The starter does not spin, only the starter relay, Renault Megane Class
Rafal12336 19038 5
  • #1 16182653
    Rafal12336
    Rate: 8
    Hello, I am new here so I apologize in advance for any mistakes.
    I have a problem with my Renault Megane classic from 1997, r 1.6 gas with gas. I have looked at similar posts here but none of them were helpful enough. Namely: on Friday night after visiting the girl I wanted to start the car, and here nothing, the starter did not even wind up, I only heard some ticking (I suspect it was a bendix) outside it was -15 ° so I thought maybe the battery, but after "borrow "There's nothing more from the mother-in-law's car. I went back and returned to my car the next day with my brother. We hit the starter that it may have hung up (I used to have this problem and replaced the starter with used and there were no problems), there was another attempt to fire on the cables and nothing else, the starter did not even turn off, just listen was "tipping" from the relay in the box with safety guards. In the end, he turned on the fast, but during the ride he turned off the control from the temperature of the refrigerator. We lit up again and somehow we got home, the car worked a long time and the battery recharged, but after some time the car went out and the same again, it does NOT smoke, the starter does not even start to be heard in the relay. I will add that I have replaced such a relay and still nothing, the fuses in the box under the hood are good, the battery also, so what can it be?
    Previously, I had only a starter, as I knew, but after the exchange there were no problems, and suddenly there was no cold in the night, and then he did not light up, even when heated, as if the electricity was cut off somewhere.
    I am asking for some advice because I can not with this car anymore. greetings :)
    manta
    Help: 463
    Rate: 1533
    Check the ground connections, you have a fuse on the main cable to the battery. How did you say that the battery is charged?
  • #3 16182829
    Rafal12336
    Rate: 8
    I checked the fuses on the cable, they are okay, and I bought from my friend not long ago, I was checked by a meter under load, I tried to run on cables and checked this "lamp" on aku and it was green. Wgl radio plays normally and wgl, and as I rode him after firing on the prop, I should theoretically be able to follow
  • #4 16182833
    g107r
    Help: 811
    Rate: 993
    Can you start the starter motor for a short time without a machine?
    If you have a battery dead, it can pass the target on the wires, it's better to replace the battery with a good one. Cables from the market are usually only suitable for recharging the battery.
    Loading check.
    The combination of mass, minus aku on the starter, i.e. motor / box.
  • #5 16182842
    manta
    Help: 463
    Rate: 1533
    As far as you're charging.
  • #6 16182864
    Rafal12336
    Rate: 8
    Ok, in a moment I will replace aku and let me know what and how :)
    Added after 1 [hour] 23 [minutes]:
    Gentlemen, the problem is solved. It turned out accidentally that the cable from the mass (not the one from the aku to the stall only some other one) was completely broken. I reassembled and the car burns nice :D Thank you for your help, the topic is over.
