Cleaning Tarnished Ankle Pins: Effective Methods & Preparations for Non-Removable Contacts
matix1991 105129 9
How can I clean tarnished pins that cannot be removed from the device?
Clean the pins with a contact-cleaning preparation such as KONTAKT 60; it is meant to dissolve the corroded layer on tarnished contacts [#6646739] For a complete treatment, follow it with KONTAKT 61 to degrease and wash away the residue, then KONTAKT WL to leave a protective layer [#6646739] One user also reported that Valvoline Cleantronic works quite well [#6499920] Another reply recommended Slovak Kontox 5 as the best preparation and said it is effective [#6499359]
  • #1 6499167
    matix1991
    Rate: 34
    How to clean tarnished ankle pins? At first I wanted to replace these pins, but they cannot be removed from the ankle, so how to clean them, apparently there are some preparations for that?
  • #2 6499216
    balonika3
    Help: 1336
    Rate: 3759
    You can try a KONTAKT preparation, but I cannot guarantee success.
  • #3 6499322
    matix1991
    Rate: 34
    And if he used, for example, Coca-Cola?
  • #4 6499355
    balonika3
    Help: 1336
    Rate: 3759
    I heard but didn't try.
  • #5 6499359
  • #6 6499370
    matix1991
    Rate: 34
    And where can I get such a preparation?
  • #7 6499394
  • #8 6499920
    ociz
    Help: 1379
    Rate: 3486
    I use "Valvoline Cleantronic", I do not know how compared to others because I only used it but it works quite well, even with Ford it copes :D .
  • #9 6646739
    marrec
    Rate: 13
    I recommend KONTAKT 60 - a typical application is cleaning tarnished contacts. If you want to comprehensively preserve the contacts, then:
    KONTAKT 60 dissolves the corroded layer,
    KONTAKT 61 degreases and washes away residues
    CONTACT WL leaves a protective layer on the contacts.
    You can buy it in the WW.SMARUJ.PL online store. Various packaging.
    The picture below shows the instructions for cleaning the contacts according to the Kontakt Chemie catalog here shortcut to that directory
  • #10 6775086
    matix1991
    Rate: 34
    So this is how I bought this contact 60, first I puffed it, then I had a Loctite degreaser at home (I could twist it a bit) and before I washed off this contact and finally the Wurth silicone grease went (I could also make a mistake) and now everything is like best order
To clean tarnished ankle pins that cannot be removed, several effective preparations have been suggested. KONTAKT products, particularly KONTAKT 60, are recommended for dissolving corrosion, while KONTAKT 61 is used for degreasing. Additionally, CONTACT WL leaves a protective layer. Slovak Kontox 5 is also noted for its effectiveness. Users have mentioned using Valvoline Cleantronic, which reportedly works well, especially with Ford components. Some have successfully combined these products with degreasers like Loctite and silicone grease for optimal results.
