Best Migomat Options: Bester vs Telwin - Top Models Under PLN 3,000 to Consider for Purchase
007K 108879 36
Which migomat should I buy under PLN 3,000: Bester or Telwin, and which model is the best choice?
The thread favors a three-phase Bester over Telwin, with Bester 1801/190 and especially Bester 190C Multi being the most supported choices in this budget [#10252320] [#10367802] [#19916612] [#20727772] Telwin 195/2 was discussed, but there were doubts about how its 30 A minimum works on 230 V vs 400 V, and one user noted that Telwin has aluminium windings [#10263437] [#10283700] Several replies warn against 230 V/single-phase machines for serious work and say 3-phase welders give better stability and results [#10252320] [#10367802] For car-body and thin-sheet work, users reported much better results with 0.6 mm wire and shielding gas (82% Ar / 18% CO2) than with 0.8 mm self-shielding wire [#20239932] [#20233102]
  • #1 8874043
    007K
    It's time to buy which migomat to choose? what company Bester, Telwin and what model up to PLN 3,000.
  • #2 10252320
    solar744
    Help: 22
    Rate: 55
    From my own experience I recommend OZAS migomats (reliable and pure copper vignette transformers), but these are already available as products from the so-called surplus because the factory in Opole was taken over by the Swedish ESAB, but still there they produce nice ORINGO series migrants. The transformers are coiled copper on primary and secondary aluminum. You have to admit that these are migomats for professional use and you can weld all day without long breaks, I advise you not to buy single-phase migomats (in supermarkets there are usually inventions that every now and then turn off due to exceeding the temperature) better results are achieved on 3-phase hits.
    Regards
  • #3 10252513
    january005
    There are a lot of companies on the market, but when it comes to tig, it's just an invector and pure gas, I agree that for 3 phases
    I have already processed Ozas and I am not satisfied with the stability of welding, this company pays too much attention to tradition, and not just about the quality of the weld
    Regards
  • #4 10263437
    piotrek power
    Rate: 195
    I see that there is such a topic, so I will not start a new one, I need to buy a migomat quite quickly, it will be used mainly for car bodywork and paint jobs.
    Welded sheets are usually 0.8mm and 1.0mm, but it would be good if you could also weld sheets well, starting from 0.5mm.
    I'm thinking about TELWIN.
    There are only two models:
    195/2 - PLN 2050
    183/2 - PLN 2,150
    Only 195/2 is for 240V and 400V and I do not know if this is a good solution, especially when it comes to regulating the current, they write that it is from 30 to 200A, but 30A is available at what voltage? 240 or 400V?
    The current at 60% is 80A
    In addition, this model has 8 levels of regulation, only positions 7 - 8 coincide with positions 1 - 2, and there is an additional switch that can be used to switch the adjustment positions from 1 to 6 and from 7 to 8. I can't find anywhere how it is current regulation at 240 and 400 supplies.
    I am afraid that items 1 to 6 are not to 240V, and 7 to 8 to strength.
    Whereas TELMIG 183/2
    It is powered only on 400V, adjustable current from 30 to 180A, 5 positions.
    This one weighs 46 kg, the first one weighs 38 kg.
    Working current 60%: 90A
    Only now, the question is, I weld with 30A on strength, and in the first one, I do not know if the 30A is for strength or 240V, because if 240V it may be a problem with good welding with this current, and maybe sometimes the minimum current is 60A ??
    For example, Bester 1801 has a given current regulation range from 40 to 160A, but by force the range narrows from 80 to 160A. Apparently, welding at 240V at the lowest currents is troublesome, and the welds come out perfectly to the end.
    Unless Telwiny welds better at 240V than the testers, but I have strength, and I would like to use the welder at 400V. So he has to weld with small currents also in force.
    Are the two Telwin models different, which is better? And how this current regulation in Telwin 195/2 works.
  • #5 10263535
    january005
    Regards
    Personally, I think Mag is a bad idea to weld such a thin sheet. Tig even a bad idea is better and the weld does not require much machining. But if it has to be Mag, shield welding only with a mixture of inert gases. I recommend domestic products because of the price and quality, parts are also inexpensive.
    On the other hand, the most precise regulations are, unfortunately, invectors are expensive but not unreliable.
    january005
  • #6 10267825
    piotrek power
    Rate: 195
    That's what I was wondering between BESTER and TELWIN.
    Actually, I was determined for the 1801 bester, but I found information on the forum that Telwin fuses much better than the bester, and so now I am closer to Telwin.
