The choice of glue to stick the LED strip to the epal palette.
Michal1561 6066 5
  • #1 16647533
    Michal1561
    Level 4  
    What glue is needed to stick the led strip to the (painted) epal palette? The tape does not want to stick or even tried hot glue and none of this. I know that this is not the right forum but someone can know it. Thank you very much for your reply. Best regards.
  • #2 16647570
    E8600
    Help: 529
    Rate: 2529
    Foam tape and if it will not hold it is a tacker and staples.
  • #3 16647688
    Michal1561
    Level 4  
    The foam tape is not holding. But with a tape cutter the LED tape will break down
  • #4 16647778
    E8600
    Help: 529
    Rate: 2529
    The problem may be a poor tape is still colorless silicone. ;)
  • #5 16647893
  • #6 16648076
    telecaster1951
    Help: 829
    Rate: 818
    Which side does he not hold? From tape or pallet? What is this palette painted with?
    E8600 wrote:
    colorless silicone.
    There is no chance it will last.
    With sufficiently large staples, no.
