[Solved] Corolla E12 1.6 2002. - vibrations on the floor and engine hum
xevirix 8730 10
Why does my Toyota Corolla vibrate and hum through the floor at about 3200–3500 rpm in every gear, even though the engine idles normally?
The cause can be the metal shield protecting the fuel tank, not the engine itself; in this case the front mounting lug had rusted/broken off, so the plate vibrated and the noise felt like it came from the engine [#17367527] When the shield was wedged or secured so it could not rattle, the vibration and hum disappeared completely [#17367527] The same problem was later confirmed as being caused by the metal sheet protecting the tank from heat [#17506511]
  • #1 16225443
    xevirix
    Good evening, I wanted to present the problem because neither I nor my mechanic can handle it. It is a Toyota Corolla e12 1.6 110km car and driving at a rotational speed of 3.5 thousand (in fifth gear about 120 km / h), in this range it is impossible to drive the engine hums and there are vibrations on the floor, you have to drive either slower or faster. The mechanic looked at the exhaust system, engine cushions and claims that everything is ok. Anyone with a problem how to solve it?
  • #2 16225498
    Damnian
    Help: 193
    Rate: 89
    And the catalyst is there?
  • #3 16225515
    tkaczu1
    Help: 22
    Rate: 92
    A part vibrates and transfers it to the floor, just as if the wheels are unbalanced at a certain speed, the vibrations are transferred to the steering wheel. It could be a broken bearing or cushions under the engine, or whether the effect occurs when the engine is stationary at this speed.
  • #4 16229728
    xevirix
    The catalyst is there. After today's tests, engine hum and vibration on the floor occur at 3200-3300 rpm in each gear. There is no problem on idle. It is difficult to diagnose because I commute to work every day and I have no way to leave the car with a mechanic for longer. The car has no power drop. I can also exclude tires / rims because it was the same on summer ones
  • #5 16707580
    darko04
    I have a question if you have already solved your problem because I have a similar one and I don't know what it might be
  • #6 16716772
    gregorius-up4
    Rate: 16
    Do you have any play on the long driveshaft.
    Maybe your inner joint is damaged and the driveshaft gets run out
  • #7 16788867
    darko04
    I just checked the internal joint and it has slack and the rubber is cracked after that, I made an appointment with the mechanic after November 11 and we will see if it helps
  • #8 17052808
    RobertW4
    Hi, have any of the men dealt with the problem with me it started the same? best regards
  • #9 17367527
    wiechu12
    I warmly welcome. Anyone else interested in solving the problem described in the post? I am asking because I see the last post from February. I had the same and after many months I solved the problem and it was prosaic. Metal covering the fuel tank was vibrating. The front lug securing it to the chassis has broken off (actually rusted). Putting even a stick between the tank and this plate (let it not be loose) resulted in the complete silence that I had been looking for for several months and the lack of vibration. Of course, you have to add an ear in a more professional way than with a stick. I know, it seems strange because the plate is not very thick, the vibrations seem to come from the vicinity of the engine and for these reasons I did not even look for the causes of the vibrations that appeared in me at 2800-3000 in all gears when the valve timing was just changed. Let me know if I helped anyone. Best regards.
  • #10 17506511
    xevirix
    The reason was the metal sheet protecting the tank from temperature
  • #11 17506513
    xevirix
The discussion revolves around a 2002 Toyota Corolla E12 1.6 experiencing vibrations on the floor and engine hum at specific RPMs (3200-3300) while driving. The owner and a mechanic have inspected the exhaust system and engine mounts without finding issues. Suggestions include checking the catalytic converter, driveshaft play, and inner joint condition. One user resolved similar vibrations caused by a rusted metal cover securing the fuel tank, which was misdiagnosed as engine-related. The solution involved stabilizing the metal cover to eliminate vibrations.