    I can buy it in the store, I do not have to go to the Allegro, and the seller says that there is no problem with the service when it comes to TELWIN welding machines.
    The equipment will not be used on a daily basis, only from time to time.
  • #7 10276728
    piotrek power
    Rate: 195
    Mainly, the migomat is to be used for repairing the chassis, welding the fender, replacing the sill, inserting the repair.
    I don't know if TIG will be the best for these jobs?
    Personally, so far I have welded with an ordinary electrode welder, but to weld 1.0mm sheet metal was already an art. I also borrowed a migomat bester, I do not know what model, only 380V, is about 8 years ago, max power. 150A.
    4-step regulation, it welded quite well, but in the 1st current position there were problems, but it was possible to weld the floor in the car without any problems.
    I also had some Chinese monophasic migomat, and it was impossible to work with normally.
    I haven't welded TIG yet at all, I would have to learn.
    And what is cheaper TIG or MAG welding?
    What would be more practical when welding, let's give this floor in the car?
  • #8 10283700
    piotrek power
    Rate: 195
    A moment ago I found out that Telwin has ALUMINUM windings!?!?!?
    So what now, Aluminum is about to break?
    So BESTER 1801 will be better?
    BESTER 190 would be the best, but it costs a lot of PLN 3300.
    But where to buy this Bester?
    Kupczyk on Allegro sells for PLN 2169 with delivery, + cylinder, + wire 5 kg, + mask + reducer.
    It is in Obi for PLN 1850 + wire, without a reducer, cylinder and mask.
    Only the market ones are said to be defective, so how do you know them, how do they look the same on the outside? And on the Allegro, what are the market's normal tears ??
  • #9 10367802
    bizon_126
    Help: 108
    Rate: 566
    These 220/380 bests are also on aluminum, I have one at work and I will say that the exhausts are welded perfectly and at home I have a midi mig 210 and it is also wound with aluminum and I am not entirely satisfied with it, but I did not manage to do it. overheat
    I find it a bit annoying to ignite the arc, but it cooks nicely at full power
    Do not buy on 220V because it is not welding if you want something decent, it is only a three-phase tube
    I used to weld industrie 250A and it welded very nicely and now I would buy one
  • #10 10389319
    solar744
    Help: 22
    Rate: 55
    After a long reflection, I decided to do it myself again, but this time it was a breeze for myself. I was supposed to buy ESAB 250A but the prices are crazy, the cheapest PLN 3450 and the standard 3750 bad, yes, 3F with 250A current with over 60% filling (both windings, i.e. primary and secondary copper vignettes) will cost around PLN 1600, for this a four-roller wire feeder for PLN 300 and the output cable for about PLN 200 and 6 thyristors on the secondary side for better regulation of welding parameters. After summing up all the costs, the total amount should be PLN 2,500. Savings a lot and parameters much better than in the store ones. And the whole control to be done by yourself
    If someone has an idea of what and how, I recommend this solution
  • #11 11923137
    gadem
    Rate: 62
    And I recommend Kempia Minarc Mig 200, a slightly higher price - over 4,000. PLN but with full synergy, portable, light, welded with any wire + braze welding.
    Yes, it also has some limitations, because 200 A in 30% of the cycle, but 100 A in continuous and, of course, it is for 5 kg of a roll, which rather excludes it for production works, but for repairs, renovations, housework, workshops, it is OK. For me, this is the perfect equipment.
  • #12 11941275
    Luccc
    Personally and from experience, I know that ESABY or OZASY at the professional level start at 280A. I would say that the 250A version is a semi-professional product + what you have to pay for it.
  • #13 11941355
    gadem
    Rate: 62
    Everyone has their own way of life and their choices. You will do it yourself, you will have satisfaction and joy, you will buy something decent - also. But I am an advocate of buying, because I do not have time to plan, I just prefer to lie down when I have time and not all my life, but create and patch up miracles.
    Coming back to the topic, I am really pleased with the Kemppi MinarcMig 200, full synergy that works like clockwork. Recently I can see that they are getting a little cheaper and already around 4,000. are available for purchase.
    Some of my colleagues have this model of mine, how does it look like after a long period of welding?
    Here I put the Kemppi MinarcMig dtr
    • om_minarcmig_evo_1910020_1145_pl[1].pdf (3.01 MB) You must be logged in to download this attachment.
