2004 Jeep Liberty KJ 3.7 Petrol - Starter Motor Not Spinning, Ignition Voltage & BCM Issue
tomkolp 6840 2
  • Starter relay bypass confirms BCM control issue
    #1 16723742
    tomkolp
    Hello, as in the topic of Jeep Liberty KJ 2004 3.7 petrol. The starter does not turn when you try to fire. Voltage comes out of the ignition switch. If I make a jumper in the relay from the starter, it turns. The parameters in the body control module show the position of the P / N gearbox and the brake applied. There is no immo (skim) installed in the car, there is only a factory alarm. There is an acoustic signal when closing and the directions blink once, when opening no acoustic signal the directions blink twice. There are no bugs anywhere. Tcm driver integrated with bcm. Maybe I will help someone with the diagram because I found only until 2003 and there is tcm separately.
    Laptopy Tomasz Rekusz
    Jastrzębce 4, Środa Śląska, 55-300 | Tel.: 793XXXXXX (Show) | Company Website: http://laptopy.srodaslaska.eu/
  • #2 16724484
    vogelek1
    Help: 36
    Rate: 114
    Fast to all, these are all reasons why the starter does not spin, there are several dozen and the main ones are 20, and I suggest checking the voltage and going "from the back, i.e. installing the relay and checking the pins one by one, and if you do not want to, a new wire from the ignition switch - relay . and HEEEJJJJJIIAAAA: -0))
  • #3 16725511
    tomkolp
    Got a schematic and found a aftermarket ignition cut-off.
