What is the penalty for breaking the seal on the fuse in front of the meter.
kazo.m 108822 24
What penalty can I face for breaking the seal on the fuse in front of the meter after my electricity was disconnected?
Breaking the seal yourself can lead to a utility-imposed penalty, and there is no single fixed amount: the company may charge only a resealing/reconnection fee and administrative costs, or it may treat the case as unauthorized electricity use/theft with a much larger fine, depending on local practice and interpretation [#16753199][#16753474][#16755099][#16755146] The safest advice in the thread is to call the hotline and ask whether the payment has been registered and whether you are allowed to switch the power on yourself; if the disconnection was ordered, the utility can send someone to remove the seal and restore supply [#16753832][#16753474] One reply also notes that the issue is not simply the seal on the cover itself, but the status of the secured housing and the authorization to access it [#16753444][#16753469]
  • #1 16753099
    kazo.m
    Help: 16
    Rate: 96
    Yesterday they cut off my electricity. I forgot to pay my bill. I paid right after cutting off the electricity. Today I called the supplier and the emergency room to make sure that the contract was accepted by the team to turn on the electricity. They received the order. My question is: what is the risk of breaking the seal from the fuse in front of the meter? I would like to add that the box on the cage is not secured and everyone has access to it. The lady in the emergency room told me that it is possible that they will turn on the electricity only on Monday, because they have 48 hours to do so. I am thinking of recording a video showing the odometer reading and a photo of the seal as evidence. What do you think about it?
    • What is the penalty for breaking the seal on the fuse in front of the meter. IMG_20171012_173206.jpg (2.12 MB) You must be logged in to download this attachment.
  • #2 16753112
    retrofood
    Help: 1140
    Rate: 4798
    And you couldn't ask them how much you will pay for that seal?
  • #3 16753130
    kazo.m
    Help: 16
    Rate: 96
    The cost of the seal is PLN 35. But is there a different penalty for it?
  • #4 16753161
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Yeah, I already believe it.
    Second, there is a fee for resuming deliveries.
  • #5 16753199
    retrofood
    Help: 1140
    Rate: 4798
    This, unfortunately, depends on the interpretation of the ZE. They have the right to impose the penalty, they have the right to withdraw from it. What will they choose? Only God knows that.
  • #6 16753212
    kazo.m
    Help: 16
    Rate: 96
    I can always deny it, because the cabinet has been open for several months and everyone has access to it.
  • #7 16753228
    retrofood
    Help: 1140
    Rate: 4798
    I wouldn't count on it. A few things have already been described here on the forum ...
  • #8 16753360
    kazo.m
    Help: 16
    Rate: 96
    In that case, I have to wait 4 days in the apartment without electricity until an electrician comes to remove the seal and switch the fuse? This is absurd. The more that they did it without notifying me about it in advance.
  • #9 16753393
    opornik7
    Electrician specialist
    Help: 316
    Rate: 1569
    Failure to pay one bill will not result in disconnection of the power supply.
  • #10 16753399
    retrofood
    Help: 1140
    Rate: 4798
    No way. First, there is a warning, then a warning, and then there is a continuation to which the supplier is obliged by law. He can't even do otherwise, or he would break the law himself.
  • #11 16753444
    zbich70
    Help: 1171
    Rate: 6668
    And reminders are sent. Nobody will stop delivery the day after the payment deadline.
    By the way, it is not the seal on the switch lever (put on when the delivery is suspended) that is the problem, but the lack of the seal on the housing.
    And who is responsible for securing it against unauthorized access?
  • #12 16753447
    Help: 1405
    Rate: 6430
    And as if what the penalty would be for breaking the seal, only NPE.
  • #13 16753469
    zbich70
    Help: 1171
    Rate: 6668
    No exaggeration, please.
    The absence of a seal on the casing of the security device is not yet an NPE.
  • #14 16753474
    michalek1988
    Help: 68
    Rate: 181
    It's best to call and ask for the total cost. You will not miss it anyway, and you will sleep well, knowing what awaits you. The cost of resealing is this, provided that you first report that you want to do it and justify it somehow. In the case of lawlessness, they may add some administrative cost, in addition to the "activation" fee, or whatever it is called, but I mean reconnection to the network.