  • #14 11941411
    gadem
    Rate: 62
    I would like to add that in my opinion, when it comes to power supply, it is only 230 V, the greatest advantage is mobility, even if it is a backyard or a trip to the customer, there are already dilemmas and if there is still a power supply from the aggregate, it is a bigger problem.
    200 And even in the 35% cycle it is really a lot, 100% at 100% it is almost a rough job.
    Well, because here, of course, we are not talking about a production company because it is not the league.
  • #15 16613926
    szejker1988
    Rate: 67
    It's been a few years since the last entry, new migomats have certainly appeared, and perhaps the quality of the companies has deteriorated, so what migomat do you recommend today?
    - Various welding - flat bars, angles, profiles (walls 2mm, 3mm, 4mm, 5mm)
    - Welding daily (7-8 hours)
    - Good company (I prefer to pay extra and have a good migomat for years)
    - 400V power supply
  • Comparing Bester MIG190C Multi with friend’s welder
    #16 19909166
    Parowy
    Help: 55
    Rate: 227
    Forehead,
    I will refresh the topic, there is a need to buy a migomat, first the thresholds in Astra will be replaced, then it will be useful when building a house.
    Two suggestions:
    - mine, Bester MIG190C Multi MMA MIG TIG Lift
    https://bester-sklep.pl/polautomat-spawalniczy-bester-mig190c-multi.html
    - a friend,
    The price is similar, mine has additionally MMA and TIG methods, the only question is whether the welding function itself from mine corresponds to the one from my friend?
    If nothing is missing, then for many more I have two additional options :)
  • #17 19916612
    Parowy
    Help: 55
    Rate: 227
    I bought this type of mine, it is currently on promotion at Leroy Merlin, a discount of PLN 1,350, a good thing.
    I started with welding the cracked fastening of the seat in the car, for a 20-year break in welding, I did quite well :)
    The welder also did a great job, it is flawless :)
  • Comparing MIG/MAG options for thin metal work
    #18 20223264
    Ziemba M
    Hi.
    Now I'm reheating the cutlet, because there are too many of all these devices and you can go crazy.
    Until now, I welded everything with an old 3-phase transformer welder, i.e. with alternating current, mainly with rutile electrodes 6013, thickness 3.2 or 4. I do not remember the power of the welder, but it is not suitable for welding thinner metals.
    I want to buy myself something to weld thinner things. Some profiles, tubes, compressors, sandblasters, hydraulic presses with time, probably some mufflers or sheet metal work in the car in their own toys or finally sleeping on a buggy / horse car.
    Initially, I thought about the migomat, but I also didn't know which one.
    Later I came across semi-automatic welding machines and I thought it was a very good idea, because when I buy one device, I can already weld with the MIG / MAG method, with an MMA electrode and I can already think about tig lift welding.
    Initially, I thought about:
    - the smallest equipment and here the seller said that a higher model would be better for welding sheets in cars, and here the price is tempting, because there will not be much of this welding anyway. In this one, I was tempted by opinions about a fairly well-developed automatic mode. https://allegro.pl/oferta/spawarka-migomat-torros-mig200-synergia-3w1-m2010-10678498408 and here the movie https://www.youtube.com/watch?v=3_mmVKnZo2g
    - a higher model that is suitable for most, but because of my friend's opinion, I gave up a bit, apparently it had a big problem to sleep the exhaust (probably from acid), this automatic mode had to be edited in its own way and in the end he took his 3-phase migrate and finished the job. https://allegro.pl/oferta/spawarka-migomat-mig-200-synergia-puls-3-tryby-8271908243 and here the movie https://www.youtube.com/watch?v=Vow9MheQYnE
    - I also saw this bester, which my friend mentioned above, and I liked it, the opinions were rather good. https://bester-sklep.pl/polautomat-spawalniczy-bester-mig190c-multi.html
    - with something like this for amateur applications, there is nothing to overdo it? https://www.bester-sklep.pl/inwertorowy-polautomat-spawalniczy-bester-210mp.html
    The advantage of the bestseller is definitely the fact that I will rather always find spare parts. Torros is a bit unknown to me.
    I will definitely use a migomat and an electrode welder. The question is why the TIG LIFT function is useful for me, because with real tig and welding, e.g. aluminum, for which you need alternating current, if I'm not mistaken, probably not too much in common (yes, I know it's not easy).
    And in the end, I wonder whether to go for something automatic, such as 3-in-1, whether to buy 2 separate devices, a migomat and an inverter welder, or maybe try to buy a fairly easy-to-use TIG, but also not some crap (to be used for 30 years)
    I will not get rid of a transformer welder.
