  • A Magic Mirror built on a Raspberry Pi combines a translucent mirror, a thin monitor, and a wooden wall-mounted frame to show weather, time, calendar, compliments, and messages.
  • A 24-inch Iiyama E2481HS-B1 monitor sits in portrait orientation with its casing removed, while Raspbian rotates the screen, runs Apache, and launches Chromium in kiosk mode.
  • The monitor measures 556 mm x 323 mm x 46 mm, plus 6 mm for the mirror, and the finished frame weighs about 6.5 kg.
  • Initial USB power integration failed with a loud boom and blown apartment fuses, so the power cable was redesigned to use an iPad charger and the monitor’s supply separately.
  • Magic Mirror na Raspberry Pi
    The author, while shopping with his girlfriend, had quite a lot of time to think and look around. As he wandered from store to store, a mirror displaying inscriptions caught his attention. It was then that he had the idea to build a similar one, but better for himself. Your own magic mirror!
    What is needed to build such a system?
    * Mirror
    * Thin monitor
    * Raspberry Pi
    * Some wood and paint for the case
    * A lot of free time.
    Let's follow the stages of the project in turn.
    Mirror
    In the described system, an ordinary mirror would not work, so you need to use another - translucent one. The mirror should be chosen so that when the monitor screen behind it is blank - black - behaves like a normal mirror, but when the monitor is lit, it allows you to view the displayed information as on the screen. Venetian mirrors, often seen in films in interrogation scenes, work on the same principle. When the light is on in one of the rooms and it is dark in the other, the Venetian mirror allows you to look through them only in one direction. Besides, it's just ordinary glass.
    Buying such a mirror is not as easy as it may seem. The glazier from whom we buy them may have various insinuations as to the purpose of their purchase ... Basically, such mirrors are used for peeking, so the associations are self-evident. Despite temporary problems, the author of the project has purchased the mirror and can continue assembling the Magic Mirror.
    Monitor
    The second critical element of Magic Mirror is the monitor behind the mirror. When selecting a monitor, the author had to make many decisions: whether to be a new or used monitor; what size monitor is needed; how thin a monitor can be purchased; how to place the control buttons of the monitor; will the monitor be bright enough?
    As the monitor will be placed vertically (in portrait orientation, not horizontally as usual), the choice of monitor size was a factor in choosing its appropriate width, which translates into height in this arrangement. After making some adjustments and a few simple measurements, the author came to the conclusion that a 24 "monitor would be perfect for its use. An additional advantage of using such a monitor is the fact that most cheap 24" monitors work natively at 1080p resolution - and this is what the author wants to use for displaying information.
    Now it was only necessary to find the right model. The author toured all the stores within 20 km of his home, often arousing security interest when he looked at the monitors, especially from the back and bottom. Why is it so important? It's about the arrangement of the connectors. Most of the monitors had the connectors at the rear. The author was looking for one that has the pinouts on the side.
    The search ended with the selection of an Iiyama monitor. They are quite cheap, have a small size, have simple touch buttons and a connector located on the side of the housing. At this stage, it was still unknown whether the casing would be easy to remove and how the buttons were connected, but unfortunately no retailer allowed the casing to be opened in a store to check it.
    The author chose a 24-inch monitor from Iiyama, model E2481HS-B1. In order to minimize the distance between the monitor and the mirror glass, the author removed the casing from the monitor. It turned out that the internal screen of the monitor quite tightly covers the electronics, which does not take up too much space, which leaves a lot of space around it to place the necessary elements in the Magic Mirror housing.
    The monitor itself, after removing the housing, is about 10 mm, after adding the controller, the author has set the dimensions of the whole: 556 mm x 323 mm x 46 mm (+ 6mm for the mirror). These dimensions define the size of the entire device and the size of the enclosure that had to be constructed.
    Case
    After removing the dimensions from the monitor with the mirror, it was possible to start assembling the housing. It is made of wood glued together to form a durable mirror frame.
    Magic Mirror na Raspberry Pi Magic Mirror na Raspberry Pi Magic Mirror na Raspberry Pi Magic Mirror na Raspberry Pi
    As the electronics inside the mirror will generate a lot of heat, the author drilled a number of ventilation holes in the housing. Elements that will allow it to be hung on the wall have also been added. The whole thing weighs around 6.5 kg, so you need a strong suspension point. A small slot for the power cable has been added to the bottom of the case.
