[Solved] Cutting 60x60cm 10mm Thick Stoneware Tiles at Home: Hand vs Electric Water Cooled Tools
RADU23 78573 15
Can a manual tile cutter handle 60x60 cm, 10 mm stoneware tiles at home, or should I use a wet electric cutter?
For 60x60 cm, 10 mm gres tiles, a wet electric tile cutter is the better choice; hand score-and-break cutters need skill and a very good wheel, and long tiles are hard to keep straight without cracking or chipping [#16771052] A wet cutter with a diamond blade cuts gres cleanly and almost without dust, especially when the tile lies on the machine table, not when you try to feed a long tile by hand [#16770960] [#16771052] The original disc on cheap machines may be poor, so a better diamond blade can make the cutter work very well [#17167315] Keep the water level so the disc is submerged about 6–7 mm to suppress dust, but not so deep that it splashes heavily [#17167315] Several replies recommend renting such a machine for the job, and one user reported cutting the tiles successfully with a wet cutter model without problems [#16771052] [#17167647] An angle grinder with a diamond disc will also cut gres, but it is very dusty and is best used outside [#16770911] [#16772513]
  • #1 16770884
    RADU23
    Help: 2428
    Rate: 1732
    I have to put stoneware tiles 60x60cm and thick at 10 mm.
    As they will have to be cut, I wonder how and what to cut at home.
    The first option is a hand machine for cutting glaze:
    The basic question is, will she actually handle the cred as the seller provides? The tiles will be about 30 pieces for cutting.
    The second option is electric with water cooling. Apparently, it does not dust very well and copes with gres tiles when using diamond discs.
    The prices of these devices are similar and you need to invest about PLN 400 (not to buy some Made in Czajnik).
    Someone used, cut, tested on stoneware tiles and can say something?
    Or maybe some other, good, proven methods?
  • #2 16770911
    1repcaK
    Help: 52
    Rate: 123
    Angle grinder with diamond disc, I cut glaze, terracotta, gres, 10 mm granite, cubes and paving slabs as well as edging (curbs).
    If you have one, you will save on buying a machine. Dust, however, a lot.
  • #3 16770951
    RADU23
    Help: 2428
    Rate: 1732
    I have an angle grinder with a diamond disc, but it makes me so at home that I can not see myself.
    macevo19
    Greetings.
    At home, in the hallway, I laid large gres tiles (170x900x8mm) about 4m3, borrowed with an electric tile and gres cutting machine, similar to what you presented.
    The machine is doing very well with the gossip, the plate was cutting the plate like a butter knife. If you have only this to solve, then consider renting the device. And if you decide to work with this razor, put it on the foil, because it is a little leaking to the sides and put on rubber gloves for cutting.
  • #5 16770976
    bearq
    Help: 414
    Rate: 1612
    The electric cutter must also have the option of cutting in water. Otherwise Mexico will be at home.
    Try to cut the grinder, but in the water cover, it will not be dusty, but there may be a large amount of coolant spread, quite high revolutions.
  • #6 16770980
    RADU23
    Help: 2428
    Rate: 1732
    Just a bud cut out with a container for water and sprayed on the dials, saying that almost no dust.
    wada
    Help: 168
    Rate: 732
    Glazed tiles with a length of 60cm hard to cut with a breaker you must have skill and must be a good knife (circle).
    It's best to cut with a diamond blade wet, and not every one can do it.
    The table after which you move the tile by hand is not practical, not only that you have a fountain of water and one of the walls you have to spend on solid splattering, it's still long tiles it is hard to push evenly, and the more that the dust sticks to the table and unevenly on different side pushing, and light gearing and blocking the shield and the tile breaks.
    The best solution is to cut, as the tile lies on the table and the dial is going, you can then make any cutouts, and the smallest fountain is surrounded and very little noise
    You can rent such a machine.
    There are also a lot of companies to which you can drive with tiles and you cut for pennies on the spot, especially when you need to drill some holes, it is best to use a water-cut at gres tiles, very precise and perfectly smooth cutting.
