Connecting MyTab8 Tablet Screen (FPC80034 MIPI V1) to Raspberry Pi Zero: Is it Possible?
YatoSenpai 4614 6
  • #1 16741935
    YatoSenpai
    Hello, I would like to know if I can somehow connect this screen from an old tablet, namely mytab8, the screen is: FPC80034 MIPI V1 to the raspberry pi zero board?
    • Connecting MyTab8 Tablet Screen (FPC80034 MIPI V1) to Raspberry Pi Zero: Is it Possible? IMG_20171006_132557.jpg (1.76 MB) You must be logged in to download this attachment.
    • Connecting MyTab8 Tablet Screen (FPC80034 MIPI V1) to Raspberry Pi Zero: Is it Possible? IMG_20171006_132542.jpg (1.86 MB) You must be logged in to download this attachment.
    • Connecting MyTab8 Tablet Screen (FPC80034 MIPI V1) to Raspberry Pi Zero: Is it Possible? IMG_20171006_132530.jpg (1.73 MB) You must be logged in to download this attachment.
  • #2 16742002
    Ture11
    Help: 573
    Rate: 1130
    Somehow it is possible, but not simple. This would require the use of a fast microcontroller or FPGA chip.
    On the other hand, RPi screens are not expensive - why combine so much?
  • #3 16742027
    YatoSenpai
    I would like a screen of this size, and for a smaller one, I do not currently have a budget, so I prefer to play like this, even if it is not easy.
  • #4 16742102
  • #5 16742109
    Ture11
    Help: 573
    Rate: 1130
    Piotrus_999 wrote:
    this is a smaller screen - it would probably be possible as RPi supports this type of screen.
    RPi Zero has a CSI camera connector and for DSI there is no lead out connector.
  • #6 16742116
  • #7 16742625
    YatoSenpai
    I don't know much about what controllers or systems will be needed, but I know schematics and soldering, so is there any way to make such modifications?
Connecting the MyTab8 tablet screen (FPC80034 MIPI V1) to a Raspberry Pi Zero is theoretically possible but complex. It requires additional components such as a fast microcontroller or FPGA chip, as the Raspberry Pi Zero lacks a direct DSI connector and only has a CSI camera connector. Users have noted that while RPi-compatible screens are affordable, the desire for a specific screen size drives the interest in this modification. Soldering skills and knowledge of schematics are essential for making the necessary connections.