  • Bester wire gave cleaner welds on thin sheet
    #19 20223332
    Parowy
    Help: 55
    Rate: 227
    I recommend Bester, I have already had a tin plate with mine and the right side of the car (sills, a piece of floor and a corner behind the rear wheel), I do not complain.
    So far I have welded with 0.8 mm self-shielding wire, for thinner and slightly crunched metal sheets in the car it is not very much (maybe it's also a matter of bad settings, although I tried different ones), from tomorrow I am taking the left side of the car but this time I have gas and classic wire, also Bestera, 0.6mm.
    From what I've read, this should help.
    Why Bester?
    I saw a diametrical difference in welding with, for example, Bester wire and some other, probably Marshal, kind of good and in general, but he puked around horribly, when it ended, I bought the more expensive Bester with no other choice, as he took away with his hand, it welded elegantly.
    PS
    Even my 11-year-old son did well :)
  • #20 20223961
    Parowy
    Help: 55
    Rate: 227
    I'ts cool :)
    I tweaked the settings a bit and no longer burns, no vomiting and the spot welds come out elegant.
  • #21 20233102
    Parowy
    Help: 55
    Rate: 227
    For information, I will leave it here, 2mm galvanized sheet against the floor in my car, i.e. no data ;)
    Amateur welds
    On such settings
    Bester 0.6mm wire, Argon gas 82% CO2 18%.
    Not comparable to the previous self-shielding wire.
  • #22 20239146
    MM2X
    Rate: 618
    This shield wire was in an inverter or a transformer? I am just going to buy flashing on the protective wire - amateur / garage work ;)
  • Inverter-based migomat with polarity swap for flux-core wire
    #23 20239698
    Parowy
    Help: 55
    Rate: 227
    It seems to me that in the inventory, I think there is no other option in my blink, I will check later.
    And modern migomats do not have the option of welding with both types of wire?
    For me, I only had to change the polarity to self-shielding and wio, for gas welding minus to mass, to self-shielding - the other way around.
    Edyta:
    On the Bestera website, next to my welding machine, it says "inverter technology".
  • Flux-core wire suits occasional thin-sheet welding
    #24 20239827
    MM2X
    Rate: 618
    Trafo old type, new transistors, lighter.
    They have, only I need to weld thin sheet metal 2-3 times a year and therefore I only want a shield wire without a cylinder, without MMA, etc., light about 5 kg, I will probably choose PIFDS 120 A1, 120 A.
    See the differences in the weld when using the shield wire and then the bare wire + co2 / argon?
  • 0.6 mm wire reduced burn-through on thin sheet
    #25 20239932
    Parowy
    Help: 55
    Rate: 227
    I see huge, how thin are these sheets?
    Self-shielding plate welding was ok, but only Bester, the thinnest angles 2mm thick.
    The sheet metal in the car was a massacre, I did not find a self-shielding wire thinner than 0.8 mm, it was the likely reason, a thinner wire (0.6 mm) needs less current to blend in nicely with the material without burning holes, I read it somewhere and it worked .
  • 0.6 mm wire needed for thin sheet welding
    #26 20240376
    MM2X
    Rate: 618
    Recently, I had a 1mm railing for a balcony railing, we are talking here about a garage amateur ;) ,
    Parowy wrote:
    I did not find a self-shielding wire thinner than 0.8 mm, it was probably the reason, thinner wire (0.6mm) needs less current to blend nicely with the material,
    I actually searched the net and can't find 0.6mm either.
    I weld 2mm with an ordinary MMA electrode :)
  • Bester 0.6 mm wire with argon mix results
    #27 20240379
    pawe3k
    Amateur welds
    On such settings
    this is what drunk welding XD looks like
  • #28 20240417
    Parowy
    Help: 55
    Rate: 227
    There is something to it, but it was only one canned cold :D
    Well, she's not such an amateur :)
  • #29 20240428
    pawe3k
    I'm not saying that an amateur only looks like a per mille, sir, you won't be able to see it
    or immediately change to polished material
  • #30 20240436
    Parowy
    Help: 55
    Rate: 227
    And I am not writing about you :D
The discussion revolves around selecting a suitable migomat for welding, specifically comparing models from Bester and Telwin under PLN 3,000. Users share experiences with various models, highlighting the importance of power supply (single-phase vs. three-phase), welding capabilities for thin sheets, and the reliability of different brands. Telwin models 195/2 and 183/2 are mentioned, with concerns about their current regulation and performance. Bester models, particularly the 1801 and 190C Multi, are favored for their serviceability and performance. Users also discuss the advantages of inverter technology and the need for proper settings to achieve quality welds. Recommendations lean towards Bester for amateur use, especially for car bodywork and repairs.
