Valuation of Electrical Installation: Assessing Electrician's Labor Costs for New Building
Mientek007 18168 18
Is the electrician’s labor quote for installing the electrical system in a new building reasonable without including materials?
The quoted labor prices look quite reasonable, and for Warsaw they may even be a bit low, but a low price does not guarantee good quality [#16173805] A reliable labor valuation cannot be made from the information given, because you need the project details and a site visit to clarify the scope before estimating [#16176199][#16176249][#16174502] Such price lists are often intended for typical single-family houses or flats, and large jobs may not be valuated well by a simple per-point scheme [#16173982][#16174819] The final price depends on concrete details like the number of modules, RCDs, circuits, sockets, and how the installation is actually divided up [#16174838][#16174819] In practice, the investor and contractor should agree on the exact scope first to avoid later misunderstandings [#16174502][#16174507]
  • #1 16173460
    Mientek007
    Pupil
    Rate: 9
    This is the valuation of an electrician (performing electrical installation in a new building). Of course, labor, without material.
    Question - would you agree to such prices?
    Good offer, can you look for an electrician?
  • #2 16173805
    Adam_Bandit
    Help: 24
    Rate: 59
    Prices look quite reasonable, as for the realities of Warsaw were even a bit low, but the issue of price is one thing, and how about quality ??
  • #3 16173975
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    I invite this electrician to cooperate with you. I have a job for February. One 2080m? room for me to "fix the cables to the ground" for 20 PLN. Please contact me immediately!
    I have already bought PS Material, a robot for a month. Maybe even up to PLN 100 we will pay for the whole :D I'm not a grandfather ;)
  • #4 16173982
    Adam_Bandit
    Help: 24
    Rate: 59
    I suspect that this price list was created for single family houses and flats for typical installations, large works are not valued from a point.
  • #5 16173989
    Łukasz-O
    Help: 654
    Rate: 4292
    The price list is a price list. When you go to buy a kayzer, no one asks if you are from the factory or privately.
  • #6 16173993
    Adam_Bandit
    Help: 24
    Rate: 59
    Ino take, just for quality, I would be afraid.
  • #7 16173995
    Łukasz-O
    Help: 654
    Rate: 4292
    Sure!
    Then we read the lamentations on the forum that the electrician has washed away, does not answer phones, the installation does not work as it should. And I will not mention the final measurements.
    Investors like to save and then pay double. That's our tradition :D
  • #8 16174333
    Mientek007
    Pupil
    Rate: 9
    It's not a price list, but a job quote
    Łukasz-O wrote:
    One room 2080m?
    which applies to a detached house with an area of 260m?
    Adam_Bandit wrote:
    for the Warsaw realities they were even a bit low
    It's about southern Poland and the Opole province
  • #9 16174493
    Łukasz-O
    Help: 654
    Rate: 4292
    I will write differently. At the investor's place I would jump for joy.
  • #10 16174502
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3532
    As usual, the devil is in the details.
    It is necessary to clarify a few points so that later, after the fact, there will be no misunderstandings like:
    investor - and I thought ...
    contractor - and I meant that ...
  • #11 16174507
    Łukasz-O
    Help: 654
    Rate: 4292
    But this is probably not our role. The investor and the contractor have to get along with each other.
  • #12 16174687
  • #13 16174819
    mawerix123
    Help: 482
    Rate: 951
    It is impossible to make a normal valuation of the entire installation :?:
    I suspect that the price list of such a service, later it will turn out that there is one RCD for the whole house and all circuits a total of 6 units.
    It may also be that if the pricelist pricing is to go out profitably, the socket will be every meter so that the points agree with the planned collection of the sum for the service ;)
  • #14 16174838
    elpapiotr
    Help: 1015
    Rate: 3532
    In this particular case, rather not. At the end of PLN 12.00 / module.
    With 200 modules, it is PLN 2,400.00. Only take.
    That's why I wrote - refine the details so I would not wake up with my hand ...
  • #15 16176147
    Adam_Bandit
    Help: 24
    Rate: 59
    Only what a layman has to do, who is happy that cheap. The light bulb is a well-made installation. An electrician can only be assessed by another electrician who has more knowledge. Ehh :(
  • #16 16176199
    Łukasz-O
    Help: 654
    Rate: 4292
    Therefore, before an approximate valuation, it is worth getting acquainted with the project, and being a contractor, make a local visa on the site.
  • #17 16176209
    Adam_Bandit
    Help: 24
    Rate: 59
    I always praise the whole, from a point too much but ...
  • #18 16176249
    Łukasz-O
    Help: 654
    Rate: 4292
    Anyway, based on the data provided by the author of the topic, it is impossible to estimate labor costs rationally.
  • #19 16176290
    Adam_Bandit
    Help: 24
    Rate: 59
    Local vision = total cost. So much in the subject :)
The discussion revolves around the valuation of electrician labor costs for electrical installations in new buildings, particularly in the context of a quote for a detached house in southern Poland. Participants express varying opinions on the reasonableness of the quoted prices, with some suggesting they are low for the Warsaw area. Concerns about the quality of work associated with lower prices are raised, alongside the importance of clear communication between investors and contractors to avoid misunderstandings. The necessity of a detailed project review before finalizing costs is emphasized, as well as the potential pitfalls of underestimating installation requirements.
