Cross-Section & Maximum Current Capacity of Internet Twisted-Pair Cable: Insulation Removal Issues
smartfon 38664 17
Can I use internet twisted-pair cable to wire rear reversing and fog lights, and what is its conductor cross-section and current capacity?
A typical twisted-pair conductor measures about 0.45–0.511 mm in diameter, but the thread concludes that internet twisted-pair cable is not suitable for vehicle lighting because its insulation and mechanical strength are not intended for those conditions; use a proper automotive wire with the same cross-section as the original installation instead [#16761168] [#16761173] [#16761209] [#16761229] [#16761297] For current, one reply cites PoE as a comparison: a power pair carries 350 mA, and if the return is through the car body, 8 wires could theoretically carry 2.8 A without overloading the cable [#16761238]
  • #1 16761141
    smartfon
    Level 4  
    Hello. What cross-section has the cable from the twisted pair from the Internet? And what is the maximum current that can flow through it? I will add that it is difficult to remove the insulation squeegee because it also tears the cord (the squeegee has a minimum clamping value of 0.2mm2).
  • #2 16761168
    1repcaK
    Help: 52
    Rate: 123
    The diameter measured by callipers - 0.45 mm
  • #3 16761173
    Foxtrott
    Help: 253
    Rate: 944
    Core diameter = 0.511 mm
  • #4 16761183
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    Write whether it is pure curiosity or do you really want to use it and for which installation?
  • #5 16761200
    smartfon
    Level 4  
    I would like to use it to connect the rear reversing and fog lights. Light bulbs are one 21W and two 4W each. At the same time, this 21W or the two at 4 w can be lit, so the total load is 8W. Voltage 12V, or current at 21W is 1.75A, and at 8W 0.67A. Can it be done or not? It is worth noting that these lights are not constantly lit, and these wires from the twisted pair are about 7cm long, the rest of the installation is made by a factory-made cable, which is a bit thicker.
  • #6 16761209
    beatom
    Help: 421
    Rate: 877
    The diameter of the duct is not everything. In such applications, insulation must be adapted to the atmospheric conditions.
  • #7 16761229
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    Why do you want to use the twisted pair wire instead of the same cross-section of the wires that already exist in the original wiring installation and should be soldered and this should do the trick.
  • #8 16761238
    sanfran
    Help: 965
    Rate: 3006
    In the current PoE standard, the power pair carries 350 mA of current (15.4W at 44V).
    Considering that the current flows only one way because I assume that the return is through the mass of the vehicle, 8 wires give you the ability to send 2.8A without overloading the cable.
  • #9 16761247
    technikabasenowa
    Help: 138
    Rate: 445
    Dear author, saving has its limits
  • #10 16761248
    smartfon
    Level 4  
    I have a cable in the twisted pair and not a wire. It can not be used to directly solder wires because it would be uncomfortable. The plates are made of aluminum and you have to get a little tired to solder it.
  • #11 16761260
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    And the twisted pair which technique will you connect with the installation?
  • #12 16761262
    smartfon
    Level 4  
    2.8A for 8 zlotys, or 0.35A for a single vein? Is 2.8A per single vein?
  • #13 16761267
    technikabasenowa
    Help: 138
    Rate: 445
    Colleagues about what to debate here :D
    I think it's only when the new subject is going to be out of light :D
  • #14 16761281
    karolark
    Help: 702
    Rate: 2518
    Is not it better to make clips?
    The author do not go this way, do not go :D
  • #15 16761282
    smartfon
    Level 4  
    Let the great gentleman write what wire would be the most suitable for such installation? 0.75mm2?
  • #16 16761297
    karolark
    Help: 702
    Rate: 2518
    The answer is resist mechanical strength and good insulation
    twisted pairing is not suitable for this
    And the topic to the basket :D
  • #18 16761479
    radsat
    Moderator
    Help: 470
    Rate: 209
    3.1.17. Do not send very basic questions that can be found in the user manual or generally available sources. Do not present the attitude that I am due. Take care of the level of questions and discussions. Thank you.
