Calculating Expected Electric Field Strength (V/m) at 1 Meter from Known Transmitter Setup
507 11
How do I calculate the expected electric field strength in V/m at 1 meter from a transmitter setup using a function generator, amplifier, and antennas?
You can’t get a meaningful V/m value from the generator setting alone; you need far-field conditions plus transmitter power/antenna gain or antenna factor, then convert the received power to power density and electric field strength [#21680937][#21680946] The replies note that the spacing should be at least a few wavelengths for EMI/RFI work, and at 30 MHz 1 m is much less than one wavelength because λ≈10 m, while at 700 MHz λ≈0.43 m so 1 m is a bit more than 2 wavelengths [#21680937][#21680940] In the far field, use λ = c/f, the antenna gain to determine effective area Ae, then relate received power Pr to power density S through Ae; from there convert S to E using the free-space relation with Z0≈377 Ω [#21680946] The thread also explains that dBm is power referenced to 1 mW in a 50 Ω load, so you may need to convert dBm to watts or volts before comparing readings [#21680942] For practical measurements, the replies recommend a calibrated receiving antenna/instrumentation receiver or a known antenna factor, because that is how field-strength measurements are normally done [#21680937][#21680946]
  • Need field-strength calculation from antenna factors
    #1 21680936
    Mit Yeltu
  • Ask about frequency range and far-field spacing
    #2 21680937
    PeterTraneus Anderson
  • #3 21680938
    Rick Curl
  • Measuring received amplitude at 30 MHz and 700 MHz
    #4 21680939
    Mit Yeltu
  • Wavelength calculations for 30 MHz and 700 MHz
    #5 21680940
    Elizabeth Simon
  • Need to verify tester readings and dBm conversions
    #6 21680941
    Mit Yeltu
  • Explains dBm and RMS power-voltage conversion
    #7 21680942
  • #8 21680943
    Elizabeth Simon
  • #9 21680944
    Cologne LED
  • Clarifying antenna factor measurement from probe voltage
    #10 21680945
    Mit Yeltu
  • Far-field field strength from received power and antenna gain
    #11 21680946
    neha dubey
  • Far-field spacing needed for EMI/RFI estimation
    #12 21680947
    neha dubey
An electrical engineer new to electromagnetic compatibility (EMC) and EMI/RFI testing seeks guidance on calculating expected electric field strength (V/m) at 1 meter from a known transmitter setup. The setup includes a function generator at fixed frequencies (30 MHz and 700 MHz) with a 15 dBm output feeding a passive transmitting antenna, and a receiver antenna positioned 1 meter away, consistent with MIL-STD-461G and IEC 61000 series test standards. The engineer aims to verify if the measured field strength on a spectrum analyzer matches theoretical expectations. Responses emphasize the importance of operating in the far-field region, which depends on wavelength (10 m at 30 MHz, ~0.43 m at 700 MHz), and confirm that 1 meter is appropriate for immunity testing per MIL-STD-461G. The concept of antenna factor (AF) is explained as the ratio of electric field to voltage at the antenna terminals, enabling conversion between measured voltage and field strength. Clarifications on decibel units (dBm) and conversions to power and voltage are provided to aid understanding. References to standards (IEC 61000-4-3, MIL-STD-461G, CISPR 11) and resources on antenna theory and EMC measurements are suggested. The discussion highlights the need for measurements in the far field, proper interpretation of antenna factors, and understanding of logarithmic units to accurately assess electric field strength from transmitter parameters and receiver readings.
TL;DR: To predict V/m at 1 m, work in the far field, convert between S, E, and H using Z0 ≈ 377 Ω, and apply antenna gain/AF. “This estimation must be done in the far field region.” [Elektroda, Anonymous, post #21680946]
Why it matters: This FAQ helps EMC lab newcomers validate spectrum-analyzer readings and set drive levels for immunity/emissions checks.
Quick-Facts
How do I calculate the expected electric field (V/m) at 1 meter from my setup?
