Audi A4 B5 AFN 98' - Flow Meter Error 553: Voltage Measurement, Mercedes Meter & ECU Issues
badyl666 8217 9
Is ECU pin 4 on the Audi A4 B5 AFN air-flow meter circuit a direct ground, or should I expect no continuity to ECU ground pins 1 and 27?
ECU pin 4 is not a direct ground, so you should not expect continuity between pin 4 and ECU ground pins 1 and 27 [#16735220] The flow meter ground is taken from ECU pin 52 to the 5-pin connector, and the MAF pinout is 2 = 12V, 3 = 5V, 4 = signal, 5 = mass [#16749160] That means the measurements you made do not by themselves prove a broken ground at pin 4 [#16735220][#16749160] If the wiring is correct and the new meter still gives the same fault, the problem is likely in the ECU/driver rather than something you can repair externally [#16748340]
  • #1 16735082
    badyl666
    Help: 25
    Rate: 109
    Hello. I measured the voltage to mass like ok. The flow meter was from Mercedes so I decided to buy a new one. On the new one the same mistake. I checked exactly according to this: https://obrazki.elektroda.pl/7157574400_1307541852.jpg
    2 to 12V and 2 to 3 2.2V, i.e. brown-blue cable. There is cable continuity to the ECU plug, but there is no transition between 4 and 1 and 27 (ground) in the ECU itself. Someone will tell me before I dismantle the ECU, is terminal 4 of the controller a clean mass and look for cold solder or something else fell?
  • #2 16735132
    sulof1601
    Help: 94
    Rate: 281
    Hello. But as between 4 and 1 as the first one is free and 4 is 5V.
  • #3 16735150
    badyl666
    Help: 25
    Rate: 109
    This measurement was on the ECU pins alone with the large plug disconnected. Pins 1 and 27 are the mass of the ECU.
    sulof1601
    Help: 94
    Rate: 281
    Pin 4 of the controller is the third on the flow meter, it is not a direct mass and there will be no transition between pins 4 and 1.
  • #5 16748255
    badyl666
    Help: 25
    Rate: 109
    Maybe it is so that the mass appears, some other condition must be met? Repair or look for another driver?
  • #6 16748340
    sulof1601
    Help: 94
    Rate: 281
    This is not how it works, there is a problem with the driver. You can't fix anything there.
    marfur30
    Help: 138
    Rate: 386
    Buddy pin 4 on the controller is + 5v then why should you have a transition with pins 1 and 27.
    The mass for the flow goes from pin 52 on the controller to a 5 pin plug.
    Plug for flow meter 2 - 12v
    3 - 5v
    4 - signal
    5 - mass
  • #8 16752187
    badyl666
    Help: 25
    Rate: 109
    I look at the available diagrams and analyze. If 2 to ground is to be 12V and 2 to 3 is to be 12V, it cannot be 5V. The cable was called and there is a transition of 3 MAF plugs to 4 ECUs.
  • #9 16752987
    marfur30
    Help: 138
    Rate: 386
    Do not measure 2 to 3 only 2 to mass and 3 to mass.
  • #10 16858337
    badyl666
    Help: 25
    Rate: 109
    I read similar posts and see that there are two types of voltage measurements on the flowmeter plug, e.g. https://www.elektroda.pl/rtvforum/topic563581.html#2911851 and the second in the post above. It is not the same. I wonder what is damaged and what is wrongly chosen? I had Pierburg 7.22684.07 and now the new 7.22684.18.0. Are their leads the same? Can substitute another driver only or does it match?
The discussion revolves around a voltage measurement issue related to the flow meter in an Audi A4 B5 AFN 98'. The user initially replaced a Mercedes flow meter but continued to encounter error 553. Measurements indicated that pin 4 of the ECU provides +5V, while pins 1 and 27 serve as ground. There is confusion regarding the correct voltage readings and the functionality of the flow meter, with suggestions that pin 4 is not a direct ground and that proper conditions must be met for the mass to appear. The user also inquired about compatibility between different flow meter models, specifically Pierburg 7.22684.07 and 7.22684.18.0, and whether another driver could be substituted. The conversation highlights the importance of accurate voltage measurements and the potential need for further diagnosis of the ECU or flow meter compatibility.
