Comparing Cylinder Pressure vs CO2 Content in Car Liquids: Xsar Picasso Case Study
keseszel 10353 12
How can I determine whether intermittent power loss in a Citroën Xsara Picasso is caused by a head-gasket or compression problem, and is a CO2 coolant test preferable to a compression test?
A compression test is still worthwhile: the integrated coil does not prevent it, because the coil is disconnected and all spark plugs are removed before testing [#16771372][#16774857] A CO2/coolant test or observing bubbles may support a head-gasket diagnosis, but it does not show which cylinder has low compression or distinguish a cylinder-to-cylinder fault [#16771292][#16771324] A combustion leak normally brings coolant loss, system aeration or bubbles, liquid expelled through the plug, and possibly an empty expansion tank after cooling; also check for hard hoses, overheating, oil-level changes, or white exhaust smoke [#16771573][#16774609] The intermittent symptoms do not specifically indicate a gasket, so investigate the integrated coil, crankshaft sensor and its connector, fuel pressure, LPG system, and possibly a sticking EGR valve [#16771573][#16774538][#16775068] A fault-free computer scan does not rule out a sensor giving an incorrect but still plausible value, so live-data comparison while the engine runs well and poorly is useful [#16771573]
  • #1 16771277
    keseszel
    Help: 54
    Rate: 558
    What is the point of comparing the pressure on the cylinders in the car when you suspect a damaged seal? Instead of measuring compression in order (which is troublesome with e.g. Xsar Picasso where the coil is integrated), just check the CO2 content in the liquid.
    Check kits cost from 20 PLN. I don't know how reliable these sets are, but considering the number of buyers ...
    It may be worth buying a device to check the pressure, however? Prices from PLN 50 here.
    Maybe I will answer myself partially. It is not only the gasket that affects such symptoms. Valves?
    I am asking because car (here Xsar Picasso ;-) ) loses power in gusts and it is very annoying at the traffic lights when you need to start on the green, and after pressing the accelerator the revs can fall ... Not always, but it happens ... For this car can catch a "mule" .
    Connecting to a computer shows nothing .
    All in all, if someone is a "hobbyist" and likes to waste time looking for a good mechanic, he can let go of such instruments. However, it irritates me a bit ...
  • #2 16771292
    sly_1978
    Help: 34
    Rate: 284
    CO2 also want to check the breakdown between cylinders?
  • #3 16771324
    Łukasz.K
    Help: 84
    Rate: 152
    It is with the engine running and gassing that the bubbles should probably go in the fluid tank like this.
  • #4 16771335
    keseszel
    Help: 54
    Rate: 558
    I didn't take this option into account, but I'm not a mechanic ;-) just a "tired" victim :crazyeyes: :shii: skirmishes between mechanics and the vehicle.
  • #5 16771372
    milejow
    Help: 1563
    Rate: 5149
    In what way does such a coil interfere with checking compression?
    I have the impression that you have no idea how to do such a test.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #6 16771548
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    Each fault can have a different background. Why do you think yours is a head gasket?
    g107r
    Help: 811
    Rate: 993
    And why do you suspect head gasket?
    Once it is burned out, with a blow it is damaged, and once it is not?
    You would have similar symptoms all the time, not just at traffic lights.
    I had a cracked head, that's a bit :( worse than EPA.
    In the morning, the pond in the cylinder, after firing, when the liquid blew out, rode well until it was fully heated, then it was only the liquid from the crack that flooded the candle and the ride ended ...
    Good, but the fluid was disappearing all the time.
    Disappears to you too? Oil increases, decreases? Hard hoses? Overheating, underheating? Is it bubbles in the tank? Any other symptoms, smoke, water is coming out of exhalation?
    keseszel wrote:
    Connecting to a computer shows nothing.
    Take you can connect this computer and observe changes while driving, compare changes in engine work when it works well with those when it works badly. The lack of errors does not have to be an indicator of the correct operation of the sensors or other electro-mechanical equipment. I do not know how much self-diagnosis is extensive in this xsara, but I have an error, e.g. a temperature sensor will occur in two cases, short circuit in the sensor or on the wires - temp above 146C, or breaks - temp below -35C.
    The range from -35C to 146C for the engine controller is OK, but whether the indicated temperature is adequate to warm up and the controller based on it properly prepares the mixture for burning is another matter. With an incorrect, because the engine is cold, and the sensor lies that it is 90C I will have low fuel, the reverse is too rich in fuel, and despite the lack of errors, because everything takes place in a safe and "error-free" temperature range for the controller -35C + 146C.
    Do you understand what I mean by giving an example? Are you probably preparing a thicker money for perhaps unnecessary demolition of the engine, without checking other possible faults, because the Internet is full of UPG and "check for errors" ...