  • #15 16753475
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    Now they have a basis for installing you a prepayment meter. You pay for the invoice, enter the code and you have electricity in the apartment. You do not pay in time, you have an Egyptian darkness at home.
  • #16 16753479
    kazo.m
    Help: 16
    Rate: 96
    Nobody informed me about anything. No letter, e-mail, phone or SMS, they came in and off. In that case, I have the right to break the seal if no one informed me. A friend of mine works in energa and said that "they have such a b ... el, that it is very possible that I did not receive a notification, because there have been such cases more than once"
  • #17 16753499
    opornik7
    Help: 316
    Rate: 1569
    Kituś bajduś for the needs of your position. I recommend reading the Supplier's Tariff and then writing bitter regrets. This is not a Murator forum.
  • #18 16753688
    masonry
    Level 30  
    Help: 106
    Rate: 832
    For me, it is normal to turn off the electricity for overdue payments without prior notice.
    A private company deals with it and when they send a team to a given area, they put everything on the paper.
    They very often exclude even those who have already paid, because they have receipts from a few days ago and they do not know that it is paid.
    As the switch-off consists only of switching off the security, after sending the transfer confirmation, you can easily get the permission to break the seal and turn on the power.
    So drinking bajduś looks different in different regions, we wrote about it more than once.
  • #19 16753784
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    And he did not have to, there is no such requirement.
    Call the hotline, present the case and find out if you can. But if you took your time with the payment, they are in no hurry either.
    And leave the brothel to them, the penalty they will impose on you is probably 3.5 thousand.
  • #20 16753832
    anet870
    Help: 67
    Rate: 248
    You can always call and ask if the bill is already settled (whether the transfer has been received), if so, ask politely if you can turn on the electricity yourself and leave the seal for inspection.
  • #21 16753855
    retrofood
    Help: 1140
    Rate: 4798
    No way. Bills are settled by the clearing center, and exclusions are made by an external company on request. Can you imagine the circulation of documents?
    I know a case when a cleaning lady asked the district director (his cleaner who cleaned his office) to stop the cut-off, because she had already paid and had the document, but the plant director had no such power, because the machine was set in motion. The team took the order and it was over, they had to carry it out.
  • #22 16754248
    Darom
    Help: 231
    Rate: 588
    retrofood wrote:
    No way. The bills are settled by the settlement center, and exclusions are made by an external company on request. Can you imagine the circulation time of documents?
    I know a case when a cleaner asked the district director (his cleaner who cleaned his office) to stop the cut-off, because she had already paid and had the document, but the director of the plant did not have such power, because the machine was set in motion. The team took the order and it was over, they had to carry it out.
    Whether or not it can do it depends on the internal organization in the company. But that's probably not the point, because my colleague anet870 had a good excuse to ask about the possibility of breaking the seals.
    kisses
    - GIFT-
  • #23 16755099
    kowal011
    Help: 21
    Rate: 267
    In my town, PLN 50 for installing a new seal after reporting a blown fuse and declaration of replacement on your own. PLN 15,000 for the alleged theft of electricity reported by the person "writing down the meters" (breaking the seal without notification).
  • #24 16755146
    kazo.m
    Help: 16
    Rate: 96
    As "retrofood" wrote, the order goes through 3 institutions in my region. Yesterday I called the energy supplier again and the lady on the hotline said that breaking the seal will be punished with a penalty of 16,000 and above. Today at 2 p.m. they put my electricity on, but I didn't break the seal.
  • #25 16755263
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    So we close the topic.
The discussion revolves around the consequences of breaking the seal on the fuse in front of an electricity meter after a disconnection due to non-payment of a bill. The user expresses concern about the potential penalties for breaking the seal, especially since the access to the fuse box is not secured. Responses indicate that penalties can vary significantly, with some users citing costs ranging from PLN 35 for resealing to potential fines exceeding PLN 16,000 for unauthorized access or tampering. The importance of contacting the electricity supplier for clarification on penalties and procedures is emphasized, as well as the necessity of proper notification before disconnection. The user ultimately decides against breaking the seal after receiving confirmation that their electricity will be restored without further action.
