iPhone 6 Camera Issue: Stripes, Spilled Screen & Intermittent Failure - Possible Causes
SzynKa17 3183 2
  • #1 16776723
    SzynKa17
    I have a problem with the Aiphon such that although I do not use the front or rear camera, I have such stripes shown, even a spilled screen, I do not know how to define it, photo below:
    http://pokazyownica.pl/yzro51/ " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://pokazyownica.pl/yzro51/
    (photo taken in the dark)
    The problem does not occur all the time. After a while, I can take normal photos with no problem, but it comes back and it's annoying. I have never flooded the phone, the fall is also not an option. Friends say it's the camera's fault from the technical side, but I'd like to know what you think here. [/ Img]
  • #2 16776896
    QNextStep
    It may be an internal damage to the camera module or the system. It is best to visit the nearest authorized service center ?. Alternatively, you can try to restore the system via DFU if that does not help, the camera or its connection to the motherboard is physically damaged.
  • #3 16782426
    mahamalak
    Rate: 110
    The problem is not in the cameras themselves, but in the systems responsible for their functioning, located on the motherboard. In this case it is necessary to solder the motherboard. If you have any service warranty, have it serviced. Are there any changes when switching from camera mode to camera / recording?
