Opel Corsa D 1.2 - Uneven engine operation + incorrect firing
Jazo90 15567 12
Why does an Opel Corsa D 1.2 run unevenly and choke on cold start even after new spark plugs and an oil filter?
Check the ignition system first: in these engines the coils and/or coil boots often fail, and replacing the boots is cheap [#17328897] Also have the camshaft clearance checked, because similar symptoms have been seen from incorrect clearance in these engines [#17329705] Another reported cause is a faulty ignition cassette or a dropping airflow meter/MAF [#17335495] If the engine is a Z12EXP, clean the throttle body and replace the air filter [#17335684] For the cold-start clatter, the most likely explanation in the thread is a timing chain/tensioner issue: the noise appears right after starting, when oil pressure is still building, and the tensioner may tighten the chain only after pressure rises [#17339473]
  • #1 17328784
    Jazo90
    Hey,
    at the beginning I would like to say hello and write that I never thought that I would set up an account here, but recently I bought my first car and I am quite concerned about the engine work, but from the beginning ...
    I replaced all the candles, plus filter oil. The 2008 Corsa with a mileage of 86k miles, the timing chain was not replaced, but the engine is not yet like a tractor.
    Now what's going on, although I realize that it will be hard to describe. The engine does not run evenly, it does not lose power while driving. When it slackens gently in place, everything seems fine. Such engine operation is always important, no matter if the engine is warm or cold. I don't think it's a timing. This is the first ailment. On the other hand, number two is the engine every time I don't know ... coughing, choking on the first start on a cold engine? When the car is warmed up, everything is fine.
    I will report to the mechanic anyway, but I would like to know more or less what t can be. Thank you in advance for your help.
  • #2 17328897
    decybel91
    Help: 1024
    Rate: 4231
    Very often coils and / or coils pipes sit down. Look for about 30 PLN / pcs of pipes on the Internet.
  • #3 17329705
    rowerek0987
    Just out of curiosity, check the camshaft clearance. I have already seen two such cases in these engines.
  • #4 17335495
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 489
    As the previous speaker said. Or the ignition cassette for replacement, but also in these engines, the fallen flow gives such symptoms
  • #5 17335684
    Sekoro
    Rate: 19
    If you have a Z12EXP engine try to clean the throttle and replace the air filter, it used to help me once ;)
  • #6 17339192
    Jazo90
    Thanks gentlemen, I will definitely look at everything for the weekend. In the meantime I throw a video about how the cold engine starts.
    I noticed that I also sometimes hear such ticking and also only on a cold engine when I am driving.
    • 20180715_190243.mp4 (58.84 MB) You must be logged in to download this attachment.
  • #7 17339229
    rowerek0987
    This wheel of variable camshaft phase had in Renault on a cold start like an old diesel like yours. After the exchange, everything was perfect.
  • #8 17339418
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 489
    But there is no wheel of variable timing phases.
  • #9 17339473
    rowerek0987
    Sorry I didn't read it actually isn't. But it sounds identical. only the timing remains to be checked, because in my opinion the tensioner is damaged, the problem occurs immediately after firing when the oil pressure is just rising, as if the tensioner works with a delay and tightens the chain only after reaching full pressure. And when the engine comes with such a loose chain, the valves run with a slight delay and only after a while everything normalizes, hence this sound may be wrong but for me it is the only rational explanation.
  • #10 17341768
    Jazo90
    If it's a tensioner, is it a problem that I should worry about at the moment? Overall, I planned to change the timing belt with the pump next year. This is my first car and I prefer to take care of it, even though it's already old.
    As for Meganki, my dad had Renoult and the engine sounded exactly like Corsa. It turned out that the timing was already falling apart and there was probably something with the head gasket.
  • #11 17341881
    tzok
    Help: 3176
    Rate: 6549
    You mean that clatter after starting the engine?
  • #12 17341957
    Jazo90
    Yes, that's exactly what I mean, because in general the engine works well. It is known, sometimes I hear some strange ticking, like clockwork, but also when the engine is cold, but I realize that the car is already old.
  • #13 17342663
    tzok
    Help: 3176
    Rate: 6549
    They are not hydraulic tappets? What happens to the oil pressure during and just after starting the engine?
The discussion revolves around issues with a 2008 Opel Corsa D 1.2, specifically uneven engine operation and incorrect firing. The owner has replaced spark plugs and oil filter but continues to experience rough idling and cold start problems, characterized by coughing and choking. Suggestions from forum members include checking ignition coils, camshaft clearance, and the ignition cassette. Cleaning the throttle and replacing the air filter are also recommended. Concerns about the timing chain tensioner are raised, with indications that it may be causing noise and delayed valve operation upon starting. The owner plans to consult a mechanic and is considering timing belt replacement in the future.
TL;DR: Coil boots cost ~30 PLN each and "Very often coils and/or coil pipes sit down." Rough idle and cold-start clatter on Corsa D 1.2 often trace to ignition cassette/boots, airflow meter, dirty throttle, or a lazy chain tensioner. [Elektroda, decybel91, post #17328897]
Why it matters: Quick, low-cost checks can prevent misfire damage and avoid unnecessary timing work for Corsa D 1.2 owners seeking fixes.
