Locating Fault on Asus X540SA Rev.2.0 - Power Button Non-Responsive, uP0132p Element Heating Up
najdzik 5259 8
  • #1 16754602
    najdzik
    Rate: 24
    I have a small problem in locating the fault on Asus X540SA Rev.2.0
    The disc does not respond to the POWER button
    From what I noticed after connecting to the power supply, the element marked uP0132p warms up and with it the processor gently warms up
    Power consumption ranges from 0.4-0.5A
    Due to the lack of a schema, I have difficulty locating the problem.
    Thanks in advance for your help
  • #2 16754628
    ul1002
    Help: 303
    Rate: 138
    Do you have any jumpers behind the coil near this system? How to bend and measure what this inverter gives you but how do I know this crap is one half ST-BY or 3.3V or 5V.
    Almar Serwis Roland Piszczelok
    Gliwicka, Rybnik, 44-200 | Tel.: 506XXXXXX (Show) | Company Website: www.almar-serwwis.pl
  • #3 16754635
    najdzik
    Rate: 24
    There is one jumper and after its desoldering the system gives 1.85V
    There is no short to ground on the other side
  • #5 16754652
    najdzik
    Rate: 24
    I will add that the main converter is working properly
  • #7 16754748
    najdzik
    Rate: 24
    After uncracking, the UV is not heating up.
    After connecting the power, all the inverters work, except that on the coil of one, the voltage drops from 0-1,3V
    This is probably a processor converter
  • #9 16754850
    najdzik
    Rate: 24
    The core is OK. I suspected SR29H damage and now I am more convinced about it
    Added after 35 [minutes]:
     Okay now I know for sure that BGA is damaged.
    The system mentioned at the beginning of the uP0132p was overloaded by a damaged BGA chip.
    This system probably powers the graphics section in SR29H
    I leave the repair decision to the owner
The discussion revolves around troubleshooting a non-responsive power button issue on an Asus X540SA Rev.2.0 laptop. The user notes that the uP0132p component heats up upon power connection, with a power consumption of 0.4-0.5A. Various responses suggest checking jumpers and inverters, with one jumper yielding 1.85V after desoldering. The user confirms that after further testing, the uP0132p does not heat up when the inverter is uncracked, but voltage drops on one coil, indicating a potential issue with the processor converter. Ultimately, the user identifies a damaged BGA chip as the likely cause of the overheating and power issues, which may affect the graphics section.
