Best Power Generator for 230V: House Renovation, 12V Installation, TV, Radiator, Up to PLN 600
Dawidoxxxxv 7641 6
  • Need to size generator for renovation tools
    #1 16724567
    Dawidoxxxxv
    Rate: 11
    Welcome
    I need a power generator for a plot where I don't have electricity. I have a house and 12v installation (for now, about 15 Watt for the light only). I want to run the 230V installation for some TV, radiator etc. I will be doing renovation soon and need a generator (up to PLN 600)
    As renovation is known, tools need more Watt, but then it is only light, laptop, fridge, etc. What power should the aggregate buy (how much Watt should the generator give) so that it will have enough tools? Only without texts like "you won't buy for this price". I just want the cheapest unit because it's just a summer house and I don't see the point in spending a lot of money.
  • #2 16724660
    Qbuś
    Help: 380
    Rate: 876
    I just want the cheapest aggregate
    Then buy the cheapest, what is your problem?
  • #3 16724670
    Dawidoxxxxv
    Rate: 11
    With the fact that I do not know what power I should look for the generator
  • #4 16724764
    Qbuś
    Help: 380
    Rate: 876
    That it will be enough for the "most powerful" power tool you will use.
  • #5 16724784
    Dawidoxxxxv
    Rate: 11
    Ok and then the second issue - how would he want to connect to the aggregate, for example, a laptop, TV, thermostat must have AVR? Looking at prices up to PLN 580 they don't have AVR
  • #6 16725239
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    Take a look from September 28 at OBI big promotions 200A Stanley inverter welder with a self-seeding mask at a price of PLN 569 where the mask of this manufacturer alone is PLN 200. Also on sale is a 2000W Hyundai power generator at PLN 669 with built-in AVR. the 2500W company itself is slightly more expensive.
    Added after 7 [minutes]:
    Promotions at OBI for a number of items take place from September 28 to October 11.
  • #7 16726298
    Dawidoxxxxv
    Rate: 11
    Thanks, I'm closing the topic
The discussion revolves around selecting a power generator for a summer house renovation, specifically for running 230V appliances like a TV and radiator, while also accommodating a 12V installation for lighting. The user seeks a budget-friendly option under PLN 600 and inquires about the necessary wattage for the generator to support various tools and devices. Responses suggest considering the wattage requirements of the most powerful tools to be used and highlight the importance of AVR (Automatic Voltage Regulation) for sensitive electronics. A recommendation includes checking promotions at OBI for specific models, such as a 2000W Hyundai generator with built-in AVR priced at PLN 669 and a 200A Stanley inverter welder at PLN 569.
