Best Power Generator Under PLN 1,000: Chinese vs Loncin Engine Models for Construction Use
malimaro 13392 9
Which generator under PLN 1,000 is suitable for construction work, and is a Loncin-engine model better than a generic Chinese one?
Cheap generators are a bit of a lottery: the engine is not necessarily the weakest part, and the generator head, accessories, and technical specs can matter more [#17149373] For the loads mentioned in the thread, one estimate was about 2500–3000 W if you want to run a concrete mixer, drill, grinder, or 2–3 devices at once, but another reply warned that you should account for starting current and said the minimum should be 5 kW [#17156880][#17157081][#17158311] The practical advice is to choose the generator based on the real tools you will power and their startup surge, not just on whether it has a Loncin engine [#17156676][#17156880][#17158311]
  • #1 17147119
    malimaro
    Rate: 159
    Hello, maybe someone knows this better and can advise. I am looking for a generator of up to PLN 1000 for construction, my friends had a Chinese for PLN 700 and they have been working for several years, I don't know how much was used. I know that these cheap Chinese people are worth nothing and sit down very quickly. Maybe someone knows the subject? from cheap someone recommended me with a loncil engine because they have steel cylinder liners.
    • Best Power Generator Under PLN 1,000: Chinese vs Loncin Engine Models for Construction Use usun.jpg (246.18 KB) You must be logged in to download this attachment.
  • #2 17148666
    malimaro
    Rate: 159
    Nobody Nothing On this topic
  • #3 17149373
    taivun
    Rate: 26
    The truth is that quinol is a lottery, one goes a few years, others a few days, the engines are not the worst, worse with a generator, accessories or inflatable technical data ...
  • #4 17156652
    malimaro
    Rate: 159
    I wonder between the kruzer and Yato, for me the kruzer is a brand I don't know and Yato has already met and I can't say a bad word
  • #5 17156676
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    What is he supposed to power this generator?
  • #6 17156880
    malimaro
    Rate: 159
    I don't know a concrete mixer for 220 volts, but probably up to 1000w and a drill 800w or grinder up to 1000w etc. Maybe e.g. glue mixer, 500w halogen. Well, it's about to withstand 2-3 devices at once, so I think that 2500 to 3000w should embrace.
  • #7 17157081
    Zbigniew 400
    Help: 283
    Rate: 794
    Minimum 5kW.
  • #8 17157873
    malimaro
    Rate: 159
    Why five? 3 kw won't deal with concrete mixers and drills at once? After all, the concrete mixer takes about 1000w drill, the same is left for me then 1000w
  • #9 17158311
    Zbigniew 400
    Help: 283
    Rate: 794
    Read about the starting current.
  • #10 17158429
    malimaro
    Rate: 159
    I understand now, I need more coil to start the case here, but no matter, I have the impression that all these aggregates from PLN 600 to PLN 1,400 are the same: / and a better company is probably the cheapest above kruzer
    Added after 14 [hours] 10 [minutes]:
    Probably based on Stanley
    Added after 5 [hours] 4 [minutes]:
    I think they are good because the SG 3200 model is sold out everywhere, sellers are waiting for delivery
    Added after 19 [hours] 5 [minutes]:
    It's good that I didn't buy this aggregate, I learned that for connecting the electricity and placing the box with protection up to 2 kw I will have to pay 700 PLN and then only for protection 20 PLN a month and the electricity will be there all the time so there is a guitar. The greater the security, the greater the fees.
The discussion revolves around finding a reliable power generator for construction use under PLN 1,000. The user expresses concerns about the quality of cheap Chinese generators, citing a friend's experience with a PLN 700 model that lasted several years. Recommendations include considering generators with Loncin engines due to their steel cylinder liners, which may offer better durability. Participants debate the necessary power output, with suggestions ranging from 2,500 to 5,000 watts to accommodate multiple devices like concrete mixers and drills. The conversation also touches on brands like Kruzer and Yato, with some skepticism about lesser-known brands. The importance of understanding starting current requirements is highlighted, as well as the potential costs associated with electrical connections and protections.