    Here you have from "my" backyard https://www.elektroda.pl/rtvforum/topic255626-30.html, what was and still is to blame for bad engine operation? A pair of wires connected together?
    keseszel wrote:
    I am asking because car (here Xsar Picasso ;-) ) loses power in its gusts and it is very annoying at traffic lights when you need to move on the green, and when you push the gas pedal, the revs can fall ... Not always, but it happens .. For this car can catch a "mule".
    e.g. a coil, integrated can hurt, one falls, you have to buy four ... The shaft sensor, which controls everything in total, the plug unbuttoned ... 2-3 times in a rainy week or something. It was enough to press as I was lucky - he shot himself trying to move, i.e. he was mullah :?: :?: because generally only incidentally lost for a moment connection in this plugin, which does not mean that it could not last until today ...
  • #8 16772843
    keseszel
    Help: 54
    Rate: 558
    Every now and then there are more hits, I don't want to create a toy car story .. Most things are overwhelmed, sometimes with help. Unfortunately, mechanics are far away, time consuming and troublesome access. Services cost, sometimes diagnoses are made, sometimes not. Never mind.
    Strange things happen from time to time. After adding gas, mud slows down during normal driving, "hole" after adding gas, going out at traffic lights. Depending on the option. Sometimes. I was interested in checking if the gasket is not damaged or the engine is running. This explains some of the problems then. In most cars I had, the compression pressure was always checked. The most common pain of cars with LPG. I think so, I could be wrong. Prices of currently available devices are acceptable, and a person with intelligence and manual skills can embrace the basic "bullshit". I do not write about cars that require no technical background. My just does not require no one to know, but rather only knowledge ;-)
    Not to move away from the subject. The liquid is ok, it doesn't rise, it doesn't fall. There is no milk ;-) It is possible that exhaust fumes from the filler cork are coming, but I don't think so. Such "I don't think" needs to be confirmed by some measurement. Here the compression ... So the instrument ...
    Problems with coupling, if any. Gasket between cylinders (water eliminated).
    Sealers. Where this from Because sometimes on a cold zakopci, or white blows sometimes. But it's all a device. ;-) Candles replaced. The shaft sensor remains, the stepper motor (cleaned). Some electrical connection .. Generally there is something to break ... ;-)
  • #9 16774538
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    Did you check the fuel pressure?
  • Combustion chamber purge points to electrical faults
    #10 16774609
    milejow
    Help: 1563
    Rate: 5149
    The purge of the combustion chamber into the water jacket is always the discharge of liquid through the plug, notorious aeration of the system and after cooling the liquid disappears (empty tank) Compression pressure does not hurt to check and the coil does not bother you because you unscrew all candles for this procedure anyway. The faults you describe fit into the standard problem of all old French people, i.e. trash and trashy electrical installation.
    Działalność własna
  • Questioning compression tester reliability without verification
    #11 16774857
    keseszel
    Help: 54
    Rate: 558
    LPG and Pb .. I usually run on LPG. Miracles are happening here and there.
    I am afraid that the installation may fail. Only the casing remains of the hangman. But it has been like this for several years. I do not intend to put in a word before any other advice. Rides x time without hangman, exhaust fumes approx.
    All in all right with this coil, you have to detach it anyway to measure.
    Question to "fairies" ;-) .. How is the reliability of the compression tester reliable? Without verification, it is a total index of even compression in the engine chambers, I suppose. But the number of people sold is interesting .. In total, people take and probably do not complain .. But I have not seen praise ... :-)
    milejow wrote:
    old French
    A 15-year-old car is just fresh :D , How dare you..
  • #12 16775068
    tzok
    Help: 3176
    Rate: 6549
    I don't know what engine you have ... although in gasoline it is a rare case, such a symptom (silt when starting off) can give, among others sticking EGR valve. For this car with LPG, so you should start by eliminating the fault of LPG.
    :arrow: http://klubcytrynki.pl/forum/index.php?topic=45685.0
  • #13 16775201
    keseszel
    Help: 54
    Rate: 558
    I did a lot of "lemon-like clubs" ;-) .. There were 5 pages there ... I was there. To this "lpg-like" page ;-) , even my posts on the electrode regarding the reducer .. Comments on the sludge in the filters .. because they were not exchanged x time ... They did not help ... Replacement of filters in the service (because I could cut something when replacing), then adjustment of the installation by the service - a toy car like gold, up to 120 / h, it was cool More was nowhere, so I was happy as a child .. Until after a few days the problem returned. Contrary to the advice (even the assembly company said that after such a course a new evaporator should be deserved), I removed the evaporator, dismantled, cleaned (somewhere I may have the remains of photos from what was in it), I put on the old gaskets that were (cleaning it up for "crazy"), because just continuous pipipipi at some point led me to pull out the evaporator ...
    Currently, the reducer is probably ending its life, because it is the seventh year in the car ... km, and at the mention of filters he made big eyes.
    The subject has expanded a bit compared to my original assumption, I will close it for now. What will I buy - I hope to inform you in the future.
