Charging Alcatel OneTouch PIXI 3 with Damaged USB: Alternatives and Potential Risks
mastachu 6156 7
  • #1 16723189
    mastachu
    Rate: 20
    I have an Alcatel OneTouch PIXI 3 tablet. I have a damaged USB port, which means that it cannot be charged. As he moves the cable, from time to time, information pops up that he is loading. I can't move the cable like that for the whole 4-5 hours. I opened the reptile and this is what I found. Charging Alcatel OneTouch PIXI 3 with Damaged USB: Alternatives and Potential Risks
    1. Three cables: + red, - black, white I don't know what for.
    2. Two 3.8 V and 2050 mAh batteries.
    Can I connect plus connected 3x 1.2 V batteries and something mAh?
    Serially they will have 3.6 V. I would charge them first! That's an idea because I don't know how I can charge it differently! Will it work after connecting a 5V charger from NOKII to these cables? (In the charger which is + and which is -? Charger with round tip).
    Please help!!!!! I am asking for professional advice, will it work or will I not destroy anything ?!
  • #3 16723239
    mastachu
    Rate: 20
    I prefer not to risk with a soldering iron. There are also such ribbons: how to disconnect them? Write or provide a link to the demonstration video, please. Maybe I'll try to do something.
    gradek83
    Help: 929
    Rate: 2099
    If you are afraid to do anything, give it to the service
    Or buy yourself the LI-ION TP4056 Battery Charger and charge through this system.
    Of course, you'll have to stuff it somehow into the housing or lead the cables out, but it's only for charging the tablet's contact with the PC rather through the original socket, no different.
    Either way, I bet you give it to the service or give it to someone who knows about it.
  • #5 16723429
    mastachu
    Rate: 20
    OK And after describing the damage, what else can I do? Before I give it to a service technician. And how much can such repair cost? Thanks for the hints.
  • #6 16723701
    gradek83
    Help: 929
    Rate: 2099
    The cost of the item, unless you have to replace it plus labor on the site should tell you how much they call for it.
  • #7 16753615
    mastachu
    Rate: 20
    Today the charger was connected to the tablet, yesterday came mail. Loading from 12:05 and at 17:15 there were 87%. I connected it to the cables going to the battery and NOW. Soon photo from repair.
  • #8 16755366
    mastachu
    Rate: 20
    Here is the repair photo
    https://obrazki.elektroda.pl/1855010700_1507915217.jpg
    Added after 2 [hours] 48 [minutes]:
    Cables soldered to the + and - power cables, flooded with hot glue and a piece of the housing cut out to fit everything. LI-ION TP4056 battery charger glued to the housing with hot glue (great invention). USB charger from NOKIA 5V phone and guitar. On an activated tablet it does not show charging, as it is almost discharged at 3 or 2% it does not show anyway. But when I turn it off / on it is only 87%, the charger with red net is blue.
✨ The discussion revolves around charging an Alcatel OneTouch PIXI 3 tablet with a damaged USB port. The user initially inquires about alternatives to charge the device, considering connecting three 1.2V batteries in series to achieve a total of 3.6V. Responses suggest either replacing the damaged USB socket or using a LI-ION TP4056 battery charger for a safer charging method. The user expresses reluctance to solder and seeks professional advice. Eventually, the user successfully connects a charger to the battery cables, achieving partial charging, although the tablet does not indicate charging status when powered on. The repair involved soldering cables to the power lines and using hot glue to secure components.
