Samsung UE50MU6172: Darker Stripes and Light Spot on Screen - Matrix Model Query
alsen22 3612 14
Should I return or complain about a new Samsung UE50MU6172 that shows dark stripes on the sides and a light spot on uniform backgrounds?
Yes—if those stripes and the bright spot are visible on uniform backgrounds in a brand-new TV, the thread’s advice is to return it or file a warranty complaint immediately [#16725968][#16726266] Several replies recommend using the 14-day return right, which does not require you to justify the decision, but you should send the TV back together with a written withdrawal notice [#16728464] They add that the return shipping is at your own expense, while the seller must refund the TV price and the original shipping cost within 14 days [#16728464] The service route may claim that such picture-uniformity issues are normal for the technology, which is why the forum leans toward returning the set instead of waiting for service [#16726272][#16726276] Unpacking, connecting, and testing the TV is treated as fair use, so open packaging or inserted batteries should not by themselves block a return [#16728532][#16733608]
  • #1 16725940
    alsen22
    I bought a Samsung UE50MU6172 TV 3 days ago
    Generally speaking very nice
    The TV setup was on a white background and I noticed shadows.
    I thought maybe a background like this.
    However, it was bothering me and I decided to turn on the RGB test - youtube video
    As a result, in my opinion, the TV shows two darker stripes on the sides and a small lighter spot that I marked in the photo. While watching it, it is not particularly visible, but it is noticeable with uniform backgrounds
    And now, honestly speaking, I do not know what to do, whether this TV is simply supposed to or, for example, return it to the store and replace it. Or maybe it just seems to me ...
    Maybe some of you have such a TV and could do a similar test for comparison?
    The TV came pre-packed date June 2017 made in Hungary
    By the way, can you tell me what matrix model does it have? I found conflicting information on this
    Thanks in advance for your advice
  • #2 16725968
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. As it is new and under warranty, I advise you to make a complaint immediately.
  • #3 16725975
    alsen22
    I have a TV set from Monday, but I still did not have time to set everything up until yesterday, so I wrote here today asking for advice. Was online ordered from Euro
  • #4 16725982
    Pedros050
    Help: 2471
    Rate: 3926
    If a colleague has a telephone number, call the company and file a complaint. Returns apply up to 14 days.
  • #5 16726255
    alsen22
    Well, I do not know what to do, I am green in these matters, it is probably best to return this TV within 14 days. I called Euro and of course the Lord told me that it is better to call the service, which will find the defect, because then it will be possible to replace it, and so I may incur some additional costs, e.g. due to the fact that after arrival the defect would be caused by my fault ...
  • #6 16726266
    Pedros050
    Help: 2471
    Rate: 3926
    And that's what you have to do for that is the Warranty and the Service has to take care of it.
  • #7 16726272
    alsen22
    This is true, but I have already read what the service usually responds to such "faults", that it is the norm with such technology, etc., that it is acceptable and does not take into account, so I do not know whether it is better not to give it back and not bother with services ...
  • #8 16726276
    Pedros050
    Help: 2471
    Rate: 3926
    As my colleague thinks, I would do the same, I am entitled to a refund of up to 14 days at no cost.
  • #9 16728464
    KOCUREK1970
    Help: 3861
    Rate: 5489
    @ alsen22
    By returning the goods within 14 days, you do not have to explain yourself to anyone.
    You have another 14 days to return the goods from the moment you inform them about this fact.
    You send back the tv and the waiver in writing in one package and only inform them about it.
    They have 14 days to return the cash register (the purchase price of the tv and the cost of sending it to you).
    You send back the goods at your own expense (and no one will reimburse you for this cost).
    I hope you carried the tv, set it up in 2 people, and the courier did not carry it in his hands alone?
  • #10 16728525
    Ture11
    Help: 573
    Rate: 1130
    KOCUREK1970 wrote:
    @ alsen22
    A colleague forgot to add that the goods must not have any traces of use ...
  • #11 16728532
    KOCUREK1970
    Help: 3861
    Rate: 5489
    We call it fair use - so we have the right to unpack, connect and check if it suits us by checking its usability.
  • #12 16732945
    alsen22
    Of course, I opened the tv, as if I had to check if it works at all
    I also give back the used one, but briefly, I also had to unpack all the accessories, etc.
  • #13 16733608
    Ture11
    Help: 573
    Rate: 1130
    Legally, I think it's called even more ... crazy ... probably "ordinary management" or something.
