iPhone 6: Fading Backlight, Black Screen Issue, Soft Reset & Screen Flashing in Corners
kubs_23 8490 8
  • #1 16734384
    kubs_23
    Hello!
    For some time I have been trying to deal with the very irritating problem of my iPhone 6, which consists in the fact that every now and then during the day, the backlight goes off and leaves a black screen behind. It happens that after a minute or two, after pressing the home button, everything goes back to normal, and it happens that in order to recover the screen, I have to make a soft reset (it is often that I have to do it sometimes even 10 - just come back)
    In some cases, after a soft reset, when everything is normal, the screen flashes very clearly in the bottom corners of the phone.
    During the writing of this post, for two hours, nothing has happened yet.
    What can this be a fault?
  • #2 16734462
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    At the beginning to substitute a proven display.
  • #3 16734505
    kubs_23
    And assuming that on another display will also be the same, what I'm most afraid of, what remains for me?
  • #4 16734525
    RafalB
    Help: 91
    Rate: 222
    Backlight power supply, LCD power supply, socket, chokes, there are several possibilities.
    iFixThis
    Łowmiańskiego 18, Poznań, 60-685 | Tel.: 516XXXXXX (Show) | Company Website: https://www.instagram.com/ifixthis.pl/
  • #5 16734531
    kubs_23
    So the fact that the screen does not work, but works, does not matter?
  • #7 16734552
    kubs_23
    Tomorrow everything will turn out, I give it to check under another display, if nothing, I am forced to send to the site, because if I'm concerned, I have never interfered with anything more than the exchange of the display
    Added after 17 [hours] 27 [minutes]:
    Okay, it turned out that the same thing happens under another display.
    Since yesterday, theoretically the backlight went off only twice, now the only question is what is the fault, where can I go with it and what costs should I prepare for?
    Could someone recommend a service in Krakow?
  • #9 17004257
    Oorhidee
    Hey, an explanation is already known? I have the same !!! The display turns off for 5 minutes but the phone can be picked up when it rings
The discussion revolves around an iPhone 6 experiencing intermittent backlight failures, resulting in a black screen. Users report that the issue sometimes resolves after pressing the home button or requires a soft reset, with some experiencing screen flashing in the corners post-reset. Suggestions for troubleshooting include replacing the display, checking the backlight power supply, LCD power supply, and related components. One user confirmed the problem persists even with a different display, prompting inquiries about potential service options and repair costs. Another user shared a similar experience with their device, indicating a broader issue among iPhone 6 users.