    After assembling the frame and filling all imperfections, the frame was sanded and painted - with paint with two layers of varnish. The chip housing was ready.
    Additionally, in order to fix the mirror in the housing, it was necessary to make four brackets that will be screwed to the frame and will hold the mirror pane in the right position. After the carpentry work, it was possible to move on to the next stage of the project - electronics assembly.
    Electronics installation
    Inside the housing there are the following elements:
    * Monitor
    * A Raspberry Pi
    * HDMI cable connecting the 'Raspberry' with the monitor
    * USB-microUSB cable for powering the Raspberry Pi
    * Monitor power cable.
    The author assumed that the computer's power supply would be solved via the USB port in the monitor, after all, all modern monitors have a USB port ... It turned out otherwise - this monitor was not equipped with such a socket, which generated an additional problem.
    It is not an insoluble problem, but in order for no additional cables to protrude from the mirror, it had to be elegantly solved. The author added a USB power supply and installed it so that it was integrated with the monitor's power cable.
    The USB power supply is mounted directly on the power cable and fixed with glue and insulating tape. The system looked really professional. Now is the time to test the power. All the elements were connected and the device plugged into a 230 V socket. The system worked without any problems, the Raspberry Pi was loaded and nothing seemed to be overheating. In a word - ideal.
    Unfortunately, 10 minutes later, the fuses in the apartment blown and cut off the power. It was not difficult to guess what was the cause of the failure ... After connecting the system to the power supply - this time with the unplugged Raspberry Pi and the monitor we could hear only a loud boom, and smoke flew from the USB power supply. Therefore, the solution created by the author did not work ...
    It's hard to see what caused the crash, but it didn't do the job for the cheap USB power supply. Maybe it was damaged while soldering it to the power cord, or the 'Raspberry' was drawing too much current. Either way, another solution was necessary. The author changed the power cable so that one part of it could be connected to the USB charger for the iPad, and the other to the monitor's power supply. This time the system worked flawlessly and nothing was burnt. The next step to the project implementation.
    Proper powering of the entire system on the table allowed us to proceed to the next stage of the project - installation of the Raspberry Pi in the housing.
    Installing the Raspberry Pi
    When the whole system is assembled, the Raspberry Pi - the heart of the Mirror - can be screwed into the housing. You need to configure the following in 'Raspberry':
    * Connection to a WiFi network
    * Screen rotation 90 degrees
    * Local web server for application presentation
    * Browser working in full screen mode
    The operating system chosen to control the Mirror is of course Raspbian. This OS is very flexible and has a lot of support for users. After downloading the image, load it on the SD card, which unfortunately takes a lot ...
    After inserting the SD card into the system, the system will load, which allows you to log in and run the configuration wizard. You can get to it at any time through the raspi-config command running with admin rights. In the configuration, you need to take care of the following things:
    * Make sure that the system will be loaded to the desktop and not to e.g. the command line / text terminal;
    * Configure time zones so that the computer displays the correct time;
    * Reserve 128 MB of RAM for the graphics processor in the advanced settings.
    The configuration can be played with impunity anywhere, but remember - if something goes wrong, it will be necessary to reinstall the system on the SD card, which as mentioned above - takes a lot of time ...
    WiFi configuration
    The installation of a wireless USB WiFi adapter is highly dependent on the card used. Some models are quite problematic to configure, but once launched, they should work flawlessly all the time. The author writes that it was the most problematic element of computer configuration.
    Screen rotation
    As the monitor screen is rotated from its normal position, it is necessary to flip it in the system. The effective resolution is then 1080 x 1920 px. It turned out to be very easy, it was enough to find the configuration file config.txt in the / boot folder and add the line in it:
    display_rotate=1
    In order for the monitor to work more efficiently, the author additionally commented on the line responsible for connecting HDMI 'hot':
    hdmi_force_hotplug=1
    After saving the changed settings and restarting the computer, everything should work immediately.
