Peugeot 3008 2012: Disabling Electronic Handbrake, Monochromatic Screen A, SDprog, MaxiEcu
Viper2215 21525 6
  • #1 16725576
    Viper2215
    Rate: 9
    I have a question about the electronic handbrake.
    I wanted to turn it off so that it does not pull automatically when the car is stationary, I read it in the manual and I know that it is possible but with my equipment version (MONOCHROMATIC SCREEN A (WITH RADIO)) the instruction refers to the dealer. Now my question is whether it is possible to disable the same after connecting to the computer? As for the computer program, I'm thinking of buying sdprog or MaxiEcu.
  • #2 16725676
    leonov
    Help: 1039
    Rate: 2248
    You won't do it 100% like Lexia can.
  • #3 16725707
    Viper2215
    Rate: 9
    I just wasn't sure what I read if these programs could handle it.
  • #4 16725761
    leonov
    Help: 1039
    Rate: 2248
    Both programs are probably under ELM327, and before you connect only to the engine, so how do you want to deactivate the brake?
  • #5 16726665
    Viper2215
    Rate: 9
    Is there any program to connect to the main car computer? If it is, I would ask for its name and location of the attachment.
  • #6 16726678
    Ireneo
    Help: 747
    Rate: 2472
    You will get cheaper in ASO. You need an interface along with the program. Plug in through obd.
  • #7 16726929
    Viper2215
    Rate: 9
    OBD is it not for engine diagnostics?
The discussion revolves around the possibility of disabling the electronic handbrake in a 2012 Peugeot 3008, specifically for models equipped with a Monochromatic Screen A. The user seeks to know if this can be achieved through computer software, considering options like SDprog or MaxiEcu. Responses indicate that while these programs may not fully replicate the capabilities of Lexia, they are likely limited to engine diagnostics and may not access the main car computer necessary for disabling the handbrake. It is suggested that a dedicated interface and software are required, and that visiting an authorized service organization (ASO) might be a more cost-effective solution.
