Using Four Wires for a Network: Essential Twisted Pair Cable Conductors?
Kuniarz 85176 15
Can I build a working network over four intercom wires, and which conductors in a twisted-pair Ethernet cable are essential?
Yes—four wires can be enough for a 10 Mbit network, and for Ethernet the essential conductors are the two pairs on contacts 1, 2 and 3, 6. In T568B that is white/orange + orange and white/green + green, but the exact colors do not matter as long as each pair stays together [#929424][#929563][#1730699] A regular 4-wire telephone cable can work for 10 Mbit at short distances, and if the cable is actually twisted it may even carry 100 Mbit over about 60–70 m, but that is risky and not something to rely on [#929563][#929494] Ordinary intercom/telephone cable may suffer from interference and may be unsuitable even for 10 or 100 Mbit in practice [#929494] Using only two pairs also means you lose the option of gigabit Ethernet, because Gigabit Ethernet uses all four pairs [#929563]
  • #1 929378
    Kuniarz
    Moderator of Designing
    Help: 371
    Rate: 826
    I want to do a rather breakneck experiment, namely I have cables for intercoms in the tenement house, which probably will never be there, so I wanted to use them to build a small network for 4 computers, without straining myself with a drill. Now, the basic question, I have 4 wires for each apartment, so is it possible to make a working network on them? Which twisted pair cables really play a role?
    We will assume that a typical crimped twisted pair has the following sequence:
    - white and orange
    - orange
    - white and green
    - blue
    - White and blue
    - green
    - White-brown
    - Brown
    so which are ESSENTIAL?
    Greetings !
  • #2 929419
    pelcbog
    Rate: 29
    I am not an eagle in these matters, but I know from experience that four wires are enough for a 10 Mb network
    -white with blue
    -blue
    -white with green
    -green
    for sure you don't need a brown and orange pair when you are using a hub for splitting the joints.
  • #3 929424
    jaku
    Are needed:
    white - orange
    orange
    white-green
    green
    that is 1,2,3,6 only whether the wires are of the right category. Check it out.
  • #4 929429
    pelcbog
    Rate: 29
    I am sorry but I did not do the interleaving in the previous post
    -white with green
    -blue
    -white with blue
    -green
    "Jaku" check in the hub which contacts are equipped with the construction of the hub socket, it appears that only the four middle wires are active and there is certainly no orange pair there.
    2 posts merged
    j.
  • #5 929444
    robt
    Rate: 14
    JAKU is right and that's it.
  • #6 929447
    Kuniarz
    Help: 371
    Rate: 826
    hmmm .. well, I have two versions ... which one is correct? :-)
    the cable is probably not KAT 5, but it is quite short sections, and besides, it is to be used only for the Internet. If it works oki, if not, I will fly with the drill.
  • #7 929451
    Masster
    Level 32  
    Help: 156
    Rate: 46
    For the 10/100 Mb / s transmission, two pairs of cables are needed, as mentioned earlier, the orange and green pairs are used in the gigbit ethernet. You can easily find descriptions of network cables on the electrode and on the net, but do not count on a 100 Mb / s connection because in this case, the correct twisting of the wires is very important. For longer sections, remember to use the orange and green twisted pair cables. Otherwise there may be circuses with the network. I do not know if you will get any connection, and if you do, it will "only" at 10 Mb / s.
  • #8 929458
    robt
    Rate: 14
    Please just the plost cable is not interlaced.
    • Using Four Wires for a Network: Essential Twisted Pair Cable Conductors? kabelek[1].gif (7.7 KB) You must be logged in to download this attachment.
  • #9 929494
    robt
    Rate: 14
    Fine plugs taken care of. However, when it comes to the network on the telephone cable, because it is probably connected to the intercoms, this may be a problem. It seems to me there will be too much trouble, too much interference, the telephone cable is rather unsuitable for 100 or even 10 Mbps transmission. But if you feel like it, check it and write what came out of it. Or maybe someone has already done such experiments, so let him speak.
