BESTER 170D-ST Inverter Welder: Affordable TIG Mount & Cable Options Under 400 PLN for TIG Lift
Szakuł880813 8988 4
  • #1 16724686
    Szakuł880813
    Rate: 14
    Hello, I have an inverter welder (BESTER 170D-ST) with the tig lift welding function, I would like to buy a cable for welding with this method, but I don't know what would be the best and reasonable price up to about PLN 400
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    SR26 8m and similar I propose. Use the rest of your funds on better gas lenses :)
  • #3 16724769
    Szakuł880813
    Rate: 14
    I have one more question, the bester purchased in castorama had a description of the tig lift function, but on the manufacturer's website it says that it has tig scratch functions http://www.lincolnelectric.com/en-pl/Equipment/Pages/product.aspx?product=B18254 -2 (LincolnElectric_EU_Base) does anyone know what the truth is and what is the difference, and will my bester generally be good at tig welding?
    filipski
    Help: 25
    Rate: 121
    This welder uses handles with a gas valve in the handle, for example: Link .
    There is a lot of it on alledrogo :) .
    TIG LIFT or scratch is the same. Ignition occurs by touching the material and moving the electrode 1-3 millimeters. The welding current increases to the value set on the panel. The disadvantage of this method of ignition is burning the tip of the electrode in the workpiece. You have to sharpen the electrode much more often.
    Find out more by google on the web.
    Andy
  • #5 16725015
    Szakuł880813
    Rate: 14
    Thanks for your help, I close the topic
