Matrix - Gluing Matrix Tape: Using 3M 9703 ACF 25mm x 27m for Connecting Matrix to Strip
EKG 11694 4
  • #2 16768966
    Marco_zg
    Help: 48
    Rate: 62
    I won't answer the question, but today on YT I watched exactly how a similar TV model (I get to know it by the edge) gostek repaired with a piece of rubber tube. On one tape, some pins did not touch. Pressing the finger was OK. He glued a piece of adhesive tape on both sides and a piece of rubber tube on it in the absence of contact, the whole was pressed by a strip covering the connecting tape from the LCD.
  • #3 16769474
    EKG
    Help: 14
    Rate: 35
    I have several matrices with damaged tapes and it's a shame to throw them in the garbage. I'm only interested in sticking the old ones, they are OK on the glass.
  • #4 16769862
    tomek5333
    Help: 13
    Rate: 57
    just like a colleague above wrote something to plant and press, there are also artists who heat with an iron, you would have to read
  • #5 17970970
    EKG
    Help: 14
    Rate: 35
    I missed a waste of time for such fun.