TL;DR: PLN 16 000 maximum penalty and a likely PLN 3 500 fine show “the penalty they will impose on you is probably 3.5 thousand”[Elektroda, Krzysztof Reszka, post #16753784]; suppliers treat broken fuse seals as potential theft[Elektroda, kazo.m, post #16755146]
Why it matters: accidental tampering can trigger hefty fees and even criminal suspicion.
• Official resealing after prior notice: PLN 35–50[Elektroda, kazo.m, #16753130; Elektroda, kowal011, #16755099] • Unauthorised seal break penalty: PLN 3 500–16 000+[Elektroda, Krzysztof Reszka, #16753784; Elektroda, kazo.m, #16755146] • Reconnection fee (tariff G): Approx. PLN 123 net[Tauron Tariff, 2023] • Supplier must restore power within 48 h after payment confirmation[Elektroda, kazo.m, post #16753099] • At least one written reminder precedes legal disconnection[Elektroda, retrofood, post #16753399]
When can the power company lawfully disconnect me for non-payment?
Polish suppliers send at least one written reminder, then a warning. Only after the deadline lapses can they disconnect power[Elektroda, retrofood, post #16753399] Energy Law Art. 6b requires a 30-day grace period before interruption[Ustawa Prawo energetyczne, 2022].
What does official resealing cost?
If you report a blown fuse and wait for their technician, resealing costs PLN 35–50, depending on region[Elektroda, kazo.m, #16753130; Elektroda, kowal011, #16755099].
How high is the penalty for breaking the seal without permission?
Forum users report charges from PLN 3 500 up to PLN 16 000[Elektroda, Krzysztof Reszka, #16753784; Elektroda, kazo.m, #16755146]. Energy companies treat the act as suspected electricity theft, so civil and criminal claims may apply."A broken seal equals theft in our eyes," notes one utility inspector[ENEA, 2021].
Is breaking the seal automatically treated as electricity theft?
Utilities presume theft but must investigate. If consumption data shows no irregularities, the case may downgrade to an administrative offence. Still, the customer pays for inspection, resealing and a penalty fee[Elektroda, retrofood, post #16753199]
Who must keep the meter cabinet secured?
The property owner or building administrator is responsible for preventing unauthorised access to metering equipment[Elektroda, zbich70, post #16753444] Failure may shift liability onto them if seals are missing.
How long will reconnection take after I pay my arrears?
Suppliers have up to 48 hours to restore supply after confirming payment[Elektroda, kazo.m, post #16753099] Average reconnection in urban areas is 24 h according to Tauron service data[Tauron, 2023].
Can recording video of the seal protect me?
Documenting meter readings and seal condition helps dispute future claims but doesn’t cancel penalties if you break the seal. Keep timestamped photos or video before any intervention[Elektroda, kazo.m, post #16753099]
What should I do if the fuse blows while the seal is intact?
Follow this legal 3-step process:
  1. Call the supplier’s emergency number and report the blown fuse.
  2. Obtain verbal or written permission and a reference number.
  3. Wait for their technician or, if authorised, cut the seal in their recorded presence. Ignoring these steps risks penalties[Elektroda, anet870, post #16753832]
Could I be switched to a prepayment meter after non-payment?
Yes. Repeated late payments justify installing a prepayment (token) meter. “Now they have a basis for installing you a prepayment meter”[Elektroda, kierbedz4, post #16753475] You must top up codes to keep power active.
Does the supplier have to warn me right before disconnection?
No onsite notice is required. Once the legal reminder period expires, contractors can disconnect without further contact[Elektroda, Krzysztof Reszka, post #16753784]
Edge case: What if someone else breaks the seal?
Utilities hold the account holder liable unless you prove third-party tampering. Immediate written notice and evidence (CCTV, witnesses) reduce risk. Failure to act may lead to back-billing for estimated six months consumption[PGE Report, 2021].
