Electrically conductive and abrasion resistant spray-coating.
walus12 8532 15
How can I make a thin, electrically conductive, abrasion-resistant coating for a sliding switch contact?
No conductive spray or varnish was considered durable enough for a sliding switch contact, so a real metal contact surface is the practical solution [#16735375] [#16735657] The most recommended option was a thin strip of self-adhesive copper foil/copper tape, properly cut and used as the contact surface [#16730967] [#16735657] If you still want a coating, the thread points to silver-based epoxy or conductive adhesive such as ELPOX 15 as the best-conducting choice, but it was presented as an experiment rather than a proven wear-proof solution [#16731081] [#16733906] Another option mentioned was EMV 35 conductive copper varnish in a 200 ml spray can, which was described as reasonably conductive, but still less abrasion-resistant than copper tape [#16733670] [#16734522] Graphite sprays were also suggested, but they were described as only slightly abrasion resistant [#16733670]
  • Request for conductive, abrasion-resistant spray coating
    #1 16730923
    walus12
    I am looking for a spray or some other self-application that conducts electricity (preferably with as little resistance as possible) and is resistant to abrasion. There are many offers on the web with descriptions that indicate conductivity and abrasion resistance, but I prefer to ask if anyone has had contact with it and can recommend something. I am interested in the best conductivity and the highest possible abrasion resistance. I want to use it in a kind of switch where another metal element will slide over such a painted surface, so it would be good if it didn't rub off. It would also be appropriate for the product to be available for purchase ;)
    Best regards.
  • #2 16730967
    zaqb
    Help: 5
    Rate: 13
    In my trials, the only thing that worked well was strips of self-adhesive copper foil (sometimes used in screens), properly cut.
  • Epoxy-silver conductive adhesive recommended for switch contacts
    #3 16731081
    vodiczka
    Help: 1185
    Rate: 4311
    walus12 wrote:
    I want to use it in something like a switch, where another metal element will move over such a painted surface,
    Give it up, as long as it's not supposed to be a multi-use switch.
    On the other hand, the carbon potentiometers don't wear out too quickly. If you like to experiment, try an epoxy and silver conductive adhesive.
    I can provide you with powdered silver for making glue yourself, you can buy a ready-made one, eg ELPOX 15
    Much depends on what current will "handle" the switch, and thus the pressure of the moving and stationary part of the switch.
  • #4 16731250
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Maybe instead of combining with some sprays, just use a reed switch?
  • Conductive coating for low-current sliding contact surfaces
    #5 16731558
    walus12
    Well, unfortunately not. Needs to apply a conductive coating. The predecessor also mentioned carbon coatings of the potentiometers - something similar to me.
    I was thinking about something such a , possibly something such a . Does anyone have experience with similar preparations?
    With copper tape there will be a problem that it will add a bit of thickness, and I would prefer it to be thin.
    Added after 15 [hours] 34 [minutes]:
    I mean something similar to the surface on the potentiometers. The supported current will be very small, the clamping force is similar to that of ordinary rotary potentiometers.
    Another issue is the resistance of such a surface. As long as it conducts electricity well over a distance equal to the thickness of the layer of this paint (i.e. from the metal that covers the top of this paint), how will it be with conductivity over longer distances (a few cm)?
  • #6 16733553
    vodiczka
    Help: 1185
    Rate: 4311
    It will be similar to the copper conductor. The resistance measured along the length will be many times greater than the transverse but still low, of the order of 1 ohm or a fraction of it.
    walus12 wrote:
    The operated current will be very small,
    . Up to how many milliamps?
  • #7 16733670
    wada
    Help: 168
    Rate: 732
    Graphit available at https://www.conrad.pl/p/lakier-cramolin-graphit-1281411-200-ml-820571? and many electronics stores - it is slightly abrasive, as with all potentiometers, - as with all graphite
    Graphiit 33 CONTACT 218 https://www.reichelt.com/pl/pl/Spreje-do-pow-...tml?ACTION=3&LA=446&ARTICLE=9480&GROUPID=4074 also graphite and slightly more abrasion resistant than above
    EMV 35 CONTACT 260 https://www.reichelt.com/pl/pl/?ARTICLE=9517&PROVID=2788 available as above, very resistant copper varnish with good conductive properties
    There are also EMI 35 https://www.sklep.cyfronika.com.pl/pl/p/KC-EM...-na-bazie-miedzi-EMV-35-pojemnosc-200ml/14655 less resistant to abrasion as above but probably more resistant to weather conditions
    You can also get EMV 35 with molybdenum in some places - it is probably the most abrasion-resistant varnish
    But there is probably no more abrasion resistant than self-adhesive copper tape. and it can be the cheapest.
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • #8 16733906
    vodiczka
    Help: 1185
    Rate: 4311
    wada wrote:
    highly resistant copper varnish with good conductive properties
    If the conductivity is to be good, then only silver-based varnish or glue.
  • #9 16734490
    walus12
    What about spray zinc? Will do the trick? Ew. aluminum? Because such are available. I only see glues with silver.
  • #10 16734522
    wada
    Help: 168
    Rate: 732
    NO
    poor conductivity and mechanical strength, these are sprays for protection against corrosion, e.g. galvanized gutters, or other elements where the original galvanized has been damaged
    I have given you what is used in electronics, read about it EMV 35 KONTAKT 260 - the resistance of the 1cm strip and the length of 1m is about 1.5 ? and after slightly pressing it, it becomes even lower, silver will not be much better, silver in addition quite quickly corrodes and with this EMV35 some repair heated car windows.
