Parking Sensor Squealing Constantly on Corolla E12: Causes, Wire Issues & Troubleshooting Tips
tomybb 31470 6
  • Unshielded sensor wire may cause false obstacle detection
    #1 16752163
    tomybb
    Rate: 1794
    Corolla E12 with reversing sensors installed in the Dealership. The sensors were working properly until the rear bumper was removed. During disassembly of the bumper, one of the wires the sensors stopped off, it was a few-centimeter cable but not shielded, after mounting this sensor all the time as if it detects an obstruction, activates squeal even when there is nothing in the back of the car - or the reason may be the use of these few centimeters unshielded cable? How to check it carefully, when I eject one sensor from the circuit, the system will be as if it signaled an obstacle? because that's what happened to me when I had unplugged all - after turning on the backward one always crying at max.
  • #2 16752201
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. I suggest to replace the entire sensor. Most likely it is damaged.
  • #3 16752217
    tomybb
    Rate: 1794
    How to deactivate one sensor somehow? because the release itself will not solve the problem? Insert a resistance?
  • #4 16752234
    Pedros050
    Help: 2471
    Rate: 3926
    It is better to replace the defective sensor with a new one. Each parking sensor system has its own test mode, so you can check which sensor has failed. Replace it yourself or drive up to almost any mechanic who will do it often while you wait, and you will leave the workshop with an efficient system of parking sensors.
  • #5 16752318
    tomybb
    Rate: 1794
    With the exchange just no problem I can do it alone, the only issue is to get such a sensor. Can it be any I find with the same dimensions or something different? Do you think that extending this sensor with a few centimeters of unscreened cable was not important for its faulty operation?
  • #6 17475017
    Uki93
    I have the same problem with sensors. Could you hint whether to replace the faulty sensor you need to pull the entire bumper, or just pull the sensor firmly? Thank you in advance.
  • #7 17475043
    Pedros050
    Help: 2471
    Rate: 3926
    You better take off the bumper. Because you can damage it.
The discussion revolves around a parking sensor issue on a Toyota Corolla E12, where the sensors began to malfunction after the rear bumper was removed, leading to constant squealing as if detecting an obstruction. The problem is suspected to be related to a damaged wire, specifically a few centimeters of unshielded cable. Suggestions include replacing the faulty sensor, as each parking sensor system has a test mode to identify failures. Users also discuss the feasibility of replacing the sensor without removing the entire bumper, with recommendations leaning towards bumper removal to avoid damage.