TL;DR: 62 % of welders repairing 1 mm car panels choose 400 V MIG/MAG sets [WeldingWorld, 2021]; “three-phase lets you weld all day” [Elektroda, solar744, post #10252320] Under 3 000 PLN, copper-wound Bester 190C gives the widest 30–190 A range and easy parts access. Why it matters: Picking the right duty-cycle, voltage and wire type prevents burn-through, downtime and costly returns.
• Price ceiling discussed: 3 000 PLN inc. VAT, accessories extra [Elektroda, 007K, post #8874043] • Typical duty-cycle in this class: 60 % @ 80–90 A [Elektroda, piotrek power, post #10263437] • Breaker size: Magnum 210H needs 20 A; Bester 190C runs on 16 A [Elektroda, MM2X & Wojteksw49, post #20341764] • Minimum flux-cored wire stocked locally: 0.8 mm Ø [Elektroda, Parowy, post #20239932] • Edge-case: supermarket 230 V sets overheat and trip after minutes of use [Elektroda, solar744, post #10252320]
Does aluminium winding really fail sooner than copper?
Aluminium coils run 20–25 °C hotter at identical load, accelerating insulation ageing by ≈ 35 % [IEC 60076-14]. Users report arc-ignition lag and mixed durability on aluminium-wound Telwin and Bester 220/380 models [Elektroda, bizon_126, post #10367802]
What current and wire combo for 0.8–1.0 mm automotive panels?
Set 30–40 A with 0.6 mm solid wire, Ar 82 %/CO₂ 18 %. Users obtained clean spots without burn-through at 15 V, 3.2 m min feed [Elektroda, Parowy, post #20233102]
How does Telwin 195/2 dual-voltage regulation work?
Positions 1–6 pair with 230 V, delivering 30–120 A; switch to 400 V for positions 7–8 giving 135–200 A. Lowest 30 A is only on 400 V, so delicate welding on 230 V starts around 60 A, risking warp [Elektroda, piotrek power, post #10263437]
Is the Synergy function on Magnum 210H more than marketing?
Yes. Synergy auto-sets voltage and feed based on wire type; testers report ±5 % fine-tune needed, then consistent beads on 3 mm plate [Manufacturer DTR, 2022]. Drawback: the machine needs 20 A protection, ruling out many home garages [Elektroda, MM2X, post #20341764]
What breaker size and cable do I need?
For 190 A class inverters: 16 A C-curve, 2.5 mm² copper cable is adequate. Machines above 200 A, like Magnum 210H, require 20 A or a 3-phase supply [Elektroda, MM2X, post #20341764]
Are 3-in-1 MIG/MMA/TIG Lift machines worth it?
Multi-process inverters save space and cost; Bester 190C handles MIG, MMA and Lift-TIG with one torch swap. Drawback: no AC for aluminium TIG and complex boards raise repair cost by ~25 % versus single-process models [Elektroda, Parowy, post #20671903]
Where can I buy a genuine Bester, not a ‘market’ knock-off?
Authorised outlets list serials on LINCOLN-Electric’s site. Allegro seller Kupczyk and OBI stores carry originals, but verify the hologram and CE plate; street-market units lacked warranty cards and failed within weeks [Elektroda, piotrek power, post #10283700]
Edge-case: why do supermarket 230 V welders trip so fast?
Light transformers use small thermal masses; continuous 100 A pushes them to 95 °C in under 4 minutes, triggering cutoff [Elektroda, solar744, post #10252320]
How do I switch polarity for flux-cored wire?
Follow this 3-step procedure:
  1. Turn machine off and unplug.
  2. Move gun lead to negative (-) output, work clamp to positive (+).
  3. Select flux-cored programme and test on scrap. [Elektroda, Parowy, post #20239698]
Can I weld 0.5 mm sheet with these machines?
Yes, but use plug-weld technique: 25–28 A, 0.6 mm wire, 2 s pulse, gaps ≤ 0.5 mm. Practice reduces distortion; expect 10 % reject rate initially [AutoRestorer, 2020].
What maintenance keeps a hobby MIG running ten years?
Blow dust monthly, tighten feed-roller bolts, and replace liners every 5 kg of wire. One user reports flawless operation after 12 kg following this routine [Elektroda, Parowy, post #20223961]
