Car Magnetic Holder - Worth it? Air Vent Mount, Safety & User Impressions Explored
geforc 5199 3
  • #1 16758803
    geforc
    Rate: 44
    Hello, does any of you use such a magnetic invention? mainly I mean one that is inserted into the air vents, nothing falls, is it safe ?? What are your impressions?
  • #2 16759322
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    The handle holds, nothing falls under one condition. The badge must be glued directly to the phone. Not on the cover.
  • #3 16759430
    geforc
    Rate: 44
    I have such a cover on the back that I put this badge between the phone and the cover, and how about holding it on the air vents?
  • #4 16761996
    buczo11
    Help: 60
    Rate: 121
    In the case of LG V10 backs are from so-called DuraSkin-porous material and the plaque hold very badly. Therefore, it was glued to a smooth case applied to the smartphone (the case adheres closely to the smartphone). However, the V10 is quite heavy and large, so unfortunately, with small bumps on the road, the magnet is not able to hold the smartphone, the magnets detach.
    In my case it completely failed. All you need is a minimal shift of the badge and the smartphone flies.