  • #10 929563
    blues
    Depends on what you want to get.
    If 10Mbit is enough for you, then a regular 4-wire telephone cable is enough to satisfy category 3. At short distances it will go,
    If the pairs in this cable are twisted, even 100Mbit has a chance to go up to 60-70m, although this is a big risk.
    In an ordinary Category 5 UTP cable, you can boldly play 2 independent transmissions, although I do not recommend it, because makeshifters are the most durable ;) You have a chance to get up to 100Mbit.
    As for the cables - it is only important that the cables 1 of 2 and 3 of 6 are from one pair. What colors you choose, it does not matter, although it is good to stick to the standard at least in one plug :)
    - white and orange
    - orange
    - white and green
    - blue
    - White and blue
    - green
    - White-brown
    - Brown
    There are several standards for coloring - I know 3 commonly used ones, of which 2 are the basic ones: T568A and T568B (you showed B here). :)
    Couples are important.
    Oh - one more thing.
    With this maneuver, you block your way to the gigabit, because all 4 copper pairs are used there. And that it wasn't - gigabit is remarkably cheap now. I have already seen small 5-port 5x1G switches for PLN 300 ....
    2 posts merged
    j.
  • #11 1730604
    Robin_Otzi
    Rate: 18
    from what they taught me (as I remember correctly), the two middle cables are usually unnecessary blue and white and blue, and this is explained by the fact that someone should not plug in the phone kalba because there is a higher voltage there and it would burn the card! but if I'm wrong don't lynch me ;)
  • #12 1730699
    gzeho.p
    Rate: 15
    Who knows, maybe it would burn ...
    but looking from the side of the contacts so that the cable from the plug comes down, it is used only from the left
    1,2,3,6 contact, but 1,2 and 3,6 are pairs (over / rebound)
    and the rest is unused only because at 100mb they are not needed and at 1GB they are already
    The standard is simply old, but well-thought-out for the future.
  • #13 1851194
    ..:::Snake:::..
    Help: 5
    Hello :)
    I have a fairly simple question, but I do not know the answer, looking on the net, I found only how to patch the cable, but not where it is most often used, i.e. in what cases or all the time what is the principle of its operation? does the cable from the router, for example, need to be crossed to connect the second computer? (net from cable)
    thank you in advance for your answer and please treat the layman gently :)
    ah, I used the 'search' button here on the Electrode for a very long time :)
    Snake
  • #14 1851311
    harkonnen
    Rate: 20
    If you can, buy it or make cross cables yourself. The new switches of the router deal with it without any problems and switch themselves as needed. You won't even have any switch, you can use this cable to connect 2 computers. A simple straight cable is not suitable for yours.
  • #15 1851727
    tzok
    Help: 3177
    Rate: 6558
    A crossover cable is only used to connect two computers without intermediate devices and possibly for cascading switches / hubs, but these usually have an additional 'upliknk' socket or a switch that switches the last port between 'normal' and 'cascade'. The computer with a switch or router is connected with a straight cable.
  • #16 1851867
    ps15011982
    Help: 12
    Hi, I have an eight-core gelled telephone cable (I do not remember the marking, but I will try to check) it connects 2 switches - a distance of about 60m - about 30m dug into the ground, the rest outside and at home without any pipes, etc., so in winter the connection must be 100Mbit. transfer between computers within 3-3.5 MB / sec. everything works for almost 2 years, so it's probably OK
    Greetings
The discussion revolves around the feasibility of using a four-wire intercom cable to establish a network for four computers. Participants suggest that for a basic 10 Mbps network, only two pairs of wires are necessary, specifically the orange and green pairs (wires 1, 2, 3, and 6). Some responses indicate that while a standard Category 5 (Cat 5) cable is preferable for higher speeds, a basic telephone cable may suffice for short distances. Concerns are raised about potential interference when using telephone cables for networking, and the importance of proper wire twisting is emphasized for achieving reliable connections. The consensus is that while it is possible to create a network with the available wires, performance may be limited, and users should be cautious of potential issues.