    I have for 10 years the cheapest Dedra 800W DED7831, I used to cut a lot of gres, granite, etc. I borrowed various friends, and now working on commercials, various stones cut it, granite, marble, basalt, or ordinary concrete is not terrible for her , and is very similar to this "Kraft & Dele KD558 tile cutter", can be found in the net by symbol, and you can temporarily like here:
    http://allegro.pl/przecinarka-stolowa-do-glazury-drewna-plytek-pila-i5325667594.html
    https://www.castorama.pl/produkty/narzedzia-i...rka-do-plytek-macallister-mstc800d-800-w.html
    https://www.obi.pl/maszyny-do-ciecia-glazury/...narka-do-glazury-mc990-800-w-720-mm/p/6229579
    https://www.leroymerlin.pl/narzedzia-budowlan...ecinarka-do-plytek-ceramicznych-tc-200-iii-a- sr-disc-200-dexter, p408451, l741.html
    https://www.olx.pl/oferty/q-przecinarka-do-glazury/
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • #8 16772356
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    I bought an electric tile cutting machine for stoneware in LIDL for about PLN 140 from Parkside. Maybe you can hit it.
  • #9 16772438
    wada
    Help: 168
    Rate: 732
    HEHe - a small light table and after it you have to move a much heavier and bigger tile, total anguish and a lot of damaged tiles
    Elefant
  • #10 16772479
    RADU23
    Help: 2428
    Rate: 1732
    The meter of these tiles costs about PLN 120. Kafla has 60x60 so its cost is about 70 PLN.
    You can not afford too much loss in the material ;-)
    I need to find out in Castorama if it is possible to rent some equipment to cut it.
  • #11 16772513
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    If you have the option of cutting outside the building. It's just a small angle, unless you're scared or have no experience with this machine. I cut everything and gres also polished cut I cut. Damage to other equipment. :D
  • #12 16772521
    RADU23
    Help: 2428
    Rate: 1732
    marqqv wrote:
    if you have the option of cutting outside the building. It's just a counter
    I have the angled tip and I use it without any problems.
    However, I will not cut it on the balcony of gres, because someone friendly from the estate guards will come and kindly inform you ;-)
  • #13 16772522
    wada
    Help: 168
    Rate: 732
    Ehhh - a liar. ;)
    One tile is just 0.36 m? PLN 43.20 - but it's still a big loss. :|
    There are a lot of borrowings, you can also buy a OLX dealer for a penny and then sell it, but think about the big table I suggested, and by the way probably the quietest cut (at the dial 200-230mm) and without dust.
    And cutting dry stoneware is a risk, large tiles have grains (from the bottom you can see such slight smudges, maziaje) which are very hard and heat up, causing cracking, even when wet cutting feels the brake disc braking and slow cutting , just push forward to avoid overheating the tile point by point.
    Elefant
  • #14 16777252
    telecaster1951
    Help: 829
    Rate: 818
    I have exactly what you threw. Glazura and stoneware cuts very nicely, provided that the tiles are on the table. Tiles 60 cm I do not see on this.
    As I laid the plaster in the apartment, I got bored with sawing the net and rented a giraffe for 5 days per night. I honed up and took off the next day. With the cutter I will think similarly in terms of amount. Arrange everything without any tricks, go, rent, donate and give away.
    There is also another way out. The neighbor laid a meter-long tile. He went to the cemetery. He found a stonemason and cut him down with a flask.
  • #16 17167647
    RADU23
    Help: 2428
    Rate: 1732
    The tiles are laid. She was able to cut their razor without any problem =>
    Glaze Mill MGM 800 Walmer
    Plus big that completely zero shit and there are no losses in the tiles ;-)
    It will be useful for the future.
    Thank you all for participating in the discussion and advice.
    I close the subject.
The discussion revolves around cutting 60x60cm, 10mm thick stoneware tiles at home, comparing hand tools and electric water-cooled machines. Users share experiences with angle grinders equipped with diamond discs, noting their effectiveness but high dust production. Electric tile cutters are recommended for their precision and reduced dust when used with water cooling. Renting equipment is suggested as a cost-effective option, and several users mention specific brands and models that performed well. Concerns about tile damage during cutting and the importance of using the right tools and techniques are highlighted.
TL;DR: Wet table saws with a good diamond blade have handled ~180 m² of tiles and “practically does not dust.” For 60×60×10 mm porcelain stoneware, choose water‑cooled cutting over dry grinding at home. [Elektroda, 563113, post #17167315] Why it matters: This FAQ helps DIYers decide how to cut large-format stoneware at home with clean edges, minimal mess, and controlled costs.
