Opel Corsa C 1.3 CDTI 70KM: Timing Chain Issues Post Dual Mass & Clutch Regeneration
Uba86 8013 5
  • #1 16755631
    Uba86
    My problem started with replacing the mass flywheel and clutch. The wheel began to jerk and the car's mileage was already 176,000 km. I decided to regenerate the dual mass and clutch. The car was returned to the mechanic, where they removed the dual mass and clutch, sent for regeneration and put it back after the regeneration. After this treatment, the car started to have problems that were not there before, i.e. sometimes it did not start and when it started, it shook and went out. It happened sporadically until it refused to fire at all. Finally when it fired it shuddered and made noise. No power etc.
    A few days later I arrived at the garage where it turned out that the timing was broken and all the rocker arms were ground. After replacing the camshaft, levers, filters and oil, the car worked as before, but the problem with firing remained. It was possible to drive the car for 3 weeks (600 km) and then the problem returned. Experts found that the chain was pulled out because it was not branded (ruville). They gave their original one and everything was ok. After this exchange, I drove 5 days (250 km) and the problem returned today.
    My question is:
    - Could the reason for this be a poorly complex dual mass? I would like to add that the clutch is strong, there are no vibrations on the pedal of the clutch and no noise.
    -New starter,
    - New timing
    - New oil pan
    - Filters and oil
    Currently no power, metallic noise, smoke. No check engine.
  • #2 16755657
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The wheel has been regenerated or a rigid wheel has been installed?
  • #3 16755676
    Uba86
    Regenerated. The clutch too. I sent them to a company in Łódź, I think.
    Added after 4 [minutes]:
    The company is called Avanti.
  • #4 16759894
    Uba86
    Will no one help me?
  • #5 16759935
    szymitsu21
    Help: 343
    Rate: 1300
    dwumas is the culprit ..
    it does not regenerate because it never works properly.
    the cheapest Chinese chain will last more than 600km ...
  • Timing chain stretch and tensioner misalignment suspected
    #6 16760543
    Somebody22
    Rate: 25
    The symptoms indicate a misalignment.
    Were the gears replaced with the timing gear? Has everything been timed right? If the chain is pulled out, it may indicate that it is in a wrong tension, or an element is too resistant. If only the chain jumps, the fault is too low oil pressure on the hydraulic tensioner.
