Buying New Home MMA Inverter Welder: Opinions on Bester MAG Power 155-ST, 150A, 2-4mm
Piotr199423 3816 7
  • #1 17156409
    Piotr199423
    Hello, I am going to buy a new MMA inverter welder for home and hobby work without professional welding. I chose the BESTER MAG POWER 155-ST model. Higher current like 150A and electrodes from 2-4mm would be enough for me. What is your opinion about this welder.
  • #2 17156958
    foxeeti
    This model of a welder for home garage work is enough, of course, everything here depends on the hand of the welding machine. But I would advise you to buy a half automatic welding machine (Migomat), instead of an inventory one because Migomat is more universal, you weld and thin sheets and quite thick and the electrode will burn thin, but you can weld very thick.
  • #3 17157262
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    I recommend an Italian MMA welder by Stanley with a range of 200A. The set includes wiring and the helmet itself. Its promotion price is slightly above PLN 500. Its symbol is the Stanley 7000
  • #4 17157280
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    kierbedz4 wrote:
    I recommend the Italian MMA welder by Stanley with a range of 200A
    Crude Chinese US venture, you wanted to say. :cry:
    I prefer it:
    http://goodmajster.pl/_Elektronarz%C4%99dzia-...awarka-inwertorowa-MMA-250A-(IGBT)-KD844-6387
    Also Chinese, only more .... advanced. :D
    On Allegro it is cheaper and in the "armored" version, with a powerful display cover.
  • #5 17158434
    Piotr199423
    And what do you think about kemppi welders? From what I read, they are welders from Finland and they say they praise them a lot instead of the Chinese ones, because maybe I would rather add and buy something better and for years and not be nervous that it overheats and turns off or something else .
  • #6 17158498
  • #7 17158703
    Piotr199423
    protasiewicz, of course, I have seen the prices. Maybe they are amazing, but I would rather add and buy something from kemppi so that it will last for years, not for a few uses or otherwise. I'm just thinking about Kemppi Minarc 150 or Minarc 180 EVO and I don't know which one to choose.
  • #8 17160362
    Piotr199423
    However, I chose the Kemppi Minarc 180 EVO
The discussion revolves around the purchase of a new MMA inverter welder, specifically the BESTER MAG POWER 155-ST model, which features a current capacity of 150A and supports electrodes ranging from 2-4mm. Responses suggest that while the BESTER model is adequate for home and hobby use, some users recommend considering a semi-automatic welder (Migomat) for greater versatility. Alternatives such as the Stanley 7000 and various Chinese models are mentioned, with a preference for higher-quality brands like Kemppi. The Kemppi Minarc 150 and Minarc 180 EVO are highlighted as durable options, although their higher price point is noted as a concern for some users.