What’s the best tool to cut 60×60×10 mm porcelain stoneware at home?
Use a water‑cooled table saw with a quality diamond blade. It gives straight, low‑chip edges and controls mess. Move‑blade designs keep the tile stationary, improving accuracy on large formats. Owners report excellent results and low dust after upgrading the blade. [Elektroda, 563113, post #17167315]
Will a manual score‑and‑snap cutter handle 60 cm stoneware cleanly?
It’s hard to get clean 60 cm breaks on dense stoneware without skill and a top‑tier wheel. Long tiles tend to bind or crack. Wet diamond cutting remains the recommended approach for consistent results on large, thick tiles. [Elektroda, wada, post #16771052]
Is a wet saw really less dusty than an angle grinder?
Yes. Water captures abrasive dust at the source. Users note wet cutters “practically” eliminate dust, while grinders produce heavy dust clouds. If you must grind, do it outdoors and expect cleanup. [Elektroda, 563113, post #17167315]
Can I cut indoors without making a mess?
You can, but control water and splatter. Place the saw on foil or plastic sheeting, wear rubber gloves, and ensure water recirculates over the blade. Expect some side spray; manage it with barriers. [Elektroda, macevo19, post #16770960]
Should I buy or rent a wet tile saw for one project?
Rent if you only have one room or a few days of cuts. Many DIYers rent, finish, and return, avoiding storage and maintenance. For frequent use, a mid‑range table saw with a better blade is worth buying. [Elektroda, telecaster1951, post #16777252]
How do I reduce edge chipping on porcelain stoneware?
Use a higher‑quality diamond blade, keep a steady feed, and maintain correct water depth. One user solved severe chipping by replacing the stock disc and achieved clean edges thereafter. [Elektroda, 563113, post #17167315]
What water level should I aim for on the blade?
Submerge the disc about 6–7 mm. Deeper immersion causes excessive dripping; shallower immersion fails to trap dust effectively. Adjust during use as water evaporates or splashes out. [Elektroda, 563113, post #17167315]
Can I just use an angle grinder with a diamond blade?
Yes, it will cut stoneware, granite, and even curbs, but expect lots of dust. Use it outdoors when possible. Indoors, it’s impractical without heavy containment and may draw complaints. [Elektroda, 1repcaK, post #16770911]
What’s the safest indoor alternative if I can’t grind outside?
Choose a wet cutter with true water‑bath operation. Models that spray but don’t bathe the blade make a mess. Enclose the workstation and protect nearby walls from splatter. [Elektroda, bearq, post #16770976]
What’s the simplest 3‑step how‑to for clean wet cuts?
  1. Fit a quality diamond blade and fill the tray so 6–7 mm of disc is submerged.
  2. Mark the cut, hold the tile steady, and feed slowly with constant pressure.
  3. Pause if you feel braking or heat buildup; let water cool the cut, then continue. [Elektroda, 563113, post #17167315]
Any budget tools that actually work?
Yes. Users report success with low‑cost wet cutters when paired with a better blade. Examples include Parkside units from discount stores and similar 800 W table saws. Upgrade the disc first. [Elektroda, kierbedz4, post #16772356]
How do I keep waste low when tiles cost ~43 PLN each?
Plan cuts to reuse offcuts, test your setup on a scrap, and avoid dry cutting large tiles. Dry cuts can overheat hard inclusions and crack the tile, wasting money. [Elektroda, wada, post #16772522]
Who can make precision cutouts or long straight cuts for me?
Tile shops and stonecutting services offer on‑the‑spot wet cuts and hole drilling for small fees. A stonemason can also help with long pieces or difficult shapes. [Elektroda, wada, post #16771052]
What’s a better design for long tiles: moving the tile or moving the blade?
Keep the tile stationary and move the blade across it. That design reduces binding, improves straightness, and limits splatter and noise on long pieces. [Elektroda, wada, post #16771052]
Any real‑world proof that wet cutters hold up on big jobs?
One DIYer cut about 180 m² of various tiles after upgrading the blade, praising low dust and performance. “An excellent tool.” [Elektroda, 563113, post #17167315]
What edge‑case failures should I watch for?
Dry cutting large tiles can hit hard grains, heat the line, and cause sudden cracking. If you feel the disc braking, slow down and keep cooling. [Elektroda, wada, post #16772522]