    You can buy EMV35 almost anywhere in 200ml spray.
    Elefant
  • #11 16734594
    vodiczka
    Help: 1185
    Rate: 4311
    wada wrote:
    silver in addition corrodes quite quickly
    You forget that silver oxide conducts electricity and that gives it an advantage over other metals. In addition, "brand" adhesives or varnishes are produced on the basis of the so-called flaked silver with a developed surface of silver particles.
  • #12 16735123
    walus12
    And you can recommend some silver-based spray / varnish. I can't even find it. There are only glues.
  • #13 16735375
    Freddy
    Help: 1394
    Rate: 2821
    No conductive varnish will be strong enough.
  • #14 16735621
    walus12
    So what to apply? Glue?
  • #15 16735657
    Freddy
    Help: 1394
    Rate: 2821
    Apply a thin foil.
  • #16 16735839
    walus12
    Freddy wrote:
    Apply a thin foil.
    It can not be otherwise? I also thought about copper tape to remove the glue from it (quite thick, because the copper itself is very thin) and stick it on a conductive glue based on copper no. Elpox 15. Will such something work?
The discussion revolves around finding a spray or coating that is both electrically conductive and abrasion-resistant for use in a switch mechanism. Various suggestions include self-adhesive copper foil, carbon potentiometers, and silver conductive adhesives. Users recommend specific products such as EMV 35, a copper varnish with good conductive properties, and graphite-based sprays like Graphit 33 CONTACT. Concerns about the thickness of copper tape and the effectiveness of zinc or aluminum sprays are raised, with a consensus that silver-based solutions offer superior conductivity but may not be as mechanically robust. The conversation emphasizes the need for a thin, durable coating that maintains conductivity over longer distances.
TL;DR: For sliding electrical contacts, thin copper foil outlasts most sprays; EMV 35 shows ~1.5 Ω per 1 m × 1 cm strip, and zinc/aluminum sprays have “poor conductivity and mechanical strength.” [Elektroda, wada, post #16734522]
Why it matters: This FAQ helps makers choose a durable, low-resistance coating or foil for DIY sliding switches and tracks.
What’s the most abrasion‑resistant conductive solution for a sliding contact?
Use thin metal foil or copper tape. Multiple users warn that conductive varnishes aren’t strong enough for repeated sliding. “No conductive varnish will be strong enough.” [Elektroda, Freddy, post #16735375]
Do copper-based sprays like EMV 35 work for low-current sliding contacts?
Yes, if you accept modest resistance. A 1 m × 1 cm EMV 35 strip measures about 1.5 Ω, and light pressure lowers it further. This suits small-signal contacts more than power paths. [Elektroda, wada, post #16734522]
Will zinc or aluminum spray work as a conductive surface?
No. These sprays target corrosion protection, not conductivity or wear. They show poor electrical performance and insufficient mechanical strength under sliding. [Elektroda, wada, post #16734522]
How does resistance change over a few centimeters on a coated track?
Expect longitudinal resistance higher than through-thickness resistance, yet still low. One member reported around 1 Ω order along length, rising with distance. [Elektroda, vodiczka, post #16733553]
Are silver-based materials better for low resistance?
Yes. Silver adhesives and varnishes use flaked silver to improve contact, and silver oxide remains conductive. This keeps surfaces electrically reliable over time. [Elektroda, vodiczka, post #16734594]
Are graphite sprays a viable option for sliding contacts?
Graphite coatings work but are slightly abrasive, similar to potentiometer tracks. Options cited include Graphit and Graphit 33; copper-based EMV 35 is tougher. [Elektroda, wada, post #16733670]
Can I build a low-wear slider like a potentiometer track?
Yes, under light pressure and small current. Carbon tracks last reasonably well. For better conductivity, use an epoxy silver adhesive such as ELPOX 15. [Elektroda, vodiczka, post #16731081]
What if copper tape adds too much thickness?
Switch to thin metal foil without adhesive. One recommendation was to apply a thin foil layer for minimal stack height and higher durability. [Elektroda, Freddy, post #16735657]
How do I apply thin copper foil for a durable contact?
  1. Clean and lightly scuff the base surface for adhesion.
  2. Lay thin foil, burnish firmly, and avoid air bubbles.
  3. Seal edges or overlaminate to prevent lifting during sliding. [Elektroda, Freddy, post #16735657]
How much current can a coated slider handle?
Keep current small. Contact pressure and path resistance set limits, as with potentiometers. Higher pressure lowers resistance but increases wear. Test under load. [Elektroda, vodiczka, post #16731081]
Is there a recommended silver spray or should I use adhesive?
Use silver epoxy adhesive for reliable conductivity; ELPOX 15 was suggested. It forms a robust conductive bond for small-signal paths. [Elektroda, vodiczka, post #16731081]
Is a reed switch a suitable alternative to a sliding contact?
Yes, if you can avoid mechanical rubbing. A reed switch provides contactless actuation with a magnet, eliminating wear entirely. [Elektroda, xury, post #16731250]
Does pressing the wiper onto EMV 35 really reduce resistance?
Yes. Users noted resistance decreases with slight pressure on EMV 35 tracks, improving contact quality during sliding. [Elektroda, wada, post #16734522]
What’s a common failure mode with conductive coatings under sliding?
Coatings can wear, flake, or polish through, raising resistance. That’s why thin foil is recommended for repeated motion paths. [Elektroda, Freddy, post #16735375]
