Developer Lacks Electrical Installation Project: Legal Rights & Apartment Alterations
gregiolo 10866 7
  • Need for an electrical installation project from the developer
    #1 16767881
    gregiolo
    Hello everyone,
    I recently picked up a new apartment from the developer. In the documentation he gave me a package of photos of how the installation was arranged. At the request for the installation design, I was told that they did not have such a design and that there were only photos.
    The company that will do the alterations according to of my preferences asked for a project to professionally approach the topic.
    Is it even possible that the developer is not required to have a project? Is there a legal basis on which I can request such a project?
  • #2 16768031
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    The project probably is, but one for the whole division of (identical) apartments.
  • #3 16768109
    gregiolo
    Hmm, just that there is almost every apartment there. Mine is two-level, below are like a double 2-room, even lower 3 rooms and then the ground floor. :(
    PS It's about living in Poland.
  • #4 16768259
    JohnySpZOO
    Electric installations specialist
    Help: 186
    Rate: 330
    The project should be somewhere.
    Perhaps it was done only in the scope of ADM + installations supplying power to residential premises (enough for an official), terminated with a dashboard. The rest in terms of tenant. I have also done such projects.
    You can apply for a project from the developer - you have the right to do so and you should receive technical documentation as the owner. Looking at my friends who recently bought housing, most of them received some plans / schemes based on which they changed something.
    The question is what is contained in the contract signed by Cb and whether there is a provision regarding acceptances / guarantees / papers (acceptance reports, measurement of elec.) / Complaints.
    I suspect that in Cb 90% of the situation was that the subcontractor was doing the topic by head without any paperwork.
  • Need real measurements for apartment electrical rework
    #5 16773689
    tomus2k
    Help: 89
    Rate: 218
    The design is only a schematic, the electrical designs are detailed as to security, the other elements are only schematically marked. And this is a horizontal projection without dimensioning.
    What does your company expect from rework? After all, professionally you don't make a project of changes to an existing building / apartment from the project, but you need to make real measurements.
    Did the developer or contractor threaten you with paragraphs, why would you threaten them.
    Ask them for a photocopier or that you will come and take a picture of yourself from the documentation.
    Or if the subcontractor was to prepare the documentation and installation, ask them for such a project. Just don't expect it to help you for the above reasons, but the pictures give you more.
    Mine is two levels,
    I skip the fact that if you can afford a duplex apartment, you should be able to afford professional advice from a construction expert :idea: dot.
  • #6 16773923
    revolt
    Help: 159
    Rate: 186
    Maybe art. 60 -> art. 2 points 13 -> art 63
    Construction Law
    Somewhere this documentation must be.
  • Developer should provide a photocopy of the installation design
    #7 16773948
    vodiczka
    Help: 1185
    Rate: 4311
    They probably did not threaten, but behaved like in a cloakroom joke:
    gregiolo wrote:
    On request for installation design I was told they did not have such a project
    We don't have your coat and what will you do to us :)
    The developer (uninvited) should make a photocopy and send it to the client, or ask him to the office if he wants a cito.
    tomus2k wrote:
    I skip the fact that if you can afford a duplex apartment, you should afford professional advice from a construction appraiser. Dot
    The fact is that this sentence smells of envy.
  • Project documentation belongs to the building manager, not the developer
    #8 16774200
    tomus2k
    Help: 89
    Rate: 218
    No, he does not have to do anything on the cito, he gives the entire documentation to the manager (because I assume there is a community there), and earlier for permission from the architecture department. But only project documentation. Executive documentation, measurements etc. always remain with the developer / contractor.
    It is because of this demanding approach that it is getting stuffy in this country.
    All on a cito, without respect, the bigger the better.
    But if you thought, understood, then my advice, which is ironic, is 100% correct, should you conflict with the developer, use a professional?
    I still insist that the fight for this paper is pointless, because there is nothing interesting for an interior designer. dot.
    Example - a fragment of a project from the documentation of a multi-family building:
The discussion revolves around a new apartment purchase from a developer in Poland, where the buyer is seeking the electrical installation project documentation that the developer claims not to possess. Responses indicate that while the developer may not have a specific project for each apartment, there should be some form of technical documentation available, especially for installations. Participants suggest that the buyer has the right to request this documentation based on construction law, and emphasize the importance of having proper plans for any alterations. Some responses highlight the need for real measurements rather than relying solely on existing photos, and the potential challenges in obtaining the necessary documentation from the developer or subcontractors.
