Automatic Satellite Dish Azimuth Adjustment Circuit Using Signal Strength LEDs
240 6
  • Using signal-strength voltage to drive azimuth control
    #1 21662173
    Ali Naeem
  • Compass-based dish alignment instead of signal-strength tracking
    #2 21662174
    Frank Bushnell
  • Binary encoder disk and PIC16F877 control suggestion
    #3 21662175
    Mark Harrington
  • Magnetic sensor fails on steel platform
    #4 21662176
    Ali Naeem
  • #5 21662177
    Mark Harrington
  • Opto couplers for movement tracking with signal strength feedback
    #6 21662178
    Ali Naeem
  • OpenGL learning and night rider project update
    #7 21662179
    Mark Harrington
The discussion addresses the design of an automatic azimuth adjustment circuit for a satellite dish mounted on a floating platform subject to gradual directional changes due to ocean currents. The main challenge is to maintain optimal satellite signal reception without manual remote control adjustments. The proposed solution involves monitoring the satellite receiver's signal strength LEDs to generate a variable voltage input for a control circuit that actuates relays to rotate the dish. Alternative approaches include using an electronic compass or magnetic sensors to detect antenna deflection; however, magnetic sensors are ineffective due to interference from the steel platform. Another suggestion involves employing optical encoders with optocouplers to count rotational ticks for precise azimuth tracking, combined with signal strength feedback to guide adjustments. The system may incorporate geared reversible motors controlled via H-bridge drivers for fine movement. Software integration ideas include using microcontrollers (e.g., Arduino) and graphical interfaces (OpenGL) for visualization and control, with potential for PC or mobile interfacing. The geostationary nature of satellites implies a fixed reference azimuth, simplifying directional control but necessitating compensation for platform rotation. Signal strength monitoring remains critical to avoid unnecessary adjustments and to confirm optimal alignment.