The discussion revolves around diagnosing issues in a Citroën Xsara Picasso, particularly focusing on the relationship between cylinder pressure and CO2 content in car fluids. The original poster questions the necessity of measuring cylinder compression when suspecting a damaged head gasket, suggesting that checking CO2 levels in the coolant might be a simpler alternative. Various responses highlight the importance of understanding the symptoms, such as power loss during acceleration and erratic engine behavior, which could be linked to multiple factors including the head gasket, valves, or fuel pressure. Participants also discuss the reliability of compression testers and the potential impact of LPG systems on engine performance. The conversation emphasizes the need for thorough diagnostics, including checking for air bubbles in the coolant and monitoring engine performance through computer diagnostics.
TL;DR: For Xsara Picasso hesitation or suspected gasket issues, start with symptoms and live-data, not just codes; ECU may treat −35°C to 146°C as “OK.” “The lack of errors does not have to be an indicator.” [Elektroda, g107r, post #16771573]
Why it matters:** This FAQ helps DIYers decide when to use CO2 block tests vs. compression tests and what else to check to fix stumbling or power loss.
Compression test or CO2 test first on a Xsara Picasso?
Use symptoms to guide you. If you see aeration or overflow at the cap, run a CO2 test. If you suspect between-cylinder leakage or general sealing, run a compression test. “Compression pressure does not hurt to check,” and the integrated coil does not block testing because plugs must come out anyway. [Elektroda, milejow, post #16774609]
Does a CO2 block test tell me which cylinder is leaking?
No. A CO2 test confirms combustion gases reached the coolant but does not identify the specific cylinder. To compare cylinders or detect a between-cylinder gasket leak, perform a compression test. Watch for coolant aeration and loss as corroborating signs. [Elektroda, milejow, post #16774609]
How do I run a compression test with an integrated coil pack?
Three steps: 1) Disable fuel and ignition, then remove the coil pack. 2) Remove all spark plugs to reduce load. 3) Install the gauge and crank the engine to record each cylinder. The integrated coil does not prevent this because all plugs come out anyway. [Elektroda, milejow, post #16774609]
What symptoms point to a head gasket or cracked head instead of sensors?
Look for persistent coolant loss, bubbling in the reservoir, hard hoses, white exhaust, or a morning “pond” in a cylinder. A cracked head can run fine cold, then misfire as coolant leaks when hot. Oil level changes and overheating patterns also help differentiate. [Elektroda, g107r, post #16771573]
Why does my car hesitate off the line with no fault codes stored?
Live-data values can be plausible yet wrong. An engine controller may see −35°C to 146°C as valid, so a lying temperature sensor can skew fueling without a DTC. “The lack of errors does not have to be an indicator.” Compare data when the car runs well vs. poorly. [Elektroda, g107r, post #16771573]
Could LPG cause stumbling even if the car also runs on petrol?
Yes. Begin diagnosis by eliminating LPG-related faults. Sticky EGR can also mimic hesitation. If the car is converted, verify reducer condition, filter service, calibration, and switch-over behavior before deeper engine work. [Elektroda, tzok, post #16775068]
What did the OP report about coolant and smoke?
Coolant level was stable with no “milk” in oil. Occasional white smoke appeared cold. The OP also wondered about fumes at the filler cap. These observations argue against constant coolant loss but still warrant targeted tests. [Elektroda, keseszel, post #16772843]
Are cheap compression testers useful for DIY checks?
Yes, as a comparative tool. Use them to verify even compression across cylinders rather than chasing exact lab values. The OP aimed to use the gauge as an index of uniformity after basic maintenance. [Elektroda, keseszel, post #16774857]
Should I check fuel pressure when chasing hesitation?
Yes. Fuel delivery faults can mimic ignition or gasket issues. A quick pressure test adds clarity before expensive teardown. This was raised early in the thread as a practical step. [Elektroda, bandi21, post #16774538]
Can coils or a crankshaft sensor plug cause intermittent power loss?
Yes. An aging integrated coil can drop a cylinder, and a loose or wet crank sensor connector can cut intermittently. These faults may appear only in certain weather or at take-off, then self-clear. [Elektroda, g107r, post #16771573]
What does continuous bubbling and overflow at the coolant cap indicate?
It indicates combustion gases purging into the coolant. Expect aeration, liquid discharge through the cap, and an empty tank after cooling. Confirm with a CO2 test and follow up with compression testing. [Elektroda, milejow, post #16774609]
How should I use live data to isolate the fault?
Record OBD parameters while driving. Compare sensor values during good operation vs. during hesitation. Focus on ECT, MAP, lambda trims, and crank signal stability. Lack of DTCs does not prove sensor accuracy. [Elektroda, g107r, post #16771573]
What is EGR, and why can it cause hesitation?
EGR stands for Exhaust Gas Recirculation. If the EGR valve sticks open, it dilutes intake charge at idle or take-off, causing a bog. Check EGR function before deeper engine work, especially on petrol engines with LPG. [Elektroda, tzok, post #16775068]
What is an LPG reducer (vaporizer), and how long can it last?
The reducer lowers pressure and vaporizes LPG. One user ran the original unit for seven years before concerns rose. Dirty filters and residue inside the reducer affected drivability until cleaned and serviced. [Elektroda, keseszel, post #16775201]
