed up, after their appearance the engine begins to jerk and even goes out, then there is a problem with starting. it fires up after the third attempts. Please help.
  • #2 16306301
    rafcio_21
    Help: 137
    Rate: 295
    Check the lambda probe and throttle.
  • #3 16346467
    konrad1983daniel
    Rate: 24
    new probe after replacement and still the same and the corsa has a mileage of 37000km we have it new
  • #4 16346835
    voyytas
    Help: 8
    Rate: 30
    Recently, I did the probe so much that in Vectra B. The mechanic told me that in this matter Opel does not digest substitutes - did you replace it with the original probe?
  • #5 16346876
    mario 77
    Help: 66
    Rate: 335
    Write what MAP shows after ignition and at idle.