    Webserver
    The mirror interface is a simple website, therefore a web server, for example the popular Apache, is required to display it. Its installation and commissioning are very simple, just follow the steps below one by one. First, we make sure our system is up to date:
    sudo apt-get update && apt-get upgrade -y
    Then download and install apache:
    sudo apt-get install apache2 apache2-doc apache2-utils
    Ready! However, if we want to use PHP on our web server (and we want to), we need to install the modules responsible for its operation:
    sudo apt-get install libapache2-mod-php5 php5 php-pear php5-xcache
    And again - done! after the machine reset, the Apache server will be operational. If we now put the index.php file in the / var / www folder and enter the Raspberry Pi IP browser, we will see the content of the page from index.php
    Kiosk mode [/ b]
    To make sure that the computer will display the page correctly every time, we will use the Chromium browser in the so-called Kiosk mode. Its installation is extremely simple:
    sudo apt-get install chromium x11-xserver-utils unclutter
    At this stage, we also have to bury a little bit in the system configuration to disable the screen saver and automatically boot the system in the described mode. Just add a box (#) before the line in the / etc / xdg / lxsession / LXDE-pi / autostart file:
     @xscreensaver -no-splash
    And add the following lines:
    @xset s off
    @xset -dpms
    @xset s noblank
    @chromium --kiosk --incognito http://localhost
    These entries will turn off the screen saver completely and make Chromium run in the mode we set, launching the local page immediately in full-screen mode. You can now save and restart our microcomputer. After launching, the page loads correctly, so everything is fine and we can move on.
    Creating an interface
    The assumption of the project was quite simple: the interface was to be 100% passive. It would be difficult to implement interaction with the user in this system - the touch interface would dirty the mirror and most importantly: there are better devices for such solutions. Additionally, the mirror is also intended to be usable as a mirror. The excess of information on the display would be difficult to reconcile with the possibility of viewing it, so the author decided to use a passive interface that presents the following information:
    * Compliments, because it's best to start the day with a nice word;
    * The weather, because since we are getting dressed, it is good to know if the conditions outside allow us to assume this or that.
    * A clock with a calendar - it will let us know how much time we have left;
    * Messages, because we would like to know if our appearance is the only thing we should worry about.
    Of course, the system is open-ended and allows modifications to be made at any time, so further functions can be added at any time.
    The information is displayed as a website written in HTML with CSS and Javascript. The author used this opportunity to test not only his skills, but also the ability to write pages on an Apple computer.
    In addition to the self-created code, the application uses several open libraries, which turned out to be necessary to speed up the creation of the page. Those are:
    * Jquery
    * Moment.js
    * FeedToJson
    * ICal parser
    Moment.js allows you to conveniently work with dates and times, which makes it much easier to create an application with a clock with a calendar. FeedToJson and the iCal parser can import data from RSS feeds and the iCal calendar, respectively. The data is imported in JSON format, which makes it extremely easy to process it via HTML and Javascript responsible for the website.
    [u] Project
    A magic mirror must be pretty. The author - Apple fanboy - decided to use the company's style with an apple in the logo in this matter and used Apple's Design Guidelines.
    As the mirror is to allow viewing, the background must be black; therefore the letters are displayed in white and shades of gray. Of course, you could add colorful elements, but the author decided to stay true to the minimalist style.
    API
    The data to be displayed on the mirror is taken from a number of streams and via an API. The author uses, inter alia:
    * Openweathermap.org for downloading weather data and meteorological forecasts. The API of this system allows you to download weather for a specific location and date.
    * ICal calendar; iCloud allows you to share your calendar in the iCal format. However, it cannot be downloaded directly with Javascript (for security reasons) data is downloaded through a proxy written in PHP:
    [syntax=php]
    ghost666
    Translator, editor
    ghost666 wrote 11961 posts with rating 10267, helped 157 times. Live in city Warszawa. Been with us since 2003 year.
  • #2 15419371
    Tommy82
    Help: 455
    Rate: 1074
    It's cool, but from what I can see, no interaction.
    If you want to have fun, they are such devices
    http://automatykab2b.pl/prezentacja-artykul/7...ci-przemyslowy-komputer-panelowy#.Vrnvxz-fo_s
    Illustrative example The point is, however, that they have a touchscreen on.
