Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection
SphunaR 9402 6
  • #1 16375621
    SphunaR
    Rate: 8
    Hello!
    I have a tablet Samsung Galaxy Tab 3 10.1 P5210.
    The problem with it is that it doesn't charge the battery when connected to a charger.
    It started when the tablet turned off. It could not be started, only download mode started. When connected to a computer, "USB device not recognized" appeared. After some time it stopped turning on and download mode.
    Due to the lack of a suitable charger, I bought a new battery. After connecting, everything works okay, but unfortunately it still doesn't load and the computer does NOT detect it at all.
    What surprises me - after peeling off the tape with which the tapes are attached, a piece of what presses the socket has broken off.
    Illustrating this is exactly about such a fragment as what is marked in the picture:
    When turning, I corrected it and stuck it with tape. But maybe this is the reason for the fault?
  • #2 16376310
    Robert 1960
    Level 32  
    Help: 238
    Rate: 408
    Hello, start by checking the socket itself, there is the most common reason for not charging and not detecting by the PC
    P.U.T. DOMSAT
    Ignacego Rzeckiego 4/39, Lublin, 20-637 | Tel.: 697XXXXXX (Show)
  • #3 16376499
    SphunaR
    Rate: 8
    Could you tell me how to do this?
    So despite the fact that the tape has pins from above (i.e. where the hook is broken), this may not be the reason?
  • #4 16376520
    Robert 1960
    Level 32  
    Help: 238
    Rate: 408
    Visually check the charging socket, if it is accidentally pulled out of the plate, measure the voltage on the socket after connecting the charger, then for starters - take a picture of the plate with the socket
    P.U.T. DOMSAT
  • #5 16377512
    SphunaR
    Rate: 8
    Photos:
    Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection Charging Issue with Samsung Galaxy Tab 3 10.1 P5210: Battery Replacement and USB Detection
    As you can see the whole USB port is greenish - tarnished. I tried to clean it - but no changes.
    The socket at the disc is ok - apart from what I wrote in the first post - a piece of what presses the pins from the tape is torn off.
    You can see in the pictures this piece in the middle of the tape.
    When I get home I will measure the tension.
    Robert 1960
    Level 32  
    Help: 238
    Rate: 408
    There is nothing to measure here, you need to thoroughly clean the socket, because without it there will be nothing!
    P.U.T. DOMSAT
  • #7 16380706
    SphunaR
    Rate: 8
    Thank you very much for your help!
    Cleaning the socket did nothing. Although it looked like new, everything was beautiful, it did not work.
    I bought new, replaced and works without a problem.
The discussion revolves around a charging issue with the Samsung Galaxy Tab 3 10.1 P5210, where the tablet fails to charge and is not recognized by a computer. The problem began after the tablet turned off and could only enter download mode. The user replaced the battery but still faced charging issues. Responses suggest checking the charging socket for damage, cleaning it, and measuring voltage. The user later discovered that the USB port was tarnished and, despite cleaning efforts, the issue persisted until a new USB port was installed, which resolved the problem.
