Best Antenna Types for Building a Directional Radio Wave Receiver for Specific Direction
315 6
  • #1 21675885
    Vivek Pratap
  • #2 21675886
    richard gabric
  • #3 21675887
    Vivek Pratap
  • Yagi antennas recommended for narrow beam directivity
    #4 21675888
    richard gabric
  • Higher amplification suggested for weak reception
    #5 21675889
    Justin Spencer Mamaradlo
  • Request for a directional 7 MHz receiver-transmitter set
    #6 21675890
    Vivek Pratap
  • #7 21675891
    Tessy Evans
The discussion focuses on designing a directional radio wave receiver operating at approximately 7 MHz (40-meter band) with a bandwidth up to 50 meters. The primary challenge is achieving directional reception that isolates signals from a specific direction while rejecting others. Yagi-Uda antennas are recommended for this frequency range due to their high directivity, though they tend to be physically large (around 20 meters wide) and require careful mechanical design for stability. The number of directors on the Yagi antenna depends on the desired beamwidth and directivity. Amplification may be necessary to improve reception quality. References to similar projects at different frequencies (e.g., TV frequencies and AM broadcast bands) highlight the relationship between wavelength, antenna size, and performance.