    And now we marry such an LCD cover by inserting between the mirror. How to use a head board with direct screen output, e.g. some via epia. This whole thing could be powered by a picopsu with 12 V, which in the case of, for example, a bathroom is safer.
    How to put an android on it, you could play with the ability to control this voice.
    https://www.youtube.com/watch?v=kkZLuIjUUcE
    For this purpose, I use a tablet pressed against the desk so that it is fully accessible from the front desk.
    An app that will display the image from the front camera on the screen and we already have a fully functional mirror.
    Moreover, when the tablet is turned off, it works like a mirror.
  • #3 15420385
    a_noob
    Help: 14
    Rate: 447
    Moreover, when the tablet is off, it works like a mirror.
    In my opinion, it is difficult to treat the tablet as a mirror, no matter if it is turned off or using the camera, it is quite a poor option and only an emergency, not at home where a normal mirror is not a problem.
    Second thing ... crushed ?! express ?! app ?! Oh man, I don't even know what forum to send you with this ...
  • #4 15421806
    szikaka
    Rate: 8
    After all, this DIY is not an obstacle to make some extra interactions, although touch is a weak idea, capacitive will not work for obvious reasons, resistive will also reduce the amount of reflected light ... but since it's a raspberry, there is nothing to prevent you from recognizing gestures, e.g. camera, or use some cheap gesture sensor, e.g. APDS-9960
    I didn't understand it at all, too, the camera as a mirror? bad idea
  • #5 15430191
    68mustang
    Rate: 10
    1. Even a million megapixel camera will not replace a mirror.
    2. What I like about the design is that the entire application is just a website. So I wonder if it is possible to replace raspi with something cheaper and maybe without Linux on SD because there are several power cuts and you have to install raspbian from scratch.
  • Pi Zero replacement and read-only filesystem for power cuts
    #6 15430417
    szikaka
    Rate: 8
    You can :) e.g. Pi zero :)
    As for the file system, after the configuration, it does not have to write anything on the card, so the file system will not crash
    https://www.sparkfun.com/news/2031
  • #7 15431652
    mamakapcia
    Help: 12
    Rate: 64
    I was interested in chromium in kiosk mode. Unfortunately, during the installation, something like this pops up:
    Does anyone know how chromium can be installed?
  • Suggesting apt-get update and alternative weather APIs
    #8 15431693
    68mustang
    Rate: 10
    Give it a try
    sudo apt-get update
    and try again. Or browse here: https://www.raspberrypi.org/forums/viewtopic.php?t=121195
    Anyone know how to change the weather api to some other? Because openweather doesn't work at all. Better some weather.com or something ...
    It's also cool: https://medium.com/@maxbraun/my-bathroom-mirror-is-smarter-than-yours-94b21c6671ba#.1lv4raa1b
    but I did not find the code; /
  • Chromium autostart commands fail after Raspberry Pi reboot
    #9 15432837
    mamakapcia
    Help: 12
    Rate: 64
    68mustang wrote:
    Thanks, the instructions on this link worked.
    However, I ran into another problem:
    I am adding a line to / etc / xdg / lxsession / LXDE-pi / autostart:
    However, after restarting, chromium does not start. This combination also doesn't work:
    @chromium-browser --kiosk --incognito http://localhost
The discussion revolves around building a "magic mirror" using a Raspberry Pi, emphasizing the need for a translucent mirror that functions as both a reflective surface and a display for information when illuminated. Participants suggest various components, including a thin monitor, wood for the frame, and the Raspberry Pi itself. They explore the possibility of adding interactivity through touchscreens or gesture recognition, although concerns are raised about the practicality of using a tablet as a mirror. Technical challenges such as installing Chromium in kiosk mode and changing weather APIs are also discussed, with users sharing solutions and troubleshooting tips.
TL;DR: Building a Raspberry-Pi magic mirror weighs about 6.5 kg and, as the maker says, "the system worked flawlessly" after final tweaks [Elektroda, ghost666, post #15415875] Expect a side-mounted 24″ 1080p monitor, a two-way mirror, and kiosk-mode Chromium. Why it matters: It turns a plain mirror into a real-time info dashboard for under €250.