What are the most likely causes of uneven idle/misfire on a Corsa D 1.2?
Start with ignition. The cassette (coil pack) and coil boots commonly fail and cause misfires. A fallen airflow meter (MAF) can produce similar symptoms. Prioritize inspecting coils/boots, then verify MAF readings or substitute with a known-good unit. These two items explain many rough-idle cases on the 1.2. [Elektroda, lukasz12345678910, post #17335495]
How do I quickly check the ignition cassette and coil boots?
Try this 3-step check:
  1. Remove the cassette and inspect boots for cracks, tracking, or oil.
  2. Swap in a known-good cassette if available to A/B test.
  3. Replace damaged boots first; they cost about 30 PLN each. "Very often coils and/or coil pipes sit down," so start here. [Elektroda, decybel91, post #17328897]
Can a dirty throttle body or air filter cause rough idle on the 1.2 ("Z12EXP")?
Yes. Carbon on the throttle plate and a clogged air filter can destabilize idle airflow. Cleaning the throttle body and installing a fresh filter has restored smooth idle for owners of this engine. Use throttle-body cleaner and avoid forcing the plate. Relearn idle if needed after cleaning. [Elektroda, Sekoro, post #17335684]
Why does my Corsa D 1.2 clatter for a moment on cold start?
That brief clatter often points to a chain tensioner that tightens only after oil pressure builds. During the first seconds, the chain can run looser, affecting valve timing slightly. "As if the tensioner works with a delay and tightens the chain only after reaching full pressure." Have a mechanic confirm. [Elektroda, rowerek0987, post #17339473]
Should I worry about the timing chain tensioner now, or can it wait?
If clatter is brief and only on cold starts, monitor closely but schedule an inspection soon. If noise lengthens, appears warm, or misfires worsen, bring the visit forward. Addressing a lazy tensioner early can prevent timing deviations. Do not ignore a progressing rattle. [Elektroda, rowerek0987, post #17339473]
Do these engines have a variable valve timing (VVT) phaser that could rattle?
No. The engine discussed in this thread does not have a variable timing phaser wheel. If you hear start-up rattle, look at the timing chain tensioner or related components instead of a phaser. This avoids chasing a non-existent VVT issue. [Elektroda, lukasz12345678910, post #17339418]
Is light ticking on a cold engine normal hydraulic tappet noise?
It can be. Hydraulic tappets may tick briefly until oil pressure stabilizes after start-up. Verify oil pressure behavior during and just after starting if the ticking concerns you. Persistent ticking when warm warrants inspection of the valve train. [Elektroda, tzok, post #17342663]
Someone said to check camshaft clearance—should I?
Yes, if basic ignition and airflow checks do not fix the issue. A technician can check camshaft end play or related clearances. There have been cases where abnormal camshaft clearance contributed to running issues on these engines. Use this as a next-step diagnostic. [Elektroda, rowerek0987, post #17329705]
My Corsa coughs only on the first cold start, then runs fine—what should I check?
Check ignition first. Weak ignition cassettes or coil boots can misfire when cold, then stabilize. Also verify the airflow meter (MAF), as a failed sensor can disturb fueling on cold starts. Prioritize these two before deeper mechanical checks. [Elektroda, lukasz12345678910, post #17335495]
How much do coil boots cost, and is replacement DIY-friendly?
Expect around 30 PLN per boot. Replacement is straightforward: remove the cassette, pull old boots, push on new ones, and refit. Ensure boots seat firmly over the plugs. If misfire persists, test or replace the entire ignition cassette. [Elektroda, decybel91, post #17328897]
Could the airflow meter cause uneven running even without fault codes?
Yes. A weak MAF can skew airflow data and upset fueling without immediately setting a code. If idle quality improves with a known-good MAF, replace it. Address ignition first to avoid misdiagnosis, then verify the MAF’s contribution. [Elektroda, lukasz12345678910, post #17335495]
Does the 2008 Corsa D 1.2 in this thread use a chain or a belt?
This owner reports a timing chain that had not been replaced. Many Corsa D 1.2 variants use a chain, not a belt. Confirm your specific engine code to be sure before ordering parts or scheduling service. [Elektroda, Jazo90, post #17328784]
What simple maintenance can I try before seeing a mechanic?
Clean the throttle body with proper cleaner and fit a new air filter. This can stabilize airflow and idle on the "Z12EXP" engine. After cleaning, let the ECU relearn idle by idling without loads. Proceed to ignition checks if idle remains rough. [Elektroda, Sekoro, post #17335684]
How can I assess oil pressure’s role in start-up noise?
Observe oil pressure during and just after starting the engine. Low or delayed pressure can extend tensioner or tappet noise. If pressure is slow to rise, inspect the lubrication system and tensioner. This directs you beyond ignition-related causes. [Elektroda, tzok, post #17342663]
