Alcatel Pixi 7 Tablet Not Turning On, Battery Check and Button Combinations Tried
kusiu2 7821 3
  • #1 16200066
    kusiu2
    Hi
    Recently, I got a malfunctioning Alcatel pixi 7 tablet (it was once added in orange as a free contract).
    The tablet does not turn on and does not respond to any button combinations.
    I thought the cause could be a battery (the tablet has been unused for over a year).
    I checked it and removed it from the device had a voltage slightly exceeding 2V, after charging with a charger to 18650 it is 4.15V.
    The tablet only reacts when connected to a computer (the computer makes a sound of connecting a new device and after 2 seconds of disconnection, the tablet displays nothing).
    I have no idea what might be broken.
    I will be grateful for all suggestions.
  • #2 16240659
    karol1977
    Rate: 107
    Hello kusiu2 - how did you deal with the problem because I have similar symptoms?
  • #3 16241589
    Freddy
    Help: 1394
    Rate: 2821
    After a very long period of non-use, you need to start with a "solid" charge of the batteries.
    Turn on the tablet to charge it for at least a few hours.
  • #4 16486078
    kusiu2
    The battery was good.
    I powered the tablet with an adapter with the same adapter as the battery and still nothing.
    I gave up repairing this device.