• Weight: 6.5 kg finished unit [Elektroda, ghost666, post #15415875] • Housing footprint: 556 × 323 × 46 mm + 6 mm glass [Elektroda, ghost666, post #15415875] • 24″ 1080p LED monitor price: €110–€150 (EU retail) [PriceSpy, 2023] • Raspberry Pi 3B power draw: 2.5 W idle, 5 W load [Raspberry Pi Docs, 2023] • Two-way acrylic mirror sheet: approx. €60 per m² [PlasticsWorld, 2023]
What type of mirror do I need for a magic mirror?
Use a two-way (Venetian) mirror that looks like normal glass when the screen is black but lets light through when lit [Elektroda, ghost666, post #15415875] Ask glass suppliers for "spy" or "observation" mirror; 3–4 mm thick panes balance strength and weight.
Which monitor works best and how thin should it be?
A 24″ Iiyama E2481HS-B1 without its plastic shell measures about 10 mm thick; total depth after controller boards is 46 mm [Elektroda, ghost666, post #15415875] Side-facing ports avoid cable bulges, and 250 cd/m² brightness penetrates the mirror well.
How do I rotate the display in Raspbian?
Open /boot/config.txt and add display_rotate=1, then reboot. The screen switches to 1080 × 1920 px portrait instantly [Elektroda, ghost666, post #15415875] Comment out hdmi_force_hotplug=1 to keep HDMI always active.
How can I run Chromium in full-screen kiosk mode at startup?
Edit /etc/xdg/lxsession/LXDE-pi/autostart.
  1. Comment out @xscreensaver -no-splash.
  2. Add: @xset s off @xset -dpms @xset s noblank @chromium --kiosk --incognito http://localhost
  3. Reboot. Chromium launches borderless after login [Elektroda, ghost666, post #15415875]
Can I replace the Raspberry Pi with something cheaper?
Yes. A €5 Pi Zero can serve the site if you add a mini-HDMI adapter and USB-Ethernet/Wi-Fi dongle [Elektroda, szikaka, post #15430417] Any board that runs a web browser and outputs 1080p works.
How do I minimise SD-card corruption after power cuts?
After setup, mount the filesystem read-only so Raspbian stops writing logs. Power interruptions then leave it intact [Elektroda, szikaka, post #15430417] You can still remount rw for updates.
Is touch or gesture control possible through the glass?
Capacitive touch fails through 3 mm glass; resistive films dim reflection [Elektroda, szikaka, post #15421806] Add a $4 APDS-9960 gesture sensor or a USB camera with OpenCV to read hand waves instead.
How do I swap OpenWeather for another weather API?
Sign up for WeatherAPI.com or Weather.com, fetch JSON, then adapt the JavaScript parser. Replace the OpenWeather URL in your AJAX call; the rest of the site stays unchanged. Average daily API limit: 1,000 calls free tier [WeatherAPI Docs, 2023].
Why not just use a tablet with the front camera?
A camera image lacks true reflection and shows latency; "even a million megapixel camera will not replace a mirror" [Elektroda, 68mustang, post #15430191] Tablets also dim when idle and scatter light differently.
How heavy is the finished mirror and how do I mount it?
The prototype weighs 6.5 kg [Elektroda, ghost666, post #15415875] Use two wall anchors rated ≥15 kg into studs or brick; add a French cleat for easy removal.
What common failure should I watch for?
Edge-case: the integrated USB supply smoked and blew the apartment fuses after 10 minutes of use [Elektroda, ghost666, post #15415875] Always insulation-test custom mains work and choose CE-marked chargers.
How do I install Apache and PHP on the Pi?
Three-step quick start:
  1. sudo apt-get update && sudo apt-get upgrade ‑y
  2. sudo apt-get install apache2 apache2-utils apache2-doc
  3. sudo apt-get install libapache2-mod-php5 php5 php-pear php5-xcache Reboot; index.php in /var/www displays instantly [Elektroda, ghost666, post #15415875]
What is the total cost range to build one?
Two-way mirror €60, used 24″ monitor €120, Raspberry Pi 3B €45, wood/paint €20, cables €5. Total ≈ €250 before sensors [PriceSpy, 2023].
How do I prevent the electronics from overheating inside the frame?
Drill ventilation holes along the top and bottom edges; ghost666 added about 20 staggered holes and reported no overheating after hours of use [Elektroda, ghost666, post #15415875]