The discussion revolves around the cross-section and maximum current capacity of twisted-pair cables used for internet connections. Users provide varying measurements for the core diameter, ranging from 0.45 mm to 0.511 mm. The author seeks to utilize the twisted pair for connecting rear reversing and fog lights, with a total load of 8W at 12V, which translates to a maximum current of 0.67A. Concerns are raised about the suitability of twisted pair cables for this application, with suggestions to use thicker, factory-made cables instead. The PoE standard is referenced, indicating that a power pair can carry up to 2.8A without overloading. The author expresses difficulty in removing insulation without damaging the cable, and alternative wiring solutions are discussed, including the use of clips and other types of cables.
TL;DR: A single CAT5/UTP conductor typically handles 350 mA; “the power pair carries 350 mA of current.” Use automotive‑grade wire for car lights. [Elektroda, sanfran, post #16761238] Why it matters: This helps DIYers decide if Ethernet cable can safely power 12 V lamps and what to use instead.
Quick-Facts
What cross‑section does a typical Ethernet twisted‑pair conductor have?
Using the posted 0.45 mm diameter, the area is about 0.16 mm² (A = π·r²). Treat this as an approximate value only. [Elektroda, 1repcaK, post #16761168]
How much current can one UTP conductor carry as a rough reference?
A commonly cited reference from PoE is 350 mA per powered pair path. This is a telecom context and not automotive. “The power pair carries 350 mA of current.” [Elektroda, sanfran, post #16761238]
Can I parallel multiple CAT5 conductors to reach around 1.75 A for a 21 W bulb?
Eight conductors at 0.35 A each imply 2.8 A total in that telecom example. Paralleling lowers resistance, but automotive conditions differ, so use proper automotive wire. [Elektroda, sanfran, post #16761238]
Is twisted‑pair cable suitable for exterior automotive lights?
No. It lacks the mechanical strength and insulation robustness vehicle harnesses require. “Twisted pairing is not suitable for this.” [Elektroda, karolark, post #16761297]
What wire should I use instead of Ethernet cable for car lights?
Match the existing harness cross‑section and use automotive‑grade insulation. Join like‑for‑like and make a quality soldered or crimped connection. [Elektroda, marqqv, post #16761229]
Why is stripping CAT5 conductors so difficult with a 0.2 mm² stripper?
The conductors are thin, and many strippers don’t adjust precisely at that size. The OP noted the insulation tears with small tools. Use a precision adjustable or thermal stripper. [Elektroda, smartfon, post #16761141]
Will 7 cm CAT5 pigtails overheat at 1.75 A?
The OP’s pigtails are about 7 cm. Short lengths reduce voltage drop, but heating risk remains if insulation and routing are poor. Prefer automotive wire. [Elektroda, smartfon, post #16761200]
Can I use the vehicle chassis as the return path for these lamps?
Yes, many circuits use chassis ground. The cited reply assumed return through vehicle mass; ensure clean grounds and corrosion protection. [Elektroda, sanfran, post #16761238]
How much current do my bulbs draw at 12 V?
From the OP: 21 W draws about 1.75 A, and 8 W draws about 0.67 A. Size wiring and protection to the highest expected current. [Elektroda, smartfon, post #16761200]
What’s the real risk of using Ethernet cable in a car even if it “works”?
Insulation not designed for oils, moisture, and temperature cycles can degrade and fail, causing shorts or intermittent faults. Choose automotive‑rated insulation. [Elektroda, beatom, post #16761209]
I must connect to aluminum parts—should I solder?
The OP notes aluminum is hard to solder. Prefer crimp lugs or mechanical fasteners with proper anti‑corrosion measures instead of ad‑hoc soldering. [Elektroda, smartfon, post #16761248]
What is CAN bus in cars?
CAN bus is a robust in‑vehicle network protocol that lets ECUs communicate over a shared two‑wire differential pair. [Wikipedia, 2024]
