Is Eurotec SM 201 Tile Cutter Worth It for Home Use? Professional Assessment of 1500W Model
Qbajach 6030 9
Is the Eurotec SM 201 1500W tile cutter worth buying for occasional home kitchen renovation work?
For occasional home use, it can work, but it is a low-end cutter and not a professional-quality choice [#16268563][#16649883] The stated 1500W looks exaggerated; one user says similar budget cutters from this segment are really around 500W, so do not expect full power from the spec sheet [#16649883][#16270013] If you buy one for a one-time renovation, the advice is to choose the cheapest model with a warranty and accept that it may fail after the guarantee ends [#16268563] Good cutting discs are important, because with this power level it will only cut well with proper blades [#16650210] Budget models can still handle tiles and even paving stones, but larger tiles may be a problem because of the small base/table, with one user reporting good results up to about 45x45 [#16269715][#16650210]
  • #1 16268521
    Qbajach
    What do you think about her? Eurotec Model SM 201 1500 W. :)
    Is it worth the money, I mean more about home use, I have to renovate the kitchen and I am looking for a machine for a good price. Thank you in advance for all the answers. I really care about the professional assessment of this equipment. :)
  • #2 16268563
    ShakeAll
    Help: 29
    Rate: 135
    Eurotec is unfortunately the lowest shelf.
    If it is supposed to be for one time only, then buy anything the cheapest with a guarantee and use it so that it could break before the end of the guarantee :)
  • #3 16268596
    Qbajach
    And the Kraft & dele cutter only 600W? I may also have 60x60 tiles to cut, so I don't know if it'll work :D
  • #4 16269715
    Michelson
    Help: 82
    Rate: 305
    I have a cutter from this price segment - some Dedra 450W bought for one job and for now I do not want to break. I have it a few years and I already have a second shield. I think he is even suitable for an amateur. The power does not knock you down, you need to adjust the cutting speed to the power of the device, but it can handle even gros. I cut maximum 45x45 inserts, with larger ones there may be a problem due to the small size of the base, the cutter table. As for the disadvantages, I will mention discs with a tendency to beat. You have to get a little tired to set it up correctly. But it's difficult, quality adequate for the price.
  • #5 16269722
    Qbajach
    So it is more profitable this Kraft & dele 600W than that of Eurotec :D I think it's enough for a few renovations :D Thank you for the hints :D If you still have one checked up to PLN 200, I am asking for names :D
  • #6 16270013
    Jerzy Trojniarz
    Help: 23
    Rate: 72
    Hello. I have just bought a cutter from this company ECSM15, power 1500W, 2800 rpm. I have not cut the plates yet, but I have a wood blade on and there were cut slats from a 32mm board, 1.5m long. Cutting speed satisfactory, but with a power of 1500W it is probably a bit exaggeration. The tiles will be just cut, but I think it should be able to do it too. It is quite quiet. The price is 200 PLN and a sufficient tool for my needs.
  • #7 16270023
    Qbajach
    So I think this Kraft & dele won :D I think that at home it will work just in time, and even the table is quite large, large tiles should go smoothly :D
  • #8 16649594
    mackam3
    Connecting to the topic.
    I want to buy a tile cutter with the option of cutting wood.
    I can choose such a 1500W machine for PLN 220
    http://allegro.pl/przecinarka-stolowa-do-glazury-drewna-plytek-sm201-i6817928607.html
    Or, for example, the one for PLN 148 on the spot in Castorama, only that it has 450W and the revs / min are the same.
    https://www.castorama.pl/produkty/narzedzia-i...przecinarka-do-glazury-opp-450-w.html#product
    At Allegro, the same machine currently costs PLN 177
    Can someone advise me in choosing and explain the principle of operation?
    Ie. 1500W vs 450W and revolutions per minute similar to each other.
    Regards
  • #9 16649883
    Michelson
    Help: 82
    Rate: 305
    This power cutter from Castorama, in my opinion, has real power, while you need to divide this power from allegro by three, because this power cutter does not have more than 500W, and manufacturers, distributors and sellers cheat unaware buyers. Both are the same price segment. After changing the shield maybe some wood will cut, but rather some slats.
    Regards.
  • #10 16650210
    marek49ae
    Help: 57
    Rate: 254
    I have such a cutter from Eurotec 500W, it is probably 10 years old. She cut a lot of tiles, paving stones, and even more boards for strips. The rule is to buy good cutting discs, because with this power, anything will not cut. I only replaced the switch, because the latter leaked, got dust and stopped working.
The discussion centers around the Eurotec SM 201 tile cutter, specifically its 1500W model, and its suitability for home use during kitchen renovations. Opinions vary, with some users expressing skepticism about Eurotec's quality, suggesting it is a low-end brand. Alternatives like the Kraft & Dele 600W cutter are recommended for similar tasks, with users noting that it may be more reliable for home renovations. Users share experiences with other models, such as a Dedra 450W cutter, which has proven effective for amateur use despite its lower power. Concerns are raised about the actual power output of budget models, with suggestions that advertised wattages may be inflated. Overall, while the Eurotec SM 201 may suffice for occasional use, users recommend considering other brands for better performance and reliability.