Work in far field. Convert desired E to power density S using S = E²/Z0. Relate S to received power via antenna gain/area, then back-calc with your transmit chain and antenna gain. Keep all gains/losses in the same reference. “This estimation must be done in the far field region.” [Elektroda, Anonymous, post #21680946]
Is 1 meter considered far field at 30 MHz or 700 MHz?
At 30 MHz, λ≈10 m, so 1 m is near field. At 700 MHz, λ≈0.43 m, so 1 m is >2λ and into far field for many antennas. Use larger spacing if in doubt. [Elektroda, Anonymous, post #21680940]
What is Antenna Factor (AF) and how is it used?
AF is the ratio of electric field (V/m) to the voltage across the antenna’s load. Multiply measured antenna voltage by AF to get field strength at that frequency. [Elektroda, Anonymous, post #21680945]
How do I convert dBm to volts for a 50 Ω system?
First convert dBm to watts, then use V_RMS = √(P×R) with R=50 Ω. Examples: 1 W = +30 dBm; 1 μW = −30 dBm. Use RMS values. [Elektroda, Anonymous, post #21680942]
What distances do common standards use for EMC testing?
Typical lab setups use 10 m for radiated emissions (CISPR 11) and 3 m for radiated immunity (IEC 61000-4-3). Check your specific standard and chamber geometry. [Elektroda, Anonymous, post #21680940]
How do E, H, and power density S relate in the far field?
They are linked by Z0≈377 Ω: S = E×H, E = √(S×Z0), and H = E/Z0. Maintain polarization alignment and impedance matching for valid results. [Elektroda, Anonymous, post #21680946]
I set my generator to 15 dBm. Are my analyzer readings reasonable?
Account for amplifier gain, cable losses, and antenna gains/factors. Apply the antenna factor to the analyzer’s voltage to compare with calculated E or S. Keep references consistent. [Elektroda, Anonymous, post #21680939]
What if I’m measuring in the near field by mistake?
Near-field coupling breaks the far-field formulas, causing large errors. Increase spacing to several wavelengths and ensure polarization, impedance, and loss terms are correct. [Elektroda, Anonymous, post #21680946]
Can you give a 3-step way to sanity-check my field reading?
  1. Convert your measured analyzer voltage to E using the antenna factor at that frequency. 2. Convert E↔S with Z0 to compare against expectations. 3. Reconcile differences by auditing gains/losses and distance vs. wavelength. [Elektroda, Anonymous, post #21680946]
How do I pick generator voltage and amplifier power to reach a target field?
Choose target E, compute S=E²/Z0, then model path with antenna gain and losses to find needed delivered power. Verify in far field and iterate with probe feedback. [Elektroda, Anonymous, post #21680946]
Why do experts stress decibels for EMC work?
Decibels simplify gain/loss chains because powers in dB add. “The decibel dB is a logarithmic unit of ratio.” Learn dBm references for quick checks. [Elektroda, Anonymous, post #21680942]
Which documents should a new EMI/RFI lab lead read first?
Start with IEC 61000 series for immunity and MIL‑STD‑461G if you test defense gear. Use your chamber’s specific methods afterward. [Elektroda, Anonymous, post #21680939]
Do I need to include cable loss and preamp gain in antenna gain?
Yes. Treat the system gain G as including antenna directivity and all significant losses or gains between antenna and receiver to avoid bias. [Elektroda, Anonymous, post #21680946]
What unit should I report field strength in?
Use volts per meter (V/m). 1 V/m implies 1 volt potential difference over a 1 meter separation along the field. [Elektroda, Anonymous, post #21680944]
Any common failure mode I should watch for when cross-coupling antennas?
Mismatched polarization or near-field spacing can depress received levels, falsely suggesting equipment faults. Verify far-field distance and polarization first. [Elektroda, Anonymous, post #21680946]
What’s a handy numeric check I can memorize?
+30 dBm equals 1 W. −60 dBm equals 1 nW. These anchor points help sanity-check analyzer scales and link budgets fast. [Elektroda, Anonymous, post #21680942]
