Understanding the Meaning of Azimuth Angle for a Transmitter: A Look at 270 Degrees
Niki331 23361 5
  • #1 16737211
    Niki331
    What this angle to the transmitter means. For example, 270 degrees.
    mariuszp19
    Help: 310
    Rate: 409
    Azimuth - the angle between the southern direction and the direction of antenna reception in the horizontal plane.
  • #3 16737229
    Hiob44
    Rate: 11
    Probably the northern direction ...
  • #4 16737376
    mariuszp19
    Help: 310
    Rate: 409
    For the satellite antenna, the azimuth is given from the south. We do not know what the author expects.
  • #5 16737435
    Hiob44
    Rate: 11
    Of course, my mistake.
  • #6 16739634
    _kli_
    Help: 762
    Rate: 1040
    Geographical azimuth - the angle between the northern part of the geographical meridian and the given horizontal direction. Like every azimuth, it is counted clockwise from the north direction defined by the reference meridian, and its value is expressed in an angular rate
    In truth, I have not met any satellite calculator (e.g. link . link ) provided an azimuth calculated from the southern part of the meridian. Sometimes, for ease of use, the angle of the antenna's direction is set = azimuth minus 180 °.
    In this case, it may have a positive or negative value - depending on whether the antenna "looks" east or west of the meridian.
    Niki331 wrote:
    What does the azimuth angle mean to? transmitter ?
    However, when it comes to the question of the author of the subject, I get the impression that it is about terrestrial TV transmitter . Azimuth 270 ° is exactly the western direction - looking from the place of reception.