    Author, you have the right to test the equipment, so no one will "hell" about the open packaging or batteries inserted into the remote control. However, I do not know what the matter of removing protective foils, etc - it is no longer necessary to "establish the nature and functionality" blah blah blah ... In fact, I wrote this information about unused goods, because not everyone is aware (surprisingly) from the fact that when I send back the goods that are scratched or evidently used, only the shipping costs (not small in the case of a TV set) may lose.
  • #14 16734856
    alsen22
    Fortunately, I did not remove the factory films from the frames around the TV, I had to test the remote control, as well as screw the base to somehow put the TV set. Yesterday I sent the tv, let me know when it ends
  • #15 17027980
    ja548
    Rate: 60
    @ alsen22
    How to do RGB test? I will check how it is with me
The discussion revolves around a Samsung UE50MU6172 TV that exhibits darker stripes on the sides and a lighter spot on the screen, particularly noticeable against uniform backgrounds. The user is uncertain whether these issues are normal or warrant a return. Responses suggest filing a complaint due to the TV being new and under warranty, with advice to return it within 14 days if unsatisfied. There are concerns about potential service responses deeming the issues as acceptable for the technology. Users emphasize the right to test the equipment and the importance of returning it without visible signs of use to avoid losing shipping costs.
TL;DR: Seeing two darker side stripes and a light spot? Use an RGB YouTube test; you have a 14‑day return window. “Returns apply up to 14 days.” [Elektroda, Pedros050, post #16725982] Why it matters: This helps new Samsung UE50MU6172 owners decide quickly whether to keep, service, or return a set.
Quick-Facts
How do I run an RGB screen test on the UE50MU6172?
Play an RGB test video on YouTube, set it to full‑screen, and view red, green, and blue fills in a dark room. Look for banding, darker stripes at the sides, and any bright spots on uniform colors. This mirrors what the original poster did to reveal the issue. [Elektroda, alsen22, post #16725940]
Is it normal to see vertical darker bands or a bright spot on uniform colors?
Service departments sometimes call such artifacts normal for the technology and within acceptable limits on uniform backgrounds. If that outcome displeases you, returning within the allowed period avoids a debate about "within spec." “It is the norm with such technology” was reported. [Elektroda, alsen22, post #16726272]
Should I return the TV or call Samsung service first?
If the set is new and under warranty, you can file a complaint immediately or use the 14‑day return right. Many buyers choose the return path to save time. “Returns apply up to 14 days.” [Elektroda, Pedros050, post #16725982]
How do I start a 14‑day return with an online retailer?
Notify the retailer of withdrawal within 14 days, then ship the TV back with a written waiver in the package. Expect the purchase price and original delivery cost refunded within 14 days of your notice. Keep proof of shipment and pack securely. [Elektroda, KOCUREK1970, post #16728464]
Who pays the return shipping and when is the refund due?
You cover the return shipping. The retailer has 14 days from your withdrawal notice to issue the refund, including the initial delivery cost. Track the shipment and keep documentation until funds clear. [Elektroda, KOCUREK1970, post #16728464]
Can I remove protective films and still return it?
Basic testing is allowed, but avoid removing protective films unless necessary to establish functionality. Keep the set clean and unmarked to prevent disputes about condition. This aligns with guidance to limit use to establishing nature and functionality. [Elektroda, Ture11, post #16733608]
Does opening accessories or attaching the stand count as "use"?
Fair use covers unpacking, connecting, and checking usability. Attaching the base to place the TV and testing the remote fit within that scope. Keep all packaging and avoid cosmetic damage for a smooth return. [Elektroda, KOCUREK1970, post #16728532]
What does “matrix model” mean on this Samsung TV?
In forum context, “matrix” refers to the LCD panel model used in the TV. The thread notes conflicting information about the exact panel used in this size. That uncertainty prompted the question from the buyer. [Elektroda, alsen22, post #16725940]
Do factory and packing dates matter for this issue?
Owners report unit labels with packing dates and factory locations; one case showed pre‑pack June 2017, made in Hungary. Such identifiers help describe your batch when contacting the retailer or service. [Elektroda, alsen22, post #16725940]
Any handling tips before I ship the TV back?
Use two people to carry and set up the TV to avoid panel stress or accidental damage. Repack carefully, include the written withdrawal, and note that the return shipment is at your cost. [Elektroda, KOCUREK1970, post #16728464]
What if service says the stripes and spot are within spec?
Service may classify uniform‑screen artifacts as acceptable. If you prefer a flawless panel, act within your retailer’s return window instead of debating tolerances with service. This was a concern raised by the buyer. [Elektroda, alsen22, post #16726272]
What did another buyer end up doing in this situation?
The thread starter briefly used the TV for testing, attached the base, and then sent it back within the return period. They planned to update after the retailer’s decision. [Elektroda, alsen22, post #16734856]
